Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sat Jun 30, 2012 4:04 pm
:lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Sat Jun 30, 2012 5:06 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Jun 30, 2012 7:04 pm
Well, I have been soaked all afternoon, but got another wobbly head lamp sorted and the new handbrake shoes fitted, one bugger was a very seized adjuster but a good soak (like me :grumpy: ) and a bit of force sorted it.
So now got good handbrakes :D
I repacked the bearings this morning before the MOT as usual.
Only the steering idler to fit when that arrives and the retest Saturday :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 2much on Sat Jun 30, 2012 7:46 pm
all rear suspension and bits done today;
- OME912 Springs off the Frog
- +4 Rough Country Shox
- Spring retainer clamps (as ever, to the Drift model)
- Dislocation cones
- Relocated brake pipe T piece (raised ~2")
- Relocated bias valve bracket (raised ~2")
Also new F.Off Numax battery - took some jiggling to get to fit and then wired up winch - wireless works but wander lead doesn't :cry:
Now looks like a Dragster with its arse in the air :oops:
2much
Modifications: 2much!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Sat Jun 30, 2012 9:35 pm
Picked up my new pads which will be fitted when it stops raining!, also took one of the spare set off stars down to my mates garage with its new friend! a 33"12.50/15 marshall venture tyre :thumbup: , they had a very successfull mateing and look very nice together now :dance: , just got the other 3 to do now n get them on the truck, might need a bit of a bodylift to allow them to be free but my god doesnt that wheel look awesome on the truck!!!!! :v happy: 33"s mmmmmm :v happy:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sat Jun 30, 2012 9:40 pm
3.1 engine swap finally finished :dance: :dance: :dance:
Pump timing sorted (well pretty close anyways), front of the engine back together, injector pipes on, couple of water leaks sorted out and off for a test drive.
Huge improvement over my 2.8 (admittedly it was getting a little tired), boost kicks in really early and its hitting max boost at a tad over 2000rpm, pulls like a train :dance:
Will be hanging on to the 2.8 engine for now, not sure whether to rebuild the 2.8 and eventually put it back in or stick with the 3.1 and get another 3.1 to rebuild
Was reading through the factory manual and it turns out the crank is nitrided and cannot be reground as undersize bearings are not available :o
What you didn't do to your truck today! by brianw on Sun Jul 01, 2012 12:31 am
Hi all
This is just a bit of a "Grrrr" at the way that the Fronty is built, unlike some vehicles which seem to be thrown together.
I thought I'd update things a bit with an electric blue dashboard lights mod. Read everything I could on this forum about removing the instrument cluster, then I got the "pains" manual out to find out about the other silly little lights like in the heater control panel, the cigarette lighter and the one above the ashtray, and after reading about that I can't decide which would be easier ... pull everything out of the interior or just remove the bodywork!
Ho, hum ... discretion being the better part of sanity, I think I'll leave it until blown bulbs force me into taking action.
Regards, Brian
If it ain't broke, fix it 'til it is.
Any similarity between prototype and production equipment is purely coincidental.
brianw
Model: 2.0i Sport Niagra 3dr
Vehicle Name: My truck
Modifications: Just a bog standard Frontera Sport in normal road trim!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JEOH on Sun Jul 01, 2012 5:32 pm
HI,
"GodZilla" Frontera got a little clean-up inside and some final work according the electricity. Then I did change the cross-joint-articulation...
No, not at the Frontera's drive shaft!
Backup car "Jaques" (Fiesta GFJ 'Calypso' 1992) had a failure of this steering element so it was hardly to drive. Now it's fine again :dance:
Kind regards,
Sorry for my pigeonenglish.
JEOH
Vehicle Name: Gentile
EX-GIGANTE (1998) 2018-2022
General Grabber AT2, Soft-Top
G-Wagon Mercedes 300GE 1990
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sun Jul 01, 2012 5:35 pm
Not sure how or why but the truck seems to be silky smooth on the road today. Only gave the engine bay a quick blast with a jet wash. Only things that seem wrong atm are the whiny rear axle and a squeaky rear seat back both of which are more annoying than anything... but seems a good excuse to turn the tunes up :D
So this is the calm before the storm I bet....any bets on what's about to go bang? :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Sun Jul 01, 2012 7:13 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mickh on Sun Jul 01, 2012 7:47 pm
Spent 20 minutes jet washing all the mud off and another hour cleaning the drive and unblocking the drain. :evil:
mickh
Modifications: 2" lift.
Front winch.
CB radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gem on Sun Jul 01, 2012 9:02 pm
brought it a little brother lol
cebs been working today carting water to a new horse field while his little brother was driven home. talking of which, need a name for little brother :idea:
Stretch's Wench
Gem
Vehicle Name: Tara
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jonnyjeep on Sun Jul 01, 2012 10:10 pm
Finally got round to replacing to fuel pipes and painting and undersealing the chassis and floor. 1more step closer to the MOT :) :) :) :)
jonnyjeep
Vehicle Name: project20
Region: Northern Ireland
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sun Jul 01, 2012 10:37 pm
Got some instant gasket for between the intercooler and waste gate running better no hissing /whislting little less blue smoke aswell :?:
Yesterday I did a 425 mile round trip to gatwick airport to pick the father in law and his mate up cause they missed their flight to Manchester last week :evil:
On the up hand the truck sailed sweetly and I only used just over a quarter of a tank :shock: :lol:
Obviously my speed was 70 mph (+-20mph :twisted: )
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Oh yes and I washed it again this morning as couldn't sleep :roll:
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Mon Jul 02, 2012 1:41 pm
Think i finally may have stopped burning oil
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Mon Jul 02, 2012 1:44 pm
425 miles on just over 1/4 tank? Were u on the back of a recovery truck most of the way? I just got 320 miles from £65 or derv (about 3/4 of a tank)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Mon Jul 02, 2012 4:34 pm
It's a B series Dan, as you know the guages dont work properly :lol:
Well , I pulled out both rear half shafts and the LSD
I then removed the cross members, gearsticks, gaitors, props and rad and started removing all the gearbox bolts to fit the new clutch. Not fun when it's hissing down with rain. I stopped when the water started sloshing round my meat n two veg.
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
