Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Wed Mar 13, 2013 4:05 pm
Cleaned out all the gunk from the inlet manifold then put it back together and added a blanking plate to the egr
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gastruck on Fri Mar 15, 2013 10:14 pm
Finally got Gerty back on her feet. Iam now hoping that I have covered all bases and it can now see the man with the tapping stick. Still more to do but It will wait for warmer weather.
gastruck
Vehicle Name: Galloping Gerty
Modifications: CB fitted Handle Mr K
DLR lights fitted.
Upgraded driving lights
Roof bar with 4 lights
Traffic recording camera fitted
Skype Username: madmax1028
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sat Mar 16, 2013 12:22 am
Fitted the new to me prop I got from rospicer. Its silky smooth again yay...now to brake it again :roll: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by geeks on Sat Mar 16, 2013 5:38 pm
Cruise control stalks fitted and tested :thumbup:
geeks
Vehicle Name: The Hulk MK2
Modifications: To Come:
Stuff...
Also:
The Beast (2.8 SWB A Series)
Previous:
Skype Username: geeksandlies
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Mar 16, 2013 6:37 pm
All I have done is drive 151 miles back home with my new 2.0 shorty :dance: :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andy.c on Sat Mar 16, 2013 11:00 pm
i have same probblem with the birds nest
andy.c
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Mon Mar 18, 2013 8:48 pm
Today i drove the 2.5 to work, yesterday i got the 2.3 on the trolley jack to investigate the oil leak. Found that the sump had a bit of damage, so dropped it off and took it to work today, its now sat in thinners getting rid of the oil, ready to be introduced to the TIG set :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Tue Mar 19, 2013 6:46 pm
Well I fitted a bleed off valve to the truck today to try and increase the amount of boost it makes. Seems to have worked...now to just fine tune it
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rustynlc on Tue Mar 19, 2013 9:27 pm
just spent the last hour (or two) trying to chase up why my obd2/eobd code reader wouldnt read codes, got fed up so decided to fit the car seat covers i hadstill sat in the packaging, then thought id takle the front to rear brake lines as they were looking abit shabby, i now have two very shiny copper brake pipes all plumbed in just need to bleed the brakes through, but with a narked of misses indoors :shh: , best be a job for tomoro. :D
rustynlc
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Wed Mar 20, 2013 6:33 pm
Well for the past two days I'll been converting the shorty into a pick up
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Thu Mar 21, 2013 10:38 pm
Got the shorty temporarily insured just so I could see what it's like to drive with all the weight taken off the back end. I must say its fun to drive now. I've got the biggest smile on my face not just because its fun to drive but because I'm back behind the wheel of a frontera :thumbup: can't wait to take it to the woods on the 7th :twisted: it's going to get battered and bruised
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JEOH on Fri Mar 22, 2013 12:26 am
Replaced left front indicator light and repaired housing on the right side - those parts are quite expensive over here for the A Model...
Hammerited some harmed areas on the floor beyond the carpet.
Kind regards,
Sorry for my pigeonenglish.
JEOH
Vehicle Name: Gentile
EX-GIGANTE (1998) 2018-2022
General Grabber AT2, Soft-Top
G-Wagon Mercedes 300GE 1990
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Fri Mar 22, 2013 12:42 am
Just an idea jeoh. Do you need any more car bits if so put a post up with a list of items then if you are coming over for the annual. you could pick all the bits up and save on postage
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fronteramac on Fri Mar 22, 2013 8:31 am
wiped the snow off my fronty ,time to see how many neighbours are my best friend again :lol:
fronteramac
2.8 td sport sold
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by montrehomme on Fri Mar 22, 2013 6:26 pm
Long awaited oil and filter change :D
been putting it off, due to the horror stories of sheared bash plate bolts, but like the rest of the car, no rust, so no seized bolts!!!
The previous owner had also taken the opportunity of using copper ease on all the bolts, so it was a doddle!.
Didn't have a 36mm socket for the filter, but my ancient adjustable had the filter off first push. Filter replaced using new O rings
supplied.
Also, while the bash plates were off, I managed to change the vac tubes on the axle, and the one to the reservoir, just in case :D
Happy days!
montrehomme
Vehicle Name: Phyllis
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Sat Mar 23, 2013 3:37 pm
Whilst we have been trying to sort out our internet,I have been working on my 2.2 DTI.
See photo's. lol.
Ok guys & gals,here is my Frontera 2.2 DTI with new lights fitted and it is now sitting on its 20" rims.
20" rims fitted.
For those of you who know my Frontera,I am putting my mark on it. As I like it very much. 8) :lol:
R.I.P Sable!(2005 to 2013)
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Sat Mar 23, 2013 7:13 pm
Serviced it last Sunday including clean and lub front caliper sliders, remove and check hub bearings. Today we went to get our annual once over with the tappy stick man..................................WE PASSED :D :D :D
Regards
Stuart
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Mar 23, 2013 7:27 pm
Nice Stuart 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Sat Mar 23, 2013 7:48 pm
Took mine ploughing at 5:30am this mornin on the way to work and came across a Delicia and a Discovery stuck in the drifts over Stannage, the Delicia driver was very thankful of the offer of a tow but the Disco driver said "no your alright, its a Discovery, its more than capable, i just need a run up", so i pulled the mitsy clear and we sat and watched the green oval on road tyres attempt a snow drift, oooo about 4-5ft deep, and promptly get STUCK! :rotfl:
Again the offer of help was turned down, but this time with the reply "I have made it this far without your help!", after this abrupt reply, all i could do was drop mine in low box and drive around him! :butt:
I left work at 12 and, yep, the Disco was still there, without its stuck up c*$k of a driver. :thumbup:
The snow hasnt stopped all day here and we ventured upto Fox House for lunch and watched the RAF helicopter lifting people off of MAM TOR :shock: .
All in all a good day, now im guna get warm and :drink: 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Mar 23, 2013 8:03 pm
Bloody green oval drivers are all the same.
:butt: I'm one too :lol: :lol:
