Re: WHAT YOU DID TO YOUR TRUCK TODAY! by richardc9052 on Fri Mar 29, 2013 4:52 pm
richardc9052
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Andytats Boss on Fri Mar 29, 2013 10:24 pm
What did you get Rob ,,,,Andy reckons you got a shogun :D
Andytats Boss
Vehicle Name: The pod
Modifications: It's a sleeper pod lol
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Fri Mar 29, 2013 10:43 pm
Are you going to get this one dirty though or is it to shiny
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Sat Mar 30, 2013 12:01 pm
Broke it.
The fan belt idle pulley spat its bearings out
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by taylor6632 on Sat Mar 30, 2013 12:48 pm
wheels off and grinding and sanding back any rust spots in the arches and chassis, treated rust and now waiting to prime, paint and waxoyl :D
taylor6632
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Mar 30, 2013 2:38 pm
Temp fix on my unlocking bonnet cable and waxoyl'd the new to be fitted fuel tank carrier and discovered waxoyl doesnt like to stick to primer :roll: so another coat needed when first has dried :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Mar 30, 2013 3:47 pm
Broke it :lol:
Something it up with the engine it feels like its holding back at 2900rpm when it does that I get a lot of black smoke out of the exhaust. I'm not sure what is up yet as I haven't looked. Any help would be gratefully received
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Mar 30, 2013 3:54 pm
Andy post in the correct section and I am sure the guys will help :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Mar 30, 2013 5:32 pm
A solid primed and waxoyled fuel tank guard 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Sat Mar 30, 2013 7:23 pm
Well today i started preparing for the lakes trip, so a service kicked things off, then i reaplaced the upper and lower ball joints both sides and flipped the top ones, nipped up the front bearings and stripped, cleaned and re-built the front brakes :thumbup: now it drives 100% better :D
Also while i was doin this i swopped back to my 265s as i prefer them off road.
Washed it and had a nice tight drivehome :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by justdan on Sat Mar 30, 2013 8:27 pm
Pre MOT work almost done !!!! Brakes , bearings !
justdan
Vehicle Name: Paddy
Alpine I.C.E system
Combra shiney nudge bar
Irmischer wheels
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Sat Mar 30, 2013 10:16 pm
Hmm, I think I holed the exhaust somewhere :(
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sun Mar 31, 2013 4:06 pm
Over the last month, in between artic chills, shopping trips and (shhhh) work... I've ripped off both propshafts, front exhaust pipe, trim, gear levers and the gearbox bash plate. Today I've removed all(?) the bolts holding the gearbox bell housing to the engine, attached a rope to the end of the gearbox and pulled....
... It didnt move :( Now, do I get under there and jemmy it out (assuming I have got all the bolts out, and yes I did get the single one, hidden right at the top of the bell housing on the 2.8!) Or do I just hook the rope onto O-no's towball, stick the truck into 4wd low and go for it.... :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sun Mar 31, 2013 5:33 pm
Been there mate...that bolt had me before too...
Tis a proper strong bugger...I had pretty much a whole fronty hanging by its 2.8 engine on the forklift as I tryed to shake it free...then found I had missed that one!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sun Mar 31, 2013 5:38 pm
It's off... The ratchet winch and frame idea worked a treat, gearbox came off and was perectly balanced :D I will do a few posts on the idea once everything is back together.
The problem? Rather than being the DMF (although it has'nt been fully discounted yet) the splines on the fibre disk where the gearbox input shaft goes in have been completly stripped! I've seen the centre come away on a plate with the springs, but have never seen the spline strip before.
Now, why did it go? Is the DMF failing, if it is and the springs that take up the 'shock' are now weak could it have put additional forces on the spline? or could it have something to do with 210k miles on the clock and me dragging a fully loaded Scottish & Southern Electric Jointers lwb transit out that had dug it self in up to the axles at work the day before.
Would it be in order to put a trooper fibre plate in with the springs just in case the DMF is past it's sell by date? And no, I'm not in the mood for having the DMF out too. The crank seal is okay (no oil in the bell housing) so the flywheel stays.
Pics, proper thread etc later.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Mar 31, 2013 5:49 pm
Frank mate, no techi info here, this section is just for an quick overview of what you have been up to with your truck and the like :wink:
Techi info leads to questions and this is then lost from the techi area search function.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Sun Mar 31, 2013 10:23 pm
Tightened up the steering wheel, as I had a screw loose
All sorted now with only one cut to the hand :(
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Mar 31, 2013 10:34 pm
Plastic is evil :twisted:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Loneranger on Mon Apr 01, 2013 4:37 pm
Washed it and looked at damage collected from driving Strata florida.........small dent to wing and a crease in passenger door :(
Good weekend but bloody cold..
Loneranger
2 inch suspension lift
2 inch Body lift - pending
33" KL71 mud tyres
winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Mon Apr 01, 2013 8:26 pm
Well today i played for the first time in 4 weeks. :dance: Took the clutch slave cylinder of my beast and put it onto Chrissy's as she needs her's for work. :cry: I stripped her cylinder down and Yep the bloody seal has given up. :evil: All for the sake of a 50p rubber seal the truck was dead. :roll: Now to get another seal (Ye Right!!!!!) :twisted: Chrissy has got a second hand cylinder comming from a guy on e-bay for £20 but wont be here till saturday. Oh well at least i got to play in the cold icey wind!!! :lol:
