Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Roughshooter on Sun May 19, 2013 9:20 pm
Bought Tub
Washed it hoovered it and discovered its coolant problem
Not bad for first days ownership if I say so myself :D :lol:
Treat every stressful situation like a dog...... If you can eat it or hump it......P**S on it and walk away!!!
Roughshooter
Vehicle Name: Tub
Modifications: None yet !!!! But I have plans
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Sun May 19, 2013 9:52 pm
Refitted the drivers door mirror and the drivers door-card.
While the card was off I took the opportunity of giving the door lock/handle mechanicals a drop of oil.
Cleaned out the carpets and it's starting to smarten up again.
Went to start the car for the first time in many weeks and it couldn't quite manage to turn over and fire.
The battery gauge showed power was down an unhealthy amount, no wonder as the doors have been open for lengthy periods while working on the truck without the engine running.
Thankfully we're getting longer days so hopefully the solar charger will bruing it back up for when I use it later in the week.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JEOH on Sun May 19, 2013 10:05 pm
Greenstripe:
Tried to fix the hose of cooling fluid system (with sensor between thermostat and rad) - failed. According to local dealer throughout Europe no longer available.
Next step ist getting other 35mm hose and see what goes...
Put off the black trim of the rear window. As original, view has improved a lot.
Image Image
GodZilla:
Trouble with rear diff again. New cover looks fine, but oil is pressed through the breather... Maybe wrong oil? Will claim that at the garage on tuesday.
Put the extension of the hose off as oil was pressed in the interior and made an awful odor...
Put it on the original breather ventile - still leaking there.
Convinced of wrong fluid now.
Kind regards,
Sorry for my pigeonenglish.
JEOH
Vehicle Name: Gentile
EX-GIGANTE (1998) 2018-2022
General Grabber AT2, Soft-Top
G-Wagon Mercedes 300GE 1990
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sun May 19, 2013 10:32 pm
Should be OEP90 Ian. :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Sun May 19, 2013 10:56 pm
Pumped the tyres up on the little blue bug (they all needed topping up)
Jump stared it and drove to my parents - good grief that Frontera is fun and can turn heads with the top down :D
There is a bit of a bang from the rear suspension that I suspect is an upper shocker mount, but apart from that it ran great.
Looking forward to it's next run up to Trentham Gardens next month.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Mon May 20, 2013 8:51 am
Make sure you give it a good clean Trugg's!!!!! :thumbup: :wave:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by montrehomme on Mon May 20, 2013 2:03 pm
Made her work a little :D got a distressed phone call from an elderly couple of friends, who's Astra had blown a hose.
towed them home and never even felt them behind me!. This Frontera is proving more useful by the day!.
Going to look at a Maverick for my wife this evening, no nothing about them, just a Terrano re-badged?.....
montrehomme
Vehicle Name: Phyllis
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Mon May 20, 2013 7:02 pm
Not today but tomorrow I will kick it as I walk past it :lol: then hopefully it won't be on my drive when I come home from work. I'm leaving it at home because the bloke that bought it is picking it up in the afternoon. :thumbup:
The only drawback with this I've got to walk to work. :thumbdown:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Mon May 20, 2013 7:38 pm
Will do ya good, think of the environment!!!!!! :thumbup: :mrgreen:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gazeddy on Mon May 20, 2013 10:14 pm
not so much my truck but i tweaked the bullbar kiteflyer was gifted at the annual. we have a deadline for it to be back on the road weekend of 22nd july. for some bbq :D
Gazeddy
Vehicle Name: gazeddy
Skype Username: gazeddy
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Mon May 20, 2013 10:19 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gazeddy on Mon May 20, 2013 10:23 pm
but is it oil or rusty bits that fell off
Gazeddy
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Mon May 20, 2013 10:25 pm
The rust adds texture to the otherwise boring oil slick... 8) 8) 8)
I reckon if Andy keeps his eyes open when he does the walk...after a couple of days he will have found enough bits to build another disco!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Tue May 21, 2013 11:23 am
Replaced the old front shocks for a set of monroes i pushed them in and still waiting for them to rebound this may take a while
Having issue with photobucket and embedding pictures sorry for small size
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue May 21, 2013 12:05 pm
Was this on the Bighorn or Trooper Drinks?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Tue May 21, 2013 9:09 pm
Bighorn
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rustynlc on Tue May 21, 2013 11:15 pm
Clean off the wheel arches and gave them some underseal, (will do the underneath tomorrow at work) blew outairbox and filter, cleaned the air flow sensor, topped up fluids, all in all a goodfew hours spent tinkering :D
rustynlc
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gazeddy on Wed May 22, 2013 9:55 am
well yesterday and not my truck. started repairing the front crossmember of the body. and its in worse shape than i anticipated
Gazeddy
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Wed May 22, 2013 12:34 pm
So far insured the 2.8 at £320.07 for fully comp fixed the drivers window fixed the boot window lock and fitted my Stereo
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Wed May 22, 2013 4:05 pm
:thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
