Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Thu Feb 28, 2013 11:51 pm
Large bottle of rad seal, see what happens and chuck it back in.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Thu Feb 28, 2013 11:54 pm
Just buy a new rad Frank Chrissy's one is great value.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fronteramac on Fri Mar 01, 2013 5:37 pm
jacked the back up cos of viabration and rear prop uj joint knackered 2nd one now so thats my next job
fronteramac
2.8 td sport sold
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Mar 02, 2013 7:51 pm
Today I made a start on making my heavy duty rear bumper. The two lengths of tubing I got of Matt ( so its military grade :lol: ) they already had the two bends in them.
In one of the picture you can see the black bit welded on the top that is part of the old frontera rear bumper lol
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mickh on Sat Mar 02, 2013 8:31 pm
Pulled the smaller of the 2 crankshaft breathers off today. It felt like a length of plasticine. The inside was completely clogged with gunk. Bought a length off tube to fit tommorow. Hope it may have a positive effect on the oil leaking from the bell housing. (crankshaft seal)
mickh
Modifications: 2" lift.
Front winch.
CB radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Sat Mar 02, 2013 8:48 pm
New pads n a little service of the calipers to free em up abit as on my way home from work i managed to push the peddle and touch the floor without stopping :shock: , siezed caliper :oh yer: , luckily a bit of lube and some love and shes back :dance:
Then as i was on a roll i decided to throw my 33s on, just for fun 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by vermithrax on Sat Mar 02, 2013 10:01 pm
Took one of the cylinder heads off the v6 to be skimmed by the local garage, will be re fitting next weekend
If it aint broke . . . Give it to me ill brake it
vermithrax
Registration Year: 1999/S
Modifications: Non yet ...
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Loneranger on Sat Mar 02, 2013 10:11 pm
Drove mine round the edge of Sibby whilst setting up a punch challenge event for my local club.
Shall post some pics of the site tomorrow to wet the appetite of those unsure about attending the annual bash.......i must say it was looking a tad wet..
Pete
Loneranger
2 inch suspension lift
2 inch Body lift - pending
33" KL71 mud tyres
winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sun Mar 03, 2013 4:38 pm
Finished all the welding on the rear bumper it just needs painting now
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fronteramac on Sun Mar 03, 2013 4:57 pm
washed it and hoovered it
fronteramac
2.8 td sport sold
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JEOH on Sun Mar 03, 2013 5:59 pm
Greased the cross joints and inspected the bottom of the truck.
Needs a good clean up and another inspection then...
Kind regards,
Sorry for my pigeonenglish.
JEOH
Vehicle Name: Gentile
EX-GIGANTE (1998) 2018-2022
General Grabber AT2, Soft-Top
G-Wagon Mercedes 300GE 1990
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sun Mar 03, 2013 7:07 pm
Removed the trim, gear levers and both propshafts in preperation for removing the gearbox. Exhaust next, then the electrics, then the x-member and gearbox mount followed by the gearbox.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sun Mar 03, 2013 11:26 pm
Knocked this up as well to help getting the gearbox out and then back in without dropping it on me head!
It's got a 250kg ratchet lever hoist on it. While I wouldnt want to lift the engine on it, it should do the trick for the gearbox. Just need to fit some bracing to the frame and it's sorted.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Mar 03, 2013 11:31 pm
Wind down windows and plonk a 4"x4" lump of wood across and a ratchet strap through the hole, job done simple and redneck 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Sun Mar 03, 2013 11:32 pm
And maybe some feet? Dont want it damaging the floor bud, looks good tho, great idea :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by crash_ndie on Mon Mar 04, 2013 8:33 pm
i so could have done with that :evil: just finnished fitting my new clutch to the 2.3 :mrgreen: yippppeee ill have post some pics of the damage :wtf:
crash_ndie
Vehicle Name: the hulk
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by crash_ndie on Mon Mar 04, 2013 9:38 pm
crash_ndie
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jellybaby on Mon Mar 04, 2013 9:48 pm
Bloomin heck went with style then.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Mon Mar 04, 2013 10:06 pm
Ouch :oh yer: . Bet that felt abit odd under foot mate :shock: . How do you find the 2.3? ive got one sat in my mates yard, should do summat with it really as its MOT'd til NOV 13 8) just needs a small sump repair and shes all good :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Mon Mar 04, 2013 10:07 pm
na a bit of kemi metal and that will be back to normal
