Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sat Jun 27, 2009 7:03 pm
was a giggle Roo... :lol: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by tez1963 on Sat Jun 27, 2009 7:16 pm
gave the engine a clean and changed me filters,oil,fuel,air and new engine oil to engine and gearbox :dance: :dance: gonna change the diff oils over the next couple of days :wink: :wink:
tez1963
Modifications: none
in between trucks
at moment !
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by vyron on Sun Jun 28, 2009 9:31 pm
well i made a start..
pitty it rained tho. ar well there is next weekend to finish.. :4x4: :4x4:
vyron
Modifications: c-trax mt's front n rear.
steel wheels fitted.
mud flaps removed....
wheel carrier removed.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sun Jun 28, 2009 11:45 pm
i did a bit of painting, and fitted a new 3 way plug, and new seats thanks alex.
viewtopic.php?f=46&t=25879&p=297267#p297267
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Mon Jun 29, 2009 12:01 am
Looking good Andy, I see what you mean no, thuogh mine is a bit different bus still do-able 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Roo on Tue Jun 30, 2009 2:12 am
Hi All
Daughter & I cleaned My Back Wheels, seeing as they had to come off, Sir Doris changed the back break pads, also he changed the break &Clutch Fluid, and he Put the CB Radio in for me .. :dance:
Daughter Took The Sport Stickers off from both side Panels. ( she got fed up cleaning the wheels :wink: )
Going to change the front pads tomorrow and clean the wheels and Lacquer them :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Tue Jun 30, 2009 2:31 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Roo on Tue Jun 30, 2009 2:39 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Tue Jun 30, 2009 2:42 am
It is today already! X
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Roo on Tue Jun 30, 2009 2:46 am
oooooo Don't I know it :lol: :lol:
Night All Image
See You tomorrow for round 2 Sir Doris :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Tue Jun 30, 2009 2:47 am
Yup... bright and early for a change, not like today where we didnt actually start anything till 5pm ;-)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Tue Jun 30, 2009 9:42 am
Not exactly what I've done but more like what I've discovered/found
after owning the truck for 2months......
I finally figured out how to turn the interior light on!!!!(it never dawned on me to PULL a switch, i just thought the bulb had gone)
and
I discovered a 6ton bottle jack hidden behind the panel in the back, when I was trying to workout why my rear washer jet isn't working.
oh the mighty Frontera everyday brings more adventures and discoveries
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Tue Jun 30, 2009 11:18 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by vyron on Tue Jun 30, 2009 3:23 pm
sure thing jim. its raining here today so no play.. today.. :(
vyron
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Roo on Tue Jun 30, 2009 7:54 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Tue Jun 30, 2009 8:05 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Wed Jul 01, 2009 5:30 pm
I actually done some thing today,
drained all the water that has pooled under the carpets, re-sealed (hopefully) the leaking roof which I suspect as being the source of the leak. Fitted some new speakers in the front door panels (just cheapy 10cm jobbies from maplins). Put some radiator flush in the water, in preparation for tomorrows thermostat replacement. Made my rust hole even bigger until i ran out of rust and got to some sound metal. and finally decided that the thermo switch is the fault as far as my fan is concerned (bridging the terminals to the fan it works a treat)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john (smifffy) on Wed Jul 01, 2009 5:58 pm
i sweated me nuts off stuck in traffic while out :D :D :D :drink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Wed Jul 01, 2009 6:48 pm
I used mine to pull a tree stump out of the garden, :D :drink: :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Wed Jul 01, 2009 8:31 pm
I put some molyslip in the engine :D
