Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu Dec 06, 2012 5:15 pm
I wasnt warm im always grateful for the 2.8 showing a non overheating guage an liked the nice choice of cold or hot in the summer but in the winter instant heat is a no no
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Thu Dec 06, 2012 7:41 pm
Driven through some incredible floods this evening, the only thing that stopped me crashing was pure dumb luck. Mental :crazy:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by ballemann on Thu Dec 06, 2012 9:30 pm
Its cold here in Norway, and offcourse the coolant turned into ice, nothing bad happend, just heating it up, and change the coolant :=)
ballemann
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Dec 07, 2012 8:58 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Fri Dec 07, 2012 9:55 am
Thanks Neal I don't no about any dates myself yet it all depends if I start a new job. Plus it would be an outside jobby cos I don't have a workshop but if I could borrow one then I would Travel because its too wet & cold outside. :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mickh on Fri Dec 07, 2012 11:49 am
Hint hint Neil :lol:
mickh
Modifications: 2" lift.
Front winch.
CB radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Dec 07, 2012 11:50 am
Andy:
I have a mate in Norwich with a heated, dry, full workshop and 4 post ramp lift. I can have a word with him tomorrow as I am using it to do my brake pads all round. I am sure he can spare some time/space for some beer tokens. Plus also he has the necessary tools for half shaft removal ;)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Fri Dec 07, 2012 4:02 pm
bloody hell your better than santa
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Fri Dec 07, 2012 5:39 pm
Special tools for a Disco half shaft comes in the shape of a 13mm socket. Hub nut socket is a big fella, don't be tempted to use a chisel, get the right socket/box spanner.
Regards
Stuart
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by davenlin on Fri Dec 07, 2012 5:48 pm
got one side of the truck t cut (it's blue)
RDH Graphics & Decals
davenlin
Modifications: none yet
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Fri Dec 07, 2012 7:02 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by scottp on Fri Dec 07, 2012 7:28 pm
This years mot just ran out so had it tested but it failed.......only just on a tyre.
what a car :dance:
scottp
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by th4neuk on Fri Dec 07, 2012 10:32 pm
Fitted the new wiper mechanism. No longer held together with cable ties :-)
Sorted
Alan
th4neuk
Sidesteps
Rear privacy glass stuff
Tweaked torsion bar
BFG AT's
Extra reversing lights
Wish List
Rear Spring +2"
+2" Shocks
Ha ha mine is :oops:
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by geeks on Sat Dec 08, 2012 6:45 pm
New battery fitted, no more jump starting The Hulk off the race car when its cold :D :lol: :lol:
geeks
Vehicle Name: The Hulk MK2
Modifications: To Come:
Stuff...
Also:
The Beast (2.8 SWB A Series)
Previous:
Skype Username: geeksandlies
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by kees on Sat Dec 08, 2012 8:33 pm
went to collect an aprila 50cc scooter with no plastics. Couldent be bothered to take the trailer so just lay it down in the back :lol:
kees
Now sold, A series Frontera.
FOG sticker
1997/ p reg 2.2i
Now sold.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Dec 08, 2012 11:06 pm
Broke it last Sunday, cancelled MOT for this morning and finally managed to get it fixed today.
Discovered a small rust hole in the primary brake line where it goes into the 'T' junction next to the front O/S suspension. Couldnt get the flange nut thing out so ended up having to cut the 'T' junction out of the circuit along with the through joint next to it and the pipework up to the master cylinder.
following 1 trip to the local Factors and another to Machine Mart I had all the bits to do the job.... Soon sused out that doing brake lines out in the yard with a stupid little torch for light and in the freezing rain aint fun. So binned the thing until this morning. All done now, fancy new bit of pipework is on, two in-line connectors linking the new bits to the rear pipework (which, on inspection looks okay) and all joints holding. Also flushed the old fluid out (and air... lots of air... LOTS of air). now have working brakes which will be strange and take some getting used to.
MOT re-booked for Tuesday, fingers crossed lol.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrPete on Sat Dec 08, 2012 11:27 pm
Good luck snapper!
My truck's having a well earned rest tonight after about 800 miles of towing around the country whilst sorting things out & moving! Still more to shift tomorrow but all good fun.
Been an absolute star and well impressed with it, same with fudge's 2bodies, though some TLC due for them both - a well deserved wash & polish each, hehe! :)
Don't confuse your books:
Gone but not forgotten...
Comments here
MrPete
Model: 2.0i Sport Niagra 3dr
Skype Username: MrPete_81
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Sun Dec 09, 2012 1:20 am
Yes Andy, that's the fella. Just couldn' remenber the size, still got mine but haven't used it in a while.
Lub the bearings up really well as there is a seal in the stub axle (stub axle bolted to the end of the axle tube, said seal inside at axle tube end) that stops the diff oil getting into the hubs, so the only lub will be what you put in there. I know of people that cut a "V" at 6 and 12 o'clock in said seal to allow the diff oil to flow in and out of the hub and swear by it, others just leave the seal out. Never touched mine and had no issues though I used to strip the hubs annually anyway.
Regards
Stuart
Fatbaz
50mm body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mickh on Sun Dec 09, 2012 5:34 pm
Yesterday adjusted the handbrake, 2 clicks and it was locked.
Today adjusted the handbrake, 6 clicks and it is locked.
Note to self, next time do it properly to start with.
mickh
Front winch.
CB radio.
Users browsing this forum: No registered users and 10 guests
