Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rustynlc on Mon Apr 15, 2013 9:42 pm
I got a grease gun to grease the nipples, just need To Figure out if There is more Than the one I found!
rustynlc
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Mon Apr 15, 2013 10:03 pm
Ordered some 50mm box, 100mm flat bar and 42mm pipe to make another set of rock/tree sliders
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Tue Apr 16, 2013 9:14 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Apr 16, 2013 11:58 am
Gave her a mud facial over the weekend:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Wed Apr 17, 2013 3:10 pm
took it back for round 2 and came out with a pass
so now have an mot :dance:
and i found out the last one was 2007 :roll: and since then it has done just over 1k miles
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by taylor6632 on Wed Apr 17, 2013 3:13 pm
put my new side exit exhaust together and on the truck.
taylor6632
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Wed Apr 17, 2013 6:35 pm
Tracked it up as it was abit out, then came home, jacked her up and removed rear diff cover, due to it giving up this morning outside the paper shop. So tomorrows job is take it to work and patch the tw4tt1ng thing up before re-fitting :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rustynlc on Thu Apr 18, 2013 8:15 am
Sanded, filled and primered a few little rot spots (on the rear doors) just waiting for the paint to turn up now :thumbup: :thumbup:
rustynlc
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Thu Apr 18, 2013 11:50 am
today i went over and put the bullbars back on, on my own(really need 2 people for mine)
then welded some rear recovery points on.
put the rear seats in
cut a couple of bars off the bullbars that i didnt like... now looks much better i think
insured it
and now waiting for the docs to be emailed to me so i can tax it
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Thu Apr 18, 2013 8:08 pm
FIXED IT! :dance:
Took my poorly diff case to work and gave it a good dose of grinder and welder and then fitted it back on, filled her up and alls well :dance:
While i was on my arse i changed the oil as i had some, and now im ready to go laning in the lakes tomorow :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Thu Apr 18, 2013 8:28 pm
and this afternoon
drove it home :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Thu Apr 18, 2013 9:22 pm
Changed the oil on the 2.8, new pads on the front and greased the wheel brgs and adjusted them back up :D Developed a funny rumbley noise suspect clutch or flywheel is on the way out :(
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fronty_TPJ on Fri Apr 19, 2013 11:17 am
Managed to get hold of all the rare parts for my truck :P taken ages but definatly worth it!
Pretty Cool having a picture of your truck on your head unit
1999 Vauxhall Frontera SWB RS DTI viewtopic.php?f=46&t=47878 (Fronty Pics)
1979 Porsche 924 GT Replica http://s1068.photobucket.com/albums/u45 ... che%20924/
Fronty_TPJ
Vehicle Name: Blue Thunder
Modifications: [IMG]http://i1068.photobucket.com/albums/u453/Fronty_TPJ/P1050062.jpg[/IMG]
Skype Username: tim.jay3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Fri Apr 19, 2013 3:24 pm
:clap: :clap: :clap: :clap: First flop-top B I have seen in this country...well done fella. 8) 8) 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Apr 19, 2013 4:00 pm
Nice tjp ... Looks amazing
As for me:
New lower ball joints.
New upper ball joints.
Upper ball joints flipped under top wishbones.
New steering idler.
Net result:
No more clunking going round corners.
No more clunking going over potholes and bumps.
No more dodgy camber on front wheels.
No more pulling to the left.
Job well done.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rustynlc on Fri Apr 19, 2013 8:23 pm
i compiled a list of spares that i need to get for my truck,
aux belt, clutch master cylinder, rocker cover gasket, possible new injector (or im hoping just a new seal)
newtyres x4, nudge bar (but sourced one), number 1 injector sensor (again already sourced one)
i did today manage to get under her and grease her nipples, :shifty: and cleaned all locking hubs, and replaced the spring that snapped on the bonnet release catch,
rustynlc
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Fri Apr 19, 2013 9:50 pm
I started mine for the first time since 1st March. 3 turns of the engine, and she fired up no problems. I is a happy chappy. :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Fri Apr 19, 2013 10:03 pm
Seen that soft top put me in mood for a swb again i miss the roof off in the summer but that just look amazing
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sat Apr 20, 2013 6:58 am
well yesterday i set to work on starting to mod...
so bucket seat in
1 pair of 8" spots fitter, need another i think..
black rear body lights
waffle boards fitted
rear speakers fitted
monroe rear shocks fitted
tyres pumped up
and that is about it for the mo
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Apr 20, 2013 4:48 pm
Gave the shorty a coat of matt black paint £1 rattle cans :lol: I really hated the Lilac colour. I did wipe the mud off where I was painting :lol: :lol:
