Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Retro Pedro on Fri Aug 03, 2012 11:08 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Aug 03, 2012 11:32 pm
Nice one, post up as if its answered in here we could loose the info and answers for future reference :oh yer: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sat Aug 04, 2012 12:32 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Sat Aug 04, 2012 11:23 am
yesterday i did the rear light conversion. made a lot easier cos i'm removing the rear bumpers to replace with chequer plate so just rerouted the wires :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fronteramac on Sat Aug 04, 2012 4:53 pm
took my brake drums off to fit new cables only to find shoes worn out and knackered cylinder,, just got a price £37 for monday then hopfully fit all of them in good weather throw in for mot then try and find money to tax it if it passes? .dun i pre mot check on it and cant see anything else ? maybe a balljoint on nearside but we,ll see
fronteramac
2.8 td sport sold
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by woodwizzard on Sun Aug 05, 2012 9:44 am
Sold the 2.4 this morning, first time I have been frontyless in 6 years.
I'm just about to go outside check all the fluids etc and see if it still starts then let it sit there for half hour while i watch a dvd inside. :D
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bowthruster on Sun Aug 05, 2012 4:58 pm
Changed bulb in spotlight,and took off air intake from throttle body and cleaned/sprayed with carb cleaner and seems to be a lot better :o ,and unblocked washer nozzles.
bowthruster
Modifications: Nothing yet......
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Sun Aug 05, 2012 5:26 pm
Fashioned an alternator tensioner out of the only bit of steel I had around. A garden gate hinge :lol: Thankfully it only has to last until tomorrow.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sun Aug 05, 2012 5:49 pm
Removed a broken solenoid from a 2.5 starter motor and replaced it with a solenoid from a 2.2 starter motor then fitted it to Bob he now starts first time of the key :D
Then flushed all the oil out of the radiator. I've now listed Bob on eBay :(
I haven't Hidden the fact that it has oil in the water because I've mentioned it in the description
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Sun Aug 05, 2012 6:03 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sun Aug 05, 2012 6:31 pm
I have :butt: read the part ( new items fitted) :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Sun Aug 05, 2012 6:33 pm
No , you read it LOL. It says there is OLD in the water :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sun Aug 05, 2012 6:35 pm
Lol I better change that then :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Sun Aug 05, 2012 6:37 pm
Sorry, couldn't resist :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Sun Aug 05, 2012 7:00 pm
Fixed my radio's case of "Old Man Syndrome" :dance:
Thankfully the coax from the roof antennna has a join behind the N/S speaker so it's a simple job to use a splitter from the CB antenna on the back door. Now using the 5ft CB antenna for reception, rather than the piddly little roof job and I can get all the local stations, better MW, etc.
Unfortunately it does mean I can now get Radio1 again, but you can just push the scan button to go past that :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by brianw on Sun Aug 05, 2012 9:26 pm
Fitted my new AKAI (type ACAC105UC) car radio which has a USB socket and a SD card reader built in so now I can take all my music with me, although it would probably take a run up to John o’Groats and back to play it all!
I used a pair of “choc blocks” or screw terminal blocks to sort out the power wiring; changing over the two wires for the main power and the switched 12 volts on the ISO connector. (Thanks Vauxhall)
If it ain't broke, fix it 'til it is.
Any similarity between prototype and production equipment is purely coincidental.
brianw
Model: 2.0i Sport Niagra 3dr
Vehicle Name: My truck
Modifications: Just a bog standard Frontera Sport in normal road trim!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Mon Aug 06, 2012 9:22 am
yesterday - towed fudge home :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Aug 06, 2012 10:55 am
The body didn't fall off the chassis after his body lift did it Fogman?? :rotfl: :rotfl: :rotfl: :rotfl:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Mon Aug 06, 2012 11:04 am
Na the top of my rad decided it didn't like its self and then snapped
so had no coolant
but now it has fresh coolant in so all good
and last night i went over and gave Dan abduction Pete a hand
when i got there they were just about to separate the box
once i disconnected the electronics from it then we got it apart.
and removed what was left of the bearing and carrier (about 6 big pieces)
then looked at the newer one to find the bearing is on is way out. then i left
so Dan has no fronty at the mo
Users browsing this forum: No registered users and 74 guests
