Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Sat Mar 23, 2013 8:07 pm
I got a couple of pics but they dont do it justice and i cant get them on here as im computer illiterate!! :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Mar 23, 2013 8:35 pm
Used it as a mobile toolbox to go fix a mates car. Mk.IV Astra 1.6 8 valve. EML light on permanently with no apparent running issues. Whipped the EGR off and it was full solid with gack. Chiseled it clean. Drilled the gack out of the pipes to the EGR, and put it all back together again. Started her up and no more EML.
Happy days.
My mate thought it was going to be mega expensive lol. Got to love GM EGR systems.
Showed him the paperclip trick to read fault codes as well. He was shocked that VX would charge at least £50 to get the same results.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Mar 23, 2013 8:40 pm
I passed a Harley Davison Motorbike in mine in the snow at 06.30 morning on the motorway, he was doing 35mph and constantly wiping snow from his visor I thought he was either slightly mental or just daft :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Mar 23, 2013 9:30 pm
Both Drifty ... glorified water pumps them bikes.
Last three days here in North Wales had great fun with three foot of snow by our house, best bit misses at last has agreed that we need the Fronty, a result :dance:
MARTIN FROM LLAN
Vehicle Name: STINKY
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Sun Mar 24, 2013 7:54 pm
Had mine towed off my drive this afternoon to where I work after a total clutch fialure yesturday. Pedal flat to the floor no gear change managed to get home in second gear. I'd got a little on the pedal today so I assume the seals have turned inside out in the cylinder.Too snowy on the drive so I haven't really had chance to look at it but will fix it tomorrow at work. Fingers crossed :D
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Mar 24, 2013 8:15 pm
popped you a pm Alfie :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Mar 25, 2013 12:14 am
Fresh new anti-freeze ready for the sub zero temperatures we are now not going to have as I have changed the water to anti-freeze.
Yes I had water in there for a couple of weeks, while I was chasing leaks around the engine bay from a variety of split hoses etc.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by FrontySteve on Mon Mar 25, 2013 12:52 am
Bought it :mrgreen:
My 2.2i swb Project Midnight
FrontySteve
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Mon Mar 25, 2013 9:25 am
Well done frontynoob!!!!! :thumbup: :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Mon Mar 25, 2013 3:42 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Mon Mar 25, 2013 6:21 pm
Used the fronty to take loads of crap to the dump x2 then had some scrap metal ( not including the disco before you ask ) that needed to get weighed in. I had to lift the old 2.5 engine into the back as I didn't have an engine hoist and couldn't lift it with just me and Lisa, i decided that a bit of rednecking was in order, i reattached the roll cage part to the back and connected the hi-lift Jack to it using a d shackle and a strop, then attached a strop to the engine and started lifting it, after getting it as high as I could lisa used a plank of wood hooked under the engine wedged it onto the bumper and levered it in the back, yes she is superwoman lol, a bit more shoving and it was in the back, who needs an engine hoist
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Mon Mar 25, 2013 8:31 pm
Crawled under mine in our nice warm and dry workshop to investigate clutch failure. No leaks, clutch leaver free and moving. No loss of fluid but nothing on the pedal.Changed the master cylinder bled through till I"d got clean fluid,Bled out air Hey Presto working clutch.Back up and running in45 mins.Thats got to be some sort of record for me :D
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Mon Mar 25, 2013 8:46 pm
After work today on the way home i thought the truck was a little floaty on the steering again. When i got home i jacked the front up and found a little play, which i thought odd as its just had new wheel bearings on the front, anyway i undid the hub to find the circlip had come off on the drivers wheel :shock: , so i sorted that and adjusted both sides up and put back together :thumbup:.
Next job was adjust the steering box to get rid of the excess play in the steering wheel and top up the fluids, also stuck a new air filter in for good measure as the Lakes trip is approaching fast.
Also today i picked up new top n bottom ball joints and track rod ends from milners ready for a complete overhall before we go :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Mar 26, 2013 8:45 am
Ordered it over the phone last night ... next day delivery (I hope)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by justdan on Tue Mar 26, 2013 2:26 pm
New discs pads and shoes on the back ready for the dreaded MOT man !!!
justdan
Vehicle Name: Paddy
Alpine I.C.E system
Combra shiney nudge bar
Irmischer wheels
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Tue Mar 26, 2013 3:12 pm
Bruised the poor girl on a lamppost :( teaches me to park it close to a lamppost hidden by the nearside A pillar :/ also has uncovered a rust hole in the sill :evil:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by LFF64 on Fri Mar 29, 2013 11:02 am
I have fitted remote central locking to front doors and more importantly the tailgate
No more getting in then thinking I need to open the back and haveing to unlock the tail :)
LFF64
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by FrontySteve on Fri Mar 29, 2013 2:58 pm
Had 2 new gg at2 tyres on the front, then home and jetwashed. Shiney Shiney 8)
FrontySteve
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by th4neuk on Fri Mar 29, 2013 4:28 pm
Washed it for the first time in ages lol. It's shiny black again :D
Alan
th4neuk
Sidesteps
Rear privacy glass stuff
Tweaked torsion bar
BFG AT's
Extra reversing lights
Wish List
Rear Spring +2"
+2" Shocks
