Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sun Dec 30, 2012 7:37 pm
Ian and i got mine a little muddy :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by wideformat on Sun Dec 30, 2012 8:49 pm
Started mine up after a week and a half, as always started 1st time then took it for a spin on Salisbury plain :thumbup:
wideformat
Vehicle Name: More Trouble
CB Radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by crash_ndie on Sun Dec 30, 2012 10:37 pm
welded up the snapped tie rod just so i can move it round the back of the house got a lift to scrap yard, there was sat a 2.3td , my heart lifted ! I stuck me head under the wheel arch and :evil: grrr some git has already took the threaded hex bolts :roll: gutted so took some off the trooper... yeah they dont fit, too long huff but fitted some shogun turbo hoses to it so i got boost at the engine now :clap: Just need to figure out why its leaking oil on boost :? :?
crash_ndie
Vehicle Name: the hulk
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Mon Dec 31, 2012 2:32 am
Changed the steering idler on it. Fairly easy job...except that the bolts hadn't been touched for 16 years so they put up a fight :( but got them in the end hehe.
In the new year I'll be changing over the steering box as its p1ssing fluid out. Then just the handbrake and it should be ready for the MOT. Getting straingly used to not having a handbrake lol.
Did some Vac pipe work...
Before:
After:
Pipes left to do - 4x4 actuator pipes, pipes underneath the grey/light blue bits on the top right, (need to remove the bracket to get better access) oh, and the joyful little tight one behind the engine itself! (Might ask the garage to do it Wednesday, as it's having the injector seals done)
I do have some questions though, should I be replacing all the stiff tubing (Black/White/Brown) with the silicone hose, or is the stiff tubing ok to leave? Also, underneath the grey/light blue bits in the top right of the engine bay there are some metal tubes that go under the engine, I assume these lead to the 4x4 bits?
Would replacing the Vac Pipes give me better bottom end on the engine? I think it may be placebo, but it seems a little less anemic before the turbo kicks in now.
Paul.Stuhlfelder
Sleeper
Modifications: Towbar
Hella HH75 Spots
iPod Radio
Parrot CarKit
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Mon Dec 31, 2012 8:13 pm
For a Fronty that engine bay is far, far to clean Paul... It needs mud, oil splatter and an old oily rag for a dip stick wipe :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Mon Dec 31, 2012 8:22 pm
Looks like the one in the Haynes manual..... :shock: :shock: :shock:
I never seen one that looks like the one in the Haynes manual before..... :shock: :shock: :shock:
Maybe it will come apart and go back together like they say it will in the Haynes manual.... :thumbup: :thumbup:
....like none of my bleedin fronteras do! :twisted: :twisted:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by wideformat on Tue Jan 01, 2013 5:45 pm
Actually got round to fitting my front recovery point today and sticking the URL on the rear screen only taken me 9 months but you can't rush these things :D
wideformat
CB Radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Tue Jan 01, 2013 5:49 pm
Nothing all the time I was off work.....crap weather and hangovers got in the way :evil:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Tue Jan 01, 2013 7:43 pm
Looked in the back of the SWB and decided that if I could gather all of the loose straw and hay off the carpets, seats and roof lining I could probably make a full bale :?
Considered brushing it out , but then decided having a kip in front of the telly was much better use of my time.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Retro Pedro on Tue Jan 01, 2013 11:28 pm
Touch wood sorted the side and main beam lights out. Seems that I had shortened out the near side side light bulb holder going through deep puddles playing silly buggers giving my grand-daughter and her mate a good giggle. Changed the bulb holder and renewed the 10amp fuses and all seems good.
Main beam was down to another 10amp fuse, being replaced - pinched the original when trying to sort out the side lights first time around.
Found it alot easier to loosen the headlights - only 2 bolts for each side. Had a go out at fitting the missing plastic clips but couldn't get them to seat in properly. Might have to revisit after I've seen how the headlight alignment is now positioned with the new clips.
All this after I had done the twin roof seal relubing on the Focus CC.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Wed Jan 02, 2013 1:29 am
On an A series it is always the nearside that screws up...no technical reason, its just sods law as its the most awkward to get to... :twisted:
Offside is easy, airbox comes out in seconds...nearside means battery out and still the washer bottle gets in the way, and the damn bolts always snap when you try and remove that! :twisted: :twisted: :twisted: Unbolting the headlight is a good move to gain some space. 8)
You didnt disconnect that battery on the Focus did you Pete...you know you are banned from doing that! :lol: :lol: :lol:
If the child leaves me for ten mins ill do my weekly checks pump the tyres up and give it a quick jet wash :)
She did finally.
Last edited by igotababyfrontera on Thu Jan 03, 2013 8:21 pm, edited 1 time in total.
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Thu Jan 03, 2013 4:22 pm
I replaced all the brake pads on the Landy. Don't think I could of got anymore out if the old ones :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Thu Jan 03, 2013 4:30 pm
There's plenty of life left in them Andy :P Lol
I broke mine :( on way home yesterday it started making a real nasty grinding sound. Duno what it is yet..but I left it at home and took grans car instead today. Haven't even been abusing it recently... So god knows :(
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by stevd on Thu Jan 03, 2013 5:27 pm
Replaced the rear axle, apparently diff cases arent meant to have wholes in them.....who knew!
stevd
3.5" wind up on front
pro Comp Shocks
Side step removal
Bonet Guard
A fair amount of scratches
Lots of rust to add character
16" alloys from an A Series
Silicone vac pipes
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Thu Jan 03, 2013 6:40 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by crash_ndie on Thu Jan 03, 2013 7:40 pm
fitted PAS hose on it today so no more leaks :dance: thought id line the pump up to while i was there, found a missing bolt from the back off the pump so it was twisting all nice and straight now :mrgreen:
crash_ndie
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Thu Jan 03, 2013 8:36 pm
Looked at her. Will be collecting the re-sealed fuel pump tomorrow. Hopefully will be mobile again tomorrow night.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Thu Jan 03, 2013 10:14 pm
