Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Mon Apr 08, 2013 9:55 pm
I went for a drive in my birthday present :D :D
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Tue Apr 09, 2013 4:05 pm
today i was back at work....
welded sill
wirebrushed more of the underside and under coated it.
sorted out the idle problem
fitted new dissy cap
fitted new ht leads
took it out for a quick drive
changed one of the head light bulbs
now at home and wanting :drink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Tue Apr 09, 2013 5:15 pm
Yesterday my little Bro (Horses45) :D came over to give me a hand changing Chrissy's clutch slave cylinder over for a new sealed one, we put my one back on that she had borrowed. :lol: Then we did Chrissy's exhaust manifold gasket as that had gone aswell. Aint she a darlin, can break anything!!!!!! :mrgreen: :wave:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Tue Apr 09, 2013 11:59 pm
Gearbox ..... back on. Just need to bolt all the other bits back on now.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by geeks on Wed Apr 10, 2013 8:24 am
All new wipers yesterday evening! I CAN SEEE!!!
geeks
Vehicle Name: The Hulk MK2
Modifications: To Come:
Stuff...
Also:
The Beast (2.8 SWB A Series)
Previous:
Skype Username: geeksandlies
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by taylor6632 on Wed Apr 10, 2013 12:35 pm
taken off cold start valve - sounds :shock: 8) :lol:
haha.
This is preparation for the 3" straight through pipe that i will be trying to craft over the next 2 months
taylor6632
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Wed Apr 10, 2013 12:47 pm
Well I found one of these in my tyre....
So I used this...
To do this... Time will tell if its done the trick or not
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Wed Apr 10, 2013 2:54 pm
today i got the last (hopefully) of my parts i need for my frontys mot
and i didnt want to start on the ball joints today so i did this insted
wrapped the exhaust :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Wed Apr 10, 2013 10:33 pm
You have been busy Fudge.... 8) 8) 8) 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Wed Apr 10, 2013 10:43 pm
Finally got the gearbox fully bolted up. The crossmember back in, tightend up and the gearbox mount bolted back too. Front exhaust section back in, sealent squirted and all done up.
Ratchet winch and frame removed, it worked a treat, the job would have been a right mare doing it on my own and using a trolley jack to support the gearbox. As it is it's taken far too long to do but I'm blaming the weather, work, shopping trips, teenage taxi trips etc etc....
Jobs left to do... Both propshafts, fill gearbox & transfer box with oil, leccy connections to gearbox, gearstick boot thing, connect battery, start it and go break it again... :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Thu Apr 11, 2013 8:12 am
Had to weld up the drivers door check strap as the dreaded parting had occured!!! Oh and went to a local scrappy and purchased a brand new battery that came from a recently dead motor for the princly sum of 30 notes!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Thu Apr 11, 2013 7:55 pm
and i spoke too soon.... more parts needed
today i changed the passenger ball joints and cv boots
wired in some side repeaters.
tested it out and all seamed ok
did a pre mot check. one bulb blown not too bad
then found that one of thw wheel cyclenders is f****d... so will be hopefull getting one tomorrow and fitting it tomorrow
then i feel it will be mot time :axe:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Thu Apr 11, 2013 8:13 pm
Hooverd mine out and put me new seat covers on!!!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Thu Apr 11, 2013 8:24 pm
Took mine to work, then came home and picked up the Megane and took it for MOT and while i was there i noticed a nice BMW 330D Msport on my mates front row so ive borrowed it to test drive over the weekend :wink: with a view to it living on my drive 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by montrehomme on Thu Apr 11, 2013 8:36 pm
New EGR valve fitted. After reading a thread on here, I removed mine, and noticed that if you pushed in the piston, stuck finger over vac tube, the piston just shot back!, obviously a split diaphragm.
Removed sticking rear calliper, cleaned, re-greased sliders, now no more smells or hot wheel!!. Pads were like new, so just de-glazed them.
After these two little jobs, it is literally a completely different vehicle :D
montrehomme
Vehicle Name: Phyllis
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by paul4be on Thu Apr 11, 2013 8:44 pm
New water pump fitted thanks to old one leaking. Lucky thing though as I found that the timing belt tensioner had a piece broken off that was loose inside the cover, so tensioner replaced as well.
paul4be
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Fri Apr 12, 2013 9:25 am
As the door mirror switch is the favoured cause
of the mirror heaters not working, despite a
functioning tell-tale lamp, I removed the
switch. After separating the gubbins from
the casing I found the contacts inside
heavily oxidised. An hour later had the
pieces shining and the switch put back
together. I will refit the switch later and
see what happens. The wiring diagram
suggests there will be no difference but I
will see.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mickh on Fri Apr 12, 2013 7:24 pm
Changed the sparky plugs today and was pleased to see all the gaps were burnt evenly albeit they were at 40 thou. Just about down to the porcelain.
mickh
Modifications: 2" lift.
Front winch.
CB radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Fri Apr 12, 2013 7:42 pm
today i fitted a new wheel cyclender and brake like(since it didnt undo from the wheel cyclender)
screwed on my front number plate
and then tried to get it in for mot tomorrow... and no where had a slot :evil:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by kees on Fri Apr 12, 2013 7:44 pm
Removed my power steering pump and stripped it down. Just need to replace the front seal, if i can find one.
kees
Now sold, A series Frontera.
FOG sticker
1997/ p reg 2.2i
Now sold.
Users browsing this forum: Google [Bot] and 16 guests
