Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Fri Jun 01, 2012 9:43 pm
picked up a new set of wheels and tyres (shogun) 31.1050.15 bfggoodrich all terrain all for £122
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Fri Jun 01, 2012 9:56 pm
today i did nothing to the car.
but i have got all the bits out for tomorrow
2x upper ball joints
2x lower ball joints
2x front wheel bearing sets
2x manual locking hubs
2x new front brake pads
2x new brake hoses front
1x new winch webbing (replacing the steel rope)
1x redwinch fairlead
1x stainless mesh
so tomorrow will be to fit all of it :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Sat Jun 02, 2012 7:57 am
not mine but imgoing to help fudge fit the above very soon - HIDE YOUR PHONES :butt:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sat Jun 02, 2012 1:01 pm
might attempt to refitt bumpers and wire towbar or do some welding on the wee trooper
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by chrispynuts on Sat Jun 02, 2012 1:36 pm
overhauling the turbo today, going to start on replacing the clutch tomorrow and when the gearbox is out going to fix the oil leaking from the gear box into the transfer box. with any luck it will all be back together and running for next Saturday. lol.
To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be.
chrispynuts
Vehicle Name: Silver Fella
Modifications: 2"lift with Isuzu Springs @ rear + koni shockers
255X70 General tyres
270,000 miles and on third fuel pump
replaced all fuel lines and all Vacuum pipes
replaced fog lights with 5" headlights (gives me main & dip)
fitted soft nudge bar and spotlights
stage 1 engine remap
Region: Northern Ireland
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sat Jun 02, 2012 3:54 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sat Jun 02, 2012 5:32 pm
today me and fogman attempted to change the balljoints and failed.
we got 2 off then buggered the new balljoint splitter :oh yer:
but luckly it was the 2 bad ones, the other 2 are still in ok condition.
so this morning i changed
2x front wheel bearings
1 upper balljoint
1 lower ball joint
since the brake pads are ok, i didnt change them.
then this afternoon i went to work on the front winch and put me new webbing rope stuff on it, and the redwinch fairlead
then went to work on fitting the mesh around it. so it now looks like this
so now looking soooo much better :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Sat Jun 02, 2012 7:24 pm
nice bungy strap :wink: i used to have 1 like that :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Sat Jun 02, 2012 7:27 pm
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Sat Jun 02, 2012 7:57 pm
done bugger all to the fronty today..because the battery is flat...
but, I did get the father in laws Focus through it's MOT with no advisories..did have to get four new tryes and a set of wiper blades for it mind, also while I was at it I gave it an oil change and a fairly harsh blast down the motorway. Turns out that the rear tyres were either the originals or a replacement set for them, cracks all the way down to the cord I could even peel chunks of tread off them..the car is a 51plate! inside of the bead and wheel rim were pristine..suprised that they hadn't been spotted when he was pulled for speeding a couple of months back..oh forgot he's going to be 80 next month, and has more points than me..lol.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sun Jun 03, 2012 10:30 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Sun Jun 03, 2012 12:41 pm
there is a good 2.5 engine and box near me do you want me to make enquireis as to cost etc.
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sun Jun 03, 2012 12:44 pm
or have a word with greg i hear he is splitting his 2.5
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sun Jun 03, 2012 4:18 pm
Andy did u check the old head gaskets to see if they were actually blown?? that might shed some light on if the block/head(s) are buggered or if somthing went wrong when u put it all back together :P
Yesterday I did the axle swap on my black dti....wasnt too hard to do...was at it for about 7 hours yesterday in total. today if the rain stops all I have to do it reconnect the drivers side handbrake cable, fit the disks/drums fit calipers and bleed the brakes.....oh and bolt the prop back on....then tighten all the drop link bolts with it sitting on level ground with its wheels on.
Have to say tho...not a easy job to do on your own but not impossible, and helps if you have more than just 2 axle stands because both of mine are stuck under the blue dti atm so I had to use both the bottle jacks out of the trucks for the black dti and the trolly jack to lift and maneuver the axle around. Oh and a tip for any1 else trying to remove springs....dont loose your rag with it and kick them out like I did because one of the compressors pung off and made it VERY hard to get a banana staped coil spring back onto the car.
Some pics I took:
Buggered....
Easy pring to get out...just undo the shock and drop the axle and the spring more or less drops out :)
Old axle by the bush, new axle waiting
And a hovering fronty :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Sun Jun 03, 2012 4:57 pm
just got back from modified nationals 10 anniversary at the Peterborough show ground took my oldest son for his birthday treat so stayed friday to sunday camping lol
saw nice new alloys for rob
and this morning before leaving i had breakfast alla fronty due to the rain
https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash4/282342_3046404289143_616743958_n.jpg
AskDean
Skype Username: askdean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sun Jun 03, 2012 7:47 pm
any more pictures
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sun Jun 03, 2012 8:27 pm
Got it muddy down the woods at the workday...big offset rims make my 2.8lwb change colour from black to brown in about 2 seconds if the wheels spin! :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Sun Jun 03, 2012 9:25 pm
AskDean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Sun Jun 03, 2012 9:29 pm
AskDean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sun Jun 03, 2012 10:29 pm
Thanks for the offers guys but I don't have the money to get a new engine or to repair this one :thumbdown: so I'm just going to carry on driving it until it blows up :lol:
