Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Mon Sep 10, 2012 9:36 pm
today i had loads of fun
i found out that my rear passenger wheel bearing is shot :evil:
so spent most of the morning trying to get it out
buggered a brake line when i undid that (same one 3 times now)
and i am now in need of the bearingator as well i did order a new bearing today
so i will be having fun on thursday to try and get to my works digs in chepstow wales from lowestoft :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Mon Sep 10, 2012 10:55 pm
If you get real stuck Fudge I think i have just bought another 2.8 shorty thats got some mot left on it, that you can borrow for a week or so...I will find out tomorrow whats happening and when I can get it.
NO ODD WHEELS OR MILITARY GRADE STICK ON STUFF IS TO GO ON IT THOUGH!!! :twisted:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by country_Est on Mon Sep 10, 2012 11:03 pm
Not jt today, but in the last wek,
Met Boxclever and got a new rear wioer Control unit, and a replacement for my bit of broken trim. (Tues)
On Sat got round to fitting them, got the wiper working, fitted the trim, took off the hID upgrade and Fan cut out switch all ready for the MOT.
Just need to do the CV gaitor and should be ready for the dreaded MOT.
Trev
2000 Frontera 2.2 DTi Ltd
country_Est
Vehicle Name: panserbjørne
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Sep 11, 2012 7:19 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by paul01 on Tue Sep 11, 2012 4:49 pm
insured my fronty :dance:
now im off to play :D
paul01
Vehicle Name: ?
Modifications: none
yet :)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Tue Sep 11, 2012 5:58 pm
Parked it on the drive :D, cant play yet as ive got digger n builders comin to play outside :D :D
Looked longingly at it as i walked past it :evil:
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Sep 11, 2012 8:45 pm
Swapped my interior light bulbs for a couple of LED versions. 16 LED's per bulb. Two lights. 32 LED's total. My god its bright in there with them switched on! Just need to find a lens cover for the rear light now.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Tue Sep 11, 2012 10:02 pm
no leaks after changing the thermostat & housing cap so refilled the cooling system with anti freeze
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Tue Sep 11, 2012 10:36 pm
Acquired a 4.3l chevy v6 for the yella fronterror....its basically a 350cu in chevy v8 with a cylinder or 2 lopped off the end...its out of a played with chevy s10 truck, about 200bhp and bundles of torque and not too much nasty electronics as runs a 4 barrel carb up top.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Wed Sep 12, 2012 12:22 am
I desided I should get some pics of the thing...so here it is stretching her springs :)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu Sep 13, 2012 9:33 am
I sorted the the leaking dodgy wrong pipe under the intercooler . Unfortunatly the 2.8 was not in the scrappy any more just the 2.6 mk1 troopers so i took the pipes off a 3.1 . This has cured the oil leak the engine sounds better and seem to run better, had a wee leak from the between the turbo and the intercooler turns out the bolts need a wee nip up.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mickh on Thu Sep 13, 2012 11:54 am
Cured the problem of the always on seat belt light, took the bulb out. Works for me. :)
mickh
Modifications: 2" lift.
Front winch.
CB radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Thu Sep 13, 2012 4:42 pm
Fitted 2 new stickers on my Fronty.
Above both headlights:-
R.I.P Sable!(2005 to 2013)
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Thu Sep 13, 2012 5:26 pm
Drove it all the way to work and all the way home and IT DIDNT BRAKE!!! :dance: :party: :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Thu Sep 13, 2012 6:55 pm
today i removed some crap from mine and put it in fogmans fronty
then, i got him to have a 3 odd size tyres on it :mrgreen:
then i borrowed it to come to wales with since mine isnt in any safe state to be used
so a big thanks go to foggy for getting me to work on time.
that allmost sounds like a song
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Thu Sep 13, 2012 11:29 pm
watched mine getting driven away by fudge :shock:
see you next week anne :cry:
Just wen out and stared it up turned the key and fired first time :D :D
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mickh on Fri Sep 14, 2012 10:34 am
see you next week anne :cry:[/quote]
You hope!!!!!!!!!!!!!!!!!!! :wave: :thumbdown:
mickh
Front winch.
CB radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Fri Sep 14, 2012 12:03 pm
:shock:
