Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Thu Feb 07, 2013 10:29 am
Started it for the first time in a week, ingnition on and left it until the glow plug relay kicked out and we fired up first turn of the key, result.
Regards
Stuart
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu Feb 07, 2013 11:55 pm
Finally back on the stock alloys got a set of 235/70 or was it 75 lol cant mind but they on 235s anyway . I have tried 255s 245s and could not get full lockwas on 225s an they brought the revs down to 2800 at 70 mph on the 215s i was getting that at 60
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by montrehomme on Fri Feb 08, 2013 11:49 pm
Made the Truck WORK for a change today!
Got a distress call from a local English ex-pat, who's Trooper 3.0 Citation had just emptied 5 litres of oil on the road :(
Took the Fronty out with towing bar, oil, and toolbox at the ready.
Looked underneath, and yup, it was a real slick under there. Couldn't identify exact point of leakage, due to all the bash plates,
but figured it could be the notorious oil pump 'O' rings or something.
Hitched it up to my Fronty, and dragged the poor thing to the local garage, thankfully only a couple of k back.
Left him there with another guy as a lift home, and reflected on the first proper work that my Fronty had done. Heavy old truck
that Trooper :D and no doubt a heavy old bill heading his way!
I gave mine a pat on the dash top on the way home!, is that wrong?
montrehomme
Vehicle Name: Phyllis
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Fri Feb 08, 2013 11:57 pm
thats not wrong at all its a job well done :clap:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Feb 09, 2013 8:53 am
Bleeding 3.0 (4JX1) Isuzu engines. Liability to the name they are/were :oops: :oops: :oops: :oops: :oops:
Not heard of one dropping its oil though. Gaining oil as the seals in the common rail lets the diesel into the sump.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by paul01 on Sat Feb 09, 2013 10:24 am
Replaced my air filter for a pipercross one :D
It's now got power 8)
Couldn't have helped that the old filter was full of mud :oops:
At least ts good now
paul01
Vehicle Name: ?
Modifications: none
yet :)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Feb 09, 2013 2:19 pm
Got O-no through it's MOT re-test :thumbup: Now got a 12 month ticket on that one.
Truck oon the other hand was MOT'd in Dec and will be getting another test around July to get the MOT test away from Dec, too b****y cold to be doing things like ball joints etc in Dec :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Feb 09, 2013 2:44 pm
OOOOOOOOhhh yer baby that felt good, turned her on and took her for a weekly spin around the back lanes just to keep her fluids moving :wink:
All was well and drove like a dream 8)
Now to ebay the Piccaso :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sat Feb 09, 2013 3:39 pm
Last night at about 3.30am I finally got the dam'd oil filter off...in the end I had to use a long extension as a chisel and a lump hammer to whack the hell out of it until it started to turn. Not much left of it now lol. But it has a nice shine one in its place, done up hand tight.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Feb 09, 2013 7:19 pm
You did smear oil on the filter o'ring didn't you Dan. If not that is usually why they jam on.
As for me I drove her to bobbinsjob's to put his new to him flywheel, new clutch assembly and old gearbox back on. It was a litle temperamental, but it gave in in the end.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Feb 09, 2013 7:33 pm
Oi Neil, no techi hints in here :thumbdown: :lol:
Good on ya helping the old fart bobins out :lol: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Feb 09, 2013 9:43 pm
Nothing to my truck but helped out Ian out putting his truck back together. Then we took it for a little test run :4x4: when I left him he was grinning like a kid on Christmas morning :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Feb 09, 2013 9:55 pm
Ahhaa...that grim...like a truck that can get him home :thumbup: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Sat Feb 09, 2013 9:59 pm
All sorts recently.....
Went laning week before last in the snow over the Wayfarer which was fun :lol: Also went for a look at the Corwen Carwash , which was erm , very fast and very deep :shock:
I've also replaced the tensioner and today chopped a nice hole in my boot floor and unclogged my fuel pump ably assisted by Dave. Tar Lar :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fronteramac on Sat Feb 09, 2013 11:31 pm
yeah but did u go for it si ???? u never said only that it was fast and very deep,
fronteramac
2.8 td sport sold
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Sat Feb 09, 2013 11:33 pm
LOL... erm, no mate.
I've done it dozens of times, but I've never seen it that fast/deep before. Unfortunately my crappy pics don't do it justice
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fronteramac on Sat Feb 09, 2013 11:36 pm
haha dont blame u mate, just lookin at that bit of wooden fence with the water curlin round it
fronteramac
2.8 td sport sold
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sun Feb 10, 2013 10:29 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Sun Feb 10, 2013 11:28 am
Thanks Neil n Andy. Really couldn't of done it without you both. Yes, after we got the props back on (gotta order new uj as one is siezed solid) we took her round the block. Considering she's stood in the garden since October, she started well and now the gear changes are smother than ever :-):-):-):-):-)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sun Feb 10, 2013 1:43 pm
... and you can get 1st, 3rd, and 5th without smashing your stereo every time :D
