Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bowthruster on Wed Jul 25, 2012 5:49 pm
Hi,took the fronty to the garage today,to find out what that horrible whining noise is/was,and it its the tensioner....needs a new one,so part ordered,take it back tomorrow morning and have it fitted.
:) Will stop all the people looking at me gone out.....Sounds like a turbine :roll:
bowthruster
Modifications: Nothing yet......
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Wed Jul 25, 2012 6:30 pm
New axle on and fitted at long last :dance: :dance:
I need the truck to tow the caravan down to Devon in a couple of weeks for our holiday but due to some pretty extreme laning antics the bodywork was knackered and the truck was looking a bit sorry for itself :|
Thankfully Dave has a mop , so I got some G3 and he got cracking ....
Resulting in the following :D
Cracking job mate, well done ! :drink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Wed Jul 25, 2012 9:36 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu Jul 26, 2012 12:13 am
Got to use the air con :D was beginning think was there any point having with the weather of late
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Thu Jul 26, 2012 8:38 am
Your aircon still works after 22 years :shock: :shock:
Mine fell apart, so I ripped it all out. Should of fixed it now in hindsight :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dingal2000 on Thu Jul 26, 2012 1:47 pm
nothing but hoping i'll be able to fix a great deal more if i get the news i want :)
dingal2000
Vehicle Name: Betty Beast
Modifications: None what so ever just yet due to everything needing fixing first
Skype Username: dingal2000
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bowthruster on Thu Jul 26, 2012 4:18 pm
Picked up the fronty from garage with new cam belt tensioner,no whining just engine noise! :D :D 8)
Oh and bought a cover for the spare tyre
bowthruster
Nothing but told the mrs how to use the climate control :roll:
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Fri Jul 27, 2012 1:04 pm
today i removed my old crappy speckers and replaced it with some edge ones
and i got the normal 4" ones for the front
but the back i got these
god they sound good
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Fri Jul 27, 2012 4:10 pm
They'll need some fettling, no??
Don't doubt they sound good though, really must get round to pouring the Focal kit into Sophie.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Fri Jul 27, 2012 4:40 pm
well they were the same size as what i had in there, but still needed about 5mm taken off
and they sound alot better than the ones i had in there
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Jul 27, 2012 7:17 pm
Probably because the old ones are 14 years old and full of mud :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Jul 27, 2012 7:18 pm
Not mine, but fitted a rear axle to a 2.2 LWB .
Getting good at these axles now, lol
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Fri Jul 27, 2012 10:40 pm
Well Si i just hapen to have my LSD axle i want puttin on mine from the trailer! HOW YA FIXED????? :mrgreen: :wave:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Jul 27, 2012 10:54 pm
-45 mins to remove, 1.5 hrs to refit. If u can get it up here I'd more than happily do it for ya bud - even though you are more than capable of doing it much quicker than me ;)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Sat Jul 28, 2012 1:14 pm
That's a point Rob, where was the trailer last weekend??
Woulda got some pointers on how it was done if I'd been able to see it :?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bhcalcutta on Sat Jul 28, 2012 4:51 pm
Took the rear diff pan off, gave it a damned good cleaning and repaired the 3 holes in it with chemical metal. (only a temp fix till i can get a new regulator for me welder)
bhcalcutta
Intek CB
Kenwood head unit
wound up torsion bars
monroe adventure front shocks
avm manual lockers
Modified TLC80 Snorkel
Trooper clutch
flappy paddle delete
egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sat Jul 28, 2012 8:02 pm
today i won some more wheels :roll:
just have a look, they are a little different
http://www.ebay.co.uk/itm/300745829051?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_500wt_1156
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Sat Jul 28, 2012 8:43 pm
Bit of a "meh" evening's fettling with Sophie tonight...
Finally had enough of the factory radio and it's Old Man syndrome, so whipped out the bullet connectors and Alpine head ready to swap that in instead. Suitably stunned on removing the factory radio though, to find a completely virgin wiring loom, first time even on a 2nd hand car :shock: No botched jobs or taped up wires, I didn't have the heart to start playing silly buggers so I left it as is, I'll get a proper connector for it tomorrow.
Bit miffed that one of my speakers seems to have had it though. Hooked my collection of Focal 6.5" stuff out of the loft and tested them to find that one of them was not making any low-down noise. Suppose I can't complain too much given the age of em, but they'd have been great in the Fronty. No point putting brand new top of the line kit in a 2.8 :lol:
Wonder if it's fixable......
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sat Jul 28, 2012 8:55 pm
