Not quite today, but last Thursday...
Finally did the last few VAC pipes on the car, including the one behind the head with use of 10" Curved Forceps! Also, the two on the front axle that I missed last time!
Drives much smoother now, actually has some guts below 2,000 RPM!
Keeping it under 3,000 a few weeks ago in the Lake District wasn't fun I can tell you! (Kept getting limp mode after 3,000)
Paul.Stuhlfelder
Sleeper
Modifications: Towbar
Hella HH75 Spots
iPod Radio
Parrot CarKit
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Mon Apr 01, 2013 8:55 pm
Go-Kart.
Up on axle stands, rear wheels off and the two rear spring/shocks off. Both springs have broken in three places, might have something to with it failing the MOT!
I have new springs but the spring compressor's just not up to the job so I'm off to the shops for another one tomorrow.
Memo to self... Must slow down for those speed bump thingies and steer round the potholes when driving said go-kart, come to that must slow down in the thing full stop :oops: OiC Home Front does NOT like her MX5 being driven like it was designed to be or like a fronty either :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by zebadee on Mon Apr 01, 2013 9:04 pm
Well not quite me but Andytats welded my drivers seat for me, as I know nothing !! :oops: but when I got home I replaced the indicator lens on front wings with nice flush gun smoked ones and they look the dogs danglies :D happy days.
Dazza
Boing Said Zebadee !! B***cks said Doogle !!
can somebody stop this roundabout of life its driving me nucking futs !!!
zebadee
Model: 2.0i Sport Niagra 3dr
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by kees on Mon Apr 01, 2013 9:13 pm
Seals on the power stearing pump decided to retire on the way back from camping at Western super Mare.
kees
Now sold, A series Frontera.
FOG sticker
1997/ p reg 2.2i
Now sold.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Apr 01, 2013 10:19 pm
Power steering pump fixed itself on the drive back from Northampton. Good thing too as I was towing about 2 ton of caravan and goods.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Mon Apr 01, 2013 10:26 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Apr 03, 2013 7:10 pm
Frontera:
Ripped the rear drivers door card off to get to the mechanism. Mech was rusted up and wouldn't move. Anyways after a bit of hammering and liberal WD40 and spray grease, it finally moved. Net result is I took it apart, cleaned it up and works a treat. Happy days.
Windscreen and centre section of the exhaust to go and she is ready for an MOT.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by richardc9052 on Wed Apr 03, 2013 8:41 pm
Powerwashed it and the passo indicator lense flew off :( put it back on with a lick of clear sealant..
richardc9052
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JEOH on Wed Apr 03, 2013 9:33 pm
Destroyed two bolts. :| Have to sort this out on Friday...
Kind regards,
Sorry for my pigeonenglish.
JEOH
Vehicle Name: Gentile
EX-GIGANTE (1998) 2018-2022
General Grabber AT2, Soft-Top
G-Wagon Mercedes 300GE 1990
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Wed Apr 03, 2013 10:13 pm
Just put £80 of fuel and a bottle of injector cleaner in the tank
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Thu Apr 04, 2013 8:18 am
i recieved my new one.
now i have to sort it out for an mot.... let the fum begin :dance:
Fitted my steel belly pans I got off bernie :dance: no more penny washers to hold the crappy plastic ones on. Cheers bern :thumbup:
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Thu Apr 04, 2013 8:17 pm
Yours will be all ready for the lakes trip then wont it Scott!! :wink: :wink:
I wish I was going mate I really do :evil: couldn't get the time off though. :thumbdown:
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Thu Apr 04, 2013 10:26 pm
:thumbdown:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Thu Apr 04, 2013 10:31 pm
I will come if scott lends me his truck :butt: :butt: :lol: :lol:
Yeah right you would probably crash it while watching tv on the way up!! :oh yer:
Or would this be a test drive for when you gotta borrow it for morocco??
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Thu Apr 04, 2013 10:38 pm
Possibly if you don't pull your finger out :butt: :butt: :lol: :lol:
Well I would if SOMEONE finished painting so I could get that axle back on :axe: :lol:
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Fri Apr 05, 2013 6:46 pm
OOOOOOOOOOOOOOOOO!! :lol:
And i thought it was Tom that got married, not you 2!!! :butt: :lol: :lol: :lol:
