Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Roo on Wed Jul 15, 2009 2:24 am
Started painting my fuel guard Tank :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Wed Jul 15, 2009 2:28 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by horses45 on Wed Jul 15, 2009 4:27 am
at 6 this morning i will drive home from work tuck the tonka up and go to bed cos the baby tonkas coming this weekend and im off for 3 whole days to play with it :D :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Roo on Wed Jul 15, 2009 12:49 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john (smifffy) on Wed Jul 15, 2009 7:18 pm
i changed the sports back lights for the one off a lwb
so now i have got double the side/brakelight & indicators :D :drink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Roo on Sat Jul 18, 2009 12:31 pm
Hi :D
Finished painting one side of the fuel guard with 3 coats of paint :D
Washed the car and used a bit of T Cut on it :wink:
And paid for a new Coil :( From good old Ebay £46.00 :dance: instead of the £100+ from Vauxhall..
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by weave67 on Sat Jul 18, 2009 1:09 pm
you going to have a go at changing it Roo :?:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Roo on Sat Jul 18, 2009 2:22 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Rich_Somerset on Sat Jul 18, 2009 5:07 pm
put a new battery in the remote central locking fob, put water in for the washer jets, checked the oil and pumped the tyres up :D
Rich_Somerset
Modifications: errr...none...just spent £800 quid to get it through its MOT though
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by PixelMonkey on Sat Jul 18, 2009 11:17 pm
After sourcing a bit of scaffy pole cut from an old washing line i managed to get the upper and lower bolts holding the brake caliper to the hub off.
This let me finally replace both inner and outer wheel bearings and seals.
Also after getting the prop shaft seal from Vauxhall £7.60 i managed to replace this aswell fixing the leak i had. Cheers for the part number Phil ( Sir-Doris).
Wire brushed and sanded round my chassis , painted it with hammerite smooth and undersealed wheel arches etc.
Finished off painting the sump guards.
:drink: :drink: :drink:
PixelMonkey
Vehicle Name: Mini Monsta!
Modifications: Debadged
Mud Guards Removed
Spare Wheel Carrier Removed
Rear Seat Removed
Rear Bumpers Removed
Tinted Windows
Blacked Out Sunroof
Bucket Seats
Black Suede Headlining
Custom Dials
Dash Dress up kit
K&N Induction kit
HID Lights
PipeWerx Exhaust
Roof Spots
Under Bumper Spots
Twin Tone Horns
Ecotek CB-26P
Red L.E.D. Dash Conversion
Blue L.E.D. Interior Lights
+2" Coils
+2" ES9000 Pro Comp Shocks
2" Body Lift
Much much more to come.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sat Jul 18, 2009 11:31 pm
Wired in the CB, ran the radio aerial cable from its new position to the cd player (sorry SKIPPER!!)..
Went down to leysdown carnival, nowhere to park anywhere....but then found the chevybravafing will now climb up a vertical 24" high retaining wall concrete wall which opened loads of parking possibilites...all the kids watching loved it...as got a wheel in the air (had do it diagonally to be able to climb it) and a bit of 4wd low rpm wheel wheel spin as it initially climbed!
The fuz didnt say anything while they watched...but one came over later and said.."there is no way our police Landrover 110 would do that"... :lol:
I replied laughing saying that it is doesnt need to, as a police 110 can be parked wherever they fancy!! :lol: :lol:
Laters
Gregster
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Sat Jul 18, 2009 11:40 pm
Took it out for a drive,went down the dual carriageway at near on full naughty speed 8) bounced around a Welsh lane :D stopped for a :drink: then bounced around another :dance: ,parted company with Drift & headed home at full legal speed,until I got to the boundaround near Knockin then the EML started going on & off like a whores draws on a Friday night :( :( code reading tomorrow :oh yer:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by vyron on Tue Jul 21, 2009 9:11 pm
not much just made it home from work.
well crawled home. thrust bearing thingy's gone :cry: :cry: :cry: :cry:
vyron
Modifications: c-trax mt's front n rear.
steel wheels fitted.
mud flaps removed....
wheel carrier removed.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john (smifffy) on Tue Jul 21, 2009 9:40 pm
replaced inlet & return fuel pipe from fuel rail to first metal pipe in engine bay :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Wed Jul 22, 2009 12:37 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Sat Jul 25, 2009 9:30 pm
Well I ained to change what I thought was a shot lower passenger side ball joint. It wasnt shot, but chased and tightened both front wheel bearings, swapped the drivers upper BJ and the drivers track rod end. Oh and while there put the procomps on the front.
I must say I ran flipped uppers on my SWB from Milners, the bolts that hold the bj to the control arm are cheap, but it has a grease nipple and castleated big nut for the BJ. They ran faultless for a year or so despite abuse.
The ones I fitted from a factors had a nyloc for the big nut and the innards of the bj have fallen apart in just 6 months and a couple of outings. Looks like a call to milners as my replacement was the same cheap tat.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by PixelMonkey on Sun Jul 26, 2009 12:43 am
Removed a shim or 2 and finally sorted my camber issue, not the easiest of jobs as they were well stuck with pooh etc but got there in the end. :D :D
PixelMonkey
Mud Guards Removed
Rear Seat Removed
Tinted Windows
Blacked Out Sunroof
Bucket Seats
Custom Dials
Dash Dress up kit
K&N Induction kit
HID Lights
PipeWerx Exhaust
Roof Spots
Under Bumper Spots
Twin Tone Horns
Ecotek CB-26P
+2" Coils
2" Body Lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Mon Jul 27, 2009 12:58 am
i fitted this, can any one tell what it is,
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by cheekychick on Mon Jul 27, 2009 9:10 am
it's what you bought from tarantula 4x4, recovery points :P :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Mon Jul 27, 2009 1:01 pm
good girl,
