Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sat Aug 11, 2012 10:09 am
Fitted new wheels and tyre's to Chrissy's baby! :| :wink:
:thumbup: :wave:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Sat Aug 11, 2012 1:45 pm
Give my truck the once over ready for next weekends laning :D First time its been started in a month :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john boy on Sun Aug 12, 2012 2:17 pm
Fitted new idler kit at last and adjusted the steering box no longer like a boat :lol: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by carlisletiger on Sun Aug 12, 2012 4:44 pm
Finished the head gasket and timing belt . Blanked the EGR ,bled the coolant system, Then went for a drive- 14 miles and the computer is saying 35.7mpg, up from 29.3mpg.
Dont know if its down to blanking the EGR , but i got a feeling the previous belt was one tooth out , as the engine seemed to be braking if you took your foot off going down hill.
Thanks for all the advice while i was doing all of this :drink:
carlisletiger
Vehicle Name: Tiger
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Sun Aug 12, 2012 5:12 pm
Started getting it ready for wales! :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Mon Aug 13, 2012 12:09 am
While going to work on Monday I had a flat rear tyre at which point I remembered that my tools, 12V pump etc were in the back of the Passat as we had just come back from holiday :roll:
SWMBO came to the rescue with the Passat and my tools only to find out the Frontera jack broke, couldn't pump up the tyre as it was leaking too fasts :evil:
Back home to collect my trolley jack and finally got it rolling.
Had the tyre fixed (was leaking from the bead) and fitted it today, thought I'd give it a quick run just to make sure it was OK and about 3 miles from home the steering got very heavy so pulled over and the bloody front drivers tyre was flat GGGGRRRRRRRRRRR :evil:
Wouldn't have been a problem but my tools, the spare, 12V pump, trolley jack AND mobile phone were sat on my drive back home DOH!!
Lesson learnt and securely hammered home :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gem on Tue Aug 14, 2012 10:40 am
currently listening to the dam alarm going off randomly on Tara .....
Stretch's Wench
Gem
Vehicle Name: Tara
Just turned mine around on the drive....... Good news still starts and drives 8)
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Tue Aug 14, 2012 4:30 pm
Started to remove item from the 2.5 so I can post them
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bowthruster on Tue Aug 14, 2012 4:35 pm
Took the old girl to the garage to check out the over revving,(i'd trying cleaning the throttle body out),to be told i need a new or 2nd hand throotle body,but dont buy one from vauxhall as there very expensive :cry:
Oh well.....better start looking
bowthruster
Modifications: Nothing yet......
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Aug 14, 2012 7:52 pm
Edit: Removed post to another thread
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fronteramac on Tue Aug 14, 2012 8:28 pm
dun the mot failure work and took it back ,passed so i can tax 2moro then back on the road
fronteramac
2.8 td sport sold
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Tue Aug 14, 2012 8:30 pm
Well done :dance: ...how many years did the smoke test put on you mate??? :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by frontlee3 on Tue Aug 14, 2012 9:15 pm
fitted some new fancy number plates and booked it in for the yearly inspection
must get it mucky
frontlee3
Vehicle Name: blue beast
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by frontlee3 on Tue Aug 14, 2012 9:19 pm
must get it mucky
frontlee3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Tue Aug 14, 2012 11:04 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Wed Aug 15, 2012 12:22 am
Removed front bumper as it is looking a little worse for wear, what with writing off a Disco a few years back and embedding it in a rock wall at the Jeep Junkies summer bash this year. Dug out a spare one and built 1 good out of the 2. Painted the centre section, will do the end caps tomorrow :D
Ordered a full set of wheel bearings and seals for the front N/S from Milners and they turned up today, also ordered a replacement steering arm and after a long discussion with the lady at Milners to try and ensure I got the right one, even mentioning that fact that a few peeps on here had been sent the wrong one they have gone and done it again :twisted: :twisted:
Will be back on the phone tomorrow to get it swapped out :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Wed Aug 15, 2012 12:26 am
AND
Finished stripping the P38, most of the bits are on eBay and the remainder will be off to the scrap yard on Friday
Its replacement is doing just fine, everything works, it starts on the button, goes like stink and the 4WD system is doing what it should, nope its not another Range Rover but a 99 plate VW Passat 2.8 4motion Estate, if only RR's were as reliable as a VW :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fronteramac on Wed Aug 15, 2012 8:13 pm
crickey mate didnt know the rangey wud be such a nightmare sori to hear that u ended up breaking it
fronteramac
2.8 td sport sold
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fronteramac on Wed Aug 15, 2012 8:15 pm
fronteramac
2.8 td sport sold
Users browsing this forum: No registered users and 69 guests
