Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigjay on Mon Nov 05, 2012 10:11 am
Just jump started mine :(
bigjay
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JEOH on Mon Nov 05, 2012 4:03 pm
Hi,
searched for the failure of the left seat. It moved a bit forward while braking - this drove the Mrs crazy!
I did not realize that - a question of body-weight...
As it didn't slide forward by pulling the back I thought this was only on the right side possible :crazy:
So put all the covers to the side, compared both seat rails and the mechanism - no difference at all apart from moving when fixed and not moving when released...
Before replacing the whole seat I tried WD40 in a drowning dose and then this impression appeared:
Something seems to have stuck there for ages - now it is rusted away / gone.
And the seat moves as it should. And is fixed in the driving position. I assume, it has never been before... :oops: :oops: :oops:
Kind regards,
Sorry for my pigeonenglish.
JEOH
Vehicle Name: Gentile
EX-GIGANTE (1998) 2018-2022
General Grabber AT2, Soft-Top
G-Wagon Mercedes 300GE 1990
Fitted some 30mm spacers on mine :dance:
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
I can't believe you just worthless without pics me! :shock:
Not loaded on comp yet, playing on phone. It just 'corrects' the offset so they sit like a set of a series rims would on a B. 8)
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrTom on Mon Nov 05, 2012 9:46 pm
had a sniff of the inside of mine.... mmm 7 month old pay n play cow sh!t fresh.
After some bellend sent me in the pit of pooh ..... Colley!
MrTom
Model: 2.0i Sport Niagra 3dr
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
Insa Turbo special tracks
2" suspension Lift
Spare wheel carrier removed
Rough country Shocks
Roof Rack
4 X 55 Watt roof lights
Tow Bar
Fan over ride switch
Bucket seats
3-point Sparco Harnesses
Rear seats removed
Manual locking Hubs
Rear welded recovery point
Winch bumper
Winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Mon Nov 05, 2012 9:49 pm
Is it not running at the minute Tom ?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrTom on Mon Nov 05, 2012 9:57 pm
No mate :( put a new starter motor on her the other day and she fired up like a beast but it was p!ssing petrol out of the hose coming out of the petrol tank (must have perished) and I cant figure out how to get the tank off at the mo :roll: looks like the filler neck needs to come out.
MrTom
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
2" suspension Lift
Roof Rack
Tow Bar
Bucket seats
Rear seats removed
Manual locking Hubs
Winch bumper
Winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Mon Nov 05, 2012 10:08 pm
Mines doing the same mate and starving itself of oil, service required i think :think:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Mon Nov 05, 2012 11:06 pm
Done some welding on the arches getting it ready for a MOT
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by frontlee3 on Mon Nov 05, 2012 11:24 pm
sold it by the looks of it
must get it mucky
frontlee3
Vehicle Name: blue beast
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Mon Nov 05, 2012 11:53 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Tue Nov 06, 2012 2:34 pm
Drove mine to a local garage to see what the problem is with the rear diff and hopefully it is not major. :cry:
R.I.P Sable!(2005 to 2013)
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Tue Nov 06, 2012 6:18 pm
Done nothing with mine for about a week am going to give him a run tomorrow to pick up some logs.
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
Finally emptied all my tools out of the back. :oops:
It's nice looking through the rear window and seeing a cow instead of boxes :lol:
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Tue Nov 06, 2012 7:52 pm
Changed the engine oil and filter. Changed the clutch fluid, put in some injector cleaner and fitted some new wipers :D
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Wed Nov 07, 2012 12:34 am
done more welding this time on drivers rear arch, that both rear arches rebuilt . Also my oil catcher arrived today that will get fitted tomorrow.
Just discovered driver rear caliper has been siezed for looks a while the disc has rust on it i have spare new ones i got for a tenner but might try see if can free off the caliper first
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Wed Nov 07, 2012 5:23 pm
Just added some more stickers :lol
This one is funny :D
And to stop the glare from the roof lights I took off the rear spoiler thing from the 2.5 frontera then cut it down abit by 6 inches or so then bolted it to the light bar which I thought was a good idea ( plus its got our website address on it )
Now all my tools are in the house i put my subs back in the boot :v happy:
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Thu Nov 08, 2012 2:44 am
Finally got around to fitting the CB, properly plump and wire up the boost gauge and also wired up the light for the inclimeter :D Dash now looks like a x-mas tress at night lol
Ill tuck the wiring away when its light outside. Just need to check the SWR and the CBs g2g :)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Thu Nov 08, 2012 4:38 pm
Finally got round to removing some useless bits of metal bolted to my engine.
The EGR's and pipe are gone and the blanking plates are on.
Hound Dogs Tractor
Hound Dog
Missing In Action
Missing In Action
