Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigjay on Mon Sep 17, 2012 8:09 pm
Carbon wrapped the bonnet to try and hide the rust
bigjay
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by paul01 on Mon Sep 17, 2012 8:14 pm
In that case
Maybe I should carbon wrap the car :lol:
paul01
Vehicle Name: ?
Modifications: none
yet :)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Mon Sep 17, 2012 8:34 pm
Atleast the bonnets not bad pal :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mudog88 on Mon Sep 17, 2012 8:54 pm
Pulled radiator and inter-cooler in an attempt to get to the water pump and cam belt. The coolant was horribly dirty, so I gave the radiator a cleaning. Had a cold one, then attempted to get the harmonic balancer off. Then the sun decided it was time to hide and my work light blew a bulb :roll: so I decided to have another cold one and call in a night. :drink:
~1992/J reg Vauxhall Frontera LWB 2.4i (sold)~ (the Frontera that got me started on Fronteras)
~1996/N reg Vauxhall Frontera Sport S 2.8TD~
mudog88
Vehicle Name: Betty
Modifications: Kingpin Advantage 265/75/16's on black steel wheels.
2+in coils with torsion bars cranked up 2+
EGR 'birds nest' removed (turbo spools sooner and it actually reached max pressure now)
Skype Username: johnphillippoin
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by paul01 on Mon Sep 17, 2012 8:54 pm
paul01
Vehicle Name: ?
Modifications: none
yet :)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Mon Sep 17, 2012 9:24 pm
Wonder wot it would look like all ripped n scratched after a days laning tho :shock: :thumbdown:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Mon Sep 17, 2012 9:41 pm
well today i have done nothing to mine yet
but i have been thinking about selling it :shock:
but i dont know how much i would get
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Mon Sep 17, 2012 11:37 pm
done anything to mine ? :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Tue Sep 18, 2012 1:43 am
Further wiring for the roof lights, half an hours work should see the job done.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Sep 18, 2012 6:50 am
Got back from holiday. All the way back from next to Silverstone with a tin tent on the back in 3 hours.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Tue Sep 18, 2012 7:38 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mudog88 on Tue Sep 18, 2012 4:42 pm
I got the timing belt and water pump changed with many thanks to RatCav for the very informative guide. I tried to use the Haynes Book of Epic Lies, but it just proved its usefullness yet again. Took the beasty for a quick spin and discovered that in my excitement to start her up I forgot to tighten one of the clips on a boost hose. After cleaning out my seat, i re-attached the hose and tightened it down and now she's all healthy and happy and breathing again.
mudog88
Vehicle Name: Betty
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Sep 18, 2012 4:50 pm
No probs buddy. Its what we are here for.
As for me I replaced all those little plastic clip things that snap over the years and fail to hold the radiator grill on. Got a few off Eblag. Not 100% but after a bit of fettling they proved to do just the job.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Tue Sep 18, 2012 7:00 pm
today i drove foggys fronty home
and on the way i picked up the bearingator
then once i got home, i wiped my wheel off (was just placed on mine with nothing under it) then bolted the bearingator on, then pop
out came my half sharft
now tomorrow i just need to cut the old bearing off and ram the new one on
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrPete on Tue Sep 18, 2012 9:04 pm
Tempted to make a tshirt.. "fudge... forever ramming"
Just sat in mine enjoying a couple of tunes after sorting some internal wiring out I'd messed up, which kept blowing the fuse for the internal lights, clock & keeping the radio working. With a new additional fuse box installed a few weeks back, that'll get another fuse in for my rear work light soon (once I've decided where it's going!)
Need to work out a date for a spanner party too - keep your eyes peeled! :shock:
Don't confuse your books:
Gone but not forgotten...
Comments here
MrPete
Model: 2.0i Sport Niagra 3dr
Skype Username: MrPete_81
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Tue Sep 18, 2012 9:13 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Tue Sep 18, 2012 11:28 pm
Had a walk round an looked at the rusted body work , time i got the grinder and welder out before winter
Took it for its MOT :oops:
Heres the result
viewtopic.php?f=32&t=51389
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Thu Sep 20, 2012 7:45 pm
I did abit of welding on the inner front wing of the Landy. The metal I used was again part of Christine's roof :lol:
This Landy is getting more and more like a frontera each day I work on it :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by wideformat on Thu Sep 20, 2012 9:42 pm
Went to start mine and found the battery was flat, typical
Put it on charge all day and still flat as a pancake after 6 hours of charging, trip to halfrauds tomorrow looks on the cards
wideformat
Vehicle Name: More Trouble
CB Radio.
