Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Jun 27, 2012 8:41 am
Easy Dan ... she will have a heart attack with all that cleaning :wtf:
Yaki
That does sound like the early non-intercooled inlet off the Trooper 2.8. The branches are almost square in shape from recollection. Does the bonnet have a scoop. In which case it should have a TMIC. You will be losing power if not. Any 2.8 and 3.1 TMIC should just bolt on. Just remember to get the mount brackets as well. Also you might need to rotate the compressor housing snail on the turbo to get the hose from the turbo to intercooler to line up.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Wed Jun 27, 2012 8:53 am
took my egr valve off as been a bit smoke to find it jammed shut and rattling so poked it open with a screw driver gave ti a good clean but still does work so now looking for a replacement
AskDean
Skype Username: askdean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by frontlee3 on Wed Jun 27, 2012 11:44 am
used it to stand on its roof to get some pics of the olympic flame outside my house
Image :dance: :dance:
must get it mucky
frontlee3
Vehicle Name: blue beast
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Wed Jun 27, 2012 4:30 pm
Started to weigh in Christine so she will be food can soon :lol: as I didn't have a car trailer I've had to cut her up so I can weigh her in. But I'm having fun doing it :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Wed Jun 27, 2012 6:38 pm
Got it a replacement caliper, well a pair, off Horses45, so il get that on at weekend. Cheers Rob :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Wed Jun 27, 2012 9:34 pm
Just bought triggers broom some new handbrake shoes :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Wed Jun 27, 2012 9:59 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Wed Jun 27, 2012 10:02 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Wed Jun 27, 2012 10:03 pm
Not done anything today apart from ring round a few sources to see if I can track down a 3.1 injection pump
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Thu Jun 28, 2012 12:35 am
Go-Kart (MX5) not the truck...
Rad out, front covers off, cam belt & bearings off, water pump off and in the bin. New oil seals to the crank and cam shafts. New water pump fitted, new cam belt and bearings fitted, front covers back on, rad back in.... And the battery was flat so no starty. Will jumpstart it in the morning and take it for a run later to charge it all up.
Started at 21:00 and just finished now, 00:34.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Thu Jun 28, 2012 8:23 am
took my egr off again and soaked it over night in wd40 and then used a torque driver to move it side to side to cean the dirt of the shaft and then go ti working normally again so now back on the car just need to sort out the o2 sensor error i now have on the dash after going in deep water so need to take it off and check the wires lol as i think one may of got a short on it
AskDean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by adyclemo on Thu Jun 28, 2012 1:12 pm
Used it to drag a guy and his Alfa 156 out of a ditch :dance:
Regards Ady
Comment on the motor here
adyclemo
Full lenght roof rack.
Front tow bar.
CB.
Manual locking hubs.
Suspension lift.
32" BFG's
Snorkle.
Egr delete
Took it through as many puddles as I could find. Especially ones that were more like fords than puddles :mrgreen:
Unfortunately the car got covered in fecal matter as bromsgroves sewers overflowed, not a nice smell :oops:
Still fun though :lol:
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mickh on Thu Jun 28, 2012 8:10 pm
Got a spare tyre from Foggy about 18 months ago, Bobbins put a wheel aside for me about 3 months ago, which I collected a month ago and today I mated them together. Not like that you pervy ones. I now have a spare wheel to keep in the garage and never have cause to use with a bit of luck. :dance:
mickh
Modifications: 2" lift.
Front winch.
CB radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Thu Jun 28, 2012 9:28 pm
Whilst masquerading as a power press engineer I managed to fit my 4 new Rough Country shocks and cut off all the rotten brake disc guards(s$%t catchers) and bled the brakes. A new track rod end to fit tomorrow and all ready for the MOT :D
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Thu Jun 28, 2012 9:37 pm
Today where i live in bromsgrove was really badly flooded :mrgreen: Thought great not a problem i have my truck :D
Jumped in the truck and it started on the button as always. I then went to pull away and i have two seized calipers :twisted:
As i had to go out i jumped in my daily drive (Peugeot 307) and ended up fording it as everywhere was so badly flooded :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Thu Jun 28, 2012 9:59 pm
blimey Ste, it's been boiling here today :?
It has here too in between all the rain.
Ste was lucky his end was water the end I was was sewage.
Gotta love English weather :lol:
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Thu Jun 28, 2012 10:09 pm
Hundreds of houses around bromsgrove was completely flooded out including my sisters house :shock:
She had 4 foot of water in the house and completely wrecked it.
I have never seen a storm like it in the uk. within 10 mins of raining there was rivers running down every road by me :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Thu Jun 28, 2012 10:18 pm
Blimey, that looks worse than that I experienced back in 2007 (Stoke Prior)
Yes, that's the canal in the background - risen about 4'
