Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sun Feb 10, 2013 2:58 pm
Truck... It's a 2.8, guess what I done... Apart from replacing the O/S rear door handle that is...
Yeah, another Oil n Filter change :lol:
she passed by v6 steve on Sun Feb 10, 2013 7:59 pm
My s plate LWB 2.2tdi passed her mot had to do a bit of welding to the sill and replace the whole of the cross member under the rear bumper and a couple of brake lines but nothing that cost to much so an other year of her pulling the trailer and tools around :thumbup:
v6 steve
Registration Year: 1999/S
Modifications: none apart from the rust bumps and scrapes
Re: she passed by Drift on Sun Feb 10, 2013 8:04 pm
Its always a good feeling :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mskiba on Sun Feb 10, 2013 10:21 pm
Installed an amp and tube, upgraded all speakers (and tweeter), tinted it and gave it a nice clean :) Happy days.
Regards,
Ski
mskiba
Vehicle Name: The Gaffa
Modifications: None
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sun Feb 10, 2013 10:30 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sun Feb 10, 2013 11:29 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sun Feb 10, 2013 11:43 pm
Friday: After getting the old bus through its MOT I was planning on changing the driveshafts as it had the a pair off a Frontera fitted just to get through MOT. Had a good look at the driveshafts that were delivered on Wed and one was mullered where the circlip is 'supposed' to sit and the other was the small CV joint version as fitted to Fronteras not Troopers :evil: :evil:
Frantic phone calls and no one in the area can get me a pair of CV joints till Monday :roll:
Milners to the rescue, 2x new outer CV joints ordered with next day delivery
Saturday: New joints turn up and off we go, passengers side was an easy job but the drivers side was a PITA. The groove in the driveshaft for the C Clip was damaged, had to slim down a parting tool for the lathe, mount the driveshaft and cleanup the slot using the parting tool.
After being parked up in Nov due to a combination of mechanical damage and no MOT it is now taxed, MOT'd and in full working order ready for a punch hunt today, same site that broke the steering back in Nov. Managed to complete the day without breaking anything, adding to the dents or getting stuck (had a few close ones tho)
BUT
The steering idler (brand new) is now bent, again :!: :!:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by montrehomme on Mon Feb 11, 2013 5:25 pm
Cleaned out the MAP sensor :D
Having got 'Phyllis' running lovely following Vac and leak offs swap and inlet and EGR clean, I was content.
This weekend, my wife and I drove to Rennes, about a two hour round trip looking for a new kitchen. We were more than happy with the performance and economy that we were getting, but, I noticed a VERY slight misfire, now this was no more than a minor flutter, but it was there, and being a perfectionist, it would niggle me if left unattended.
Today, whilst reading my favourite forum, I happened upon a thread about the MAP sensor. How could I have overlooked this?, I mean, I even disconnected it whilst removing the inlet manifold to clean it!.
So today I removed the MAP sensor, cleaned it, and took 'Phyllis' for a spin.
My God, what a transformation :shock: unbelievable!, no EML at 3500 rpm, clean and crisp throttle response throughout all gears, and a HUGE smile on my face.
Once again, this forum enhances my Fronty ownership.
montrehomme
Vehicle Name: Phyllis
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Mon Feb 11, 2013 6:07 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Mon Feb 11, 2013 6:33 pm
Well done fella 8) 8) 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Mon Feb 11, 2013 9:22 pm
Lucky... Best you go get a lottery ticket for tommorrows euro!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Tue Feb 12, 2013 6:31 pm
Dug spare steering idler out of the shed and replaced the bent one then took it to the local Turk's car valeting to get it jetwashed outside and underneath
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by millenaire on Wed Feb 13, 2013 6:47 pm
I didn't do all this today but bought 6m of vac pipe and replaced them all, one by awkward one, Changed oil and filter, changed tyre pressures up to 35psi for a wee experiment ( im running it on general grabber 2's). took spare wheel off back and bracket (also an experiment lol) replaced small piece of vac pipe i damaged fitting. Cleaned glow plugs and lead ends, topped up the water levels, refitted some loose dash trim (from the heater matrix replacement) and took it for a test run. HOLY S**T, what a difference. I have had a mid range power loss for a while now...Not anymore :D :D :D
Pulls like a train, acceleration is now brilliant, mid-range is back on song and i am a happy man. I also think it handles a bit better due to the spare tyre removal, though this maybe a placebo effect because of the engine going so strong. :lol:
I spent a lot of money on booze, birds and fast cars. The rest I just squandered.
millenaire
Vehicle Name: Black Beast of Arrrgggh
Modifications: Fitted Bose sound system from my now scrapped Alfa Romeo, fitted some tasty spot and fog lights. Fixed speedo problem, cleaned egr and sorted vac pipe issues.
Hammerite and Waxoyl underneath, it's got new discs, pads and copper brake pipes all round. watch this space for the next exciting installment lol.
Region: Northern Ireland
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by kees on Wed Feb 13, 2013 9:21 pm
Finaly got around to replacing the 2 cracked valve guides, 2 bent inlet and 2 bent exhaust valves. Now to start rebuilding the engine, maybe sometime later as it's to cold outside :lol:
kees
Now sold, A series Frontera.
FOG sticker
1997/ p reg 2.2i
Now sold.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Fri Feb 15, 2013 11:01 pm
I got one of those bluetooth rear view mirrors on ebay. Works great it clips over orignal mirror the display is not too annoying can hear and be heared fine, can upload phone book to it so it has caller display. Down side not voice activated the mirror glass is tinted great for glare at night but bit dark , It has a no house charger only a car charger that comes with a good length of cable so you can route it under dash and around window surround to mirror. The sunvisor catches it when i try to put it down as its slightly longer than the mirror.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Fri Feb 15, 2013 11:13 pm
Didn't do anything to my car but had to replace a full lock set on my aunties ford escort mk4 ( ignition barrel , doors , fuel tank & boot ) it cost £50 for the locks I didn't thing it was worth doing but my auntie did as she's had the car from new
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Feb 16, 2013 12:44 am
Did you then open it with your *insert random key from keyring here* key. Not that Ford had a reputation for that :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Feb 16, 2013 12:47 am
I did try that lol the only lock I could unlock was one of the doors
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Sat Feb 16, 2013 12:12 pm
Yesterday fitted an nice new Exide battery after the frost killed mine. Heavy Duty 3years guarantee £71.00. All good and sorted able to start truck again :D
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fronteramac on Sat Feb 16, 2013 5:23 pm
re-wired the spotlights on the roof then replaced sum fuses and put the sump bash plate back on
fronteramac
2.8 td sport sold
Users browsing this forum: Google [Bot] and 22 guests
