[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead Frontera Technical Support • View topic - Sir-Doris's underseal thread
Thats entirely up to you Jellyman, There is a pub a couple of hundred yards away that does a good dinner or there is machynlleth about 6 miles away that has all kinds of takeaways, chinese, indian, fishy chippers and a kebab shop.
Since camping is involved I daresay there will be a campfire and some beverages consumed.
Sorry you cant make it Alchemist but like everything else there will be more.
Il pop into the campsite on my way home in the morning and just let them know there will be a few of us staying, may get a last minute discount.
a good evening was had even though you get the impression you were being watched in the morning. no incrimanating pictures there yet then. only took a few pics too busy falling through the camping chair and the others are far too much but it was a full moon in wales.
The only boundry is your imagination. Jellybaby (Dave Jellyman)
