Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sun May 27, 2012 10:16 am
so far today i have aquired another winch(superwinch for £10)
and went to an autojumble and found a LED work/flood light for £5
:lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dingal2000 on Sun May 27, 2012 12:23 pm
a good tidy up inside and fixed a crack in the back bumper
dingal2000
Vehicle Name: Betty Beast
Modifications: None what so ever just yet due to everything needing fixing first
Skype Username: dingal2000
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sun May 27, 2012 1:53 pm
Have bled the brakes hoping it wil cure my brake issue afater doing an emegenct stop cause some dickhead paramedic jumped the light with no siren i slammed the breaks on and it took nearly two car lengths to stop at 30mph.
Now to test drive while im out today
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by frontlee3 on Sun May 27, 2012 4:15 pm
must get it mucky
frontlee3
Vehicle Name: blue beast
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sun May 27, 2012 4:18 pm
well that will then be my 3rd one
i have
a rep8000 ramsey (cost 130)
a rep5000 ramsey (cost 56)
and now a 2500superwinch for 10er
oh and some winch webbing (insted of rope) this weekend for £50
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sun May 27, 2012 10:12 pm
Tried brakes still wont do an emergency stop :x
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Sun May 27, 2012 10:56 pm
During the week I have brush applied waxoyl to most of the accessible parts underneath. Hopefully this dry hot weather will continue and with the aid of the compressor I can inject more of the stuff into the hollows of the chassis rails and hard to get areas.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jimmybhoy on Sun May 27, 2012 11:27 pm
Re-did all the back windows Limo Black. :mrgreen:
jimmybhoy
Registration Year: 2004/04
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Mon May 28, 2012 8:13 am
Drove it to the petrol station and treated him to £50 of fuel!!! Oh he did smile, i could tell! :lol:
Well I finally decided to clean all the scratches off from strata :oops:
One of the better jobs I have done if I do say so myself :D
Gotta put more oil in it today as I forgot to do the drain plug up the other day :oops: :roll:
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Mon May 28, 2012 12:11 pm
This one's a hangover from Saturday, as I've not been on the forum since; the timing belt & tensioners, plus alternator and PAS belts were changed on Sophie.
Definitely worth doing, too, quite aside from the service book stamp saying it was done 10 years ago, when the rollers came off for replacement they were making some nasty noises :shock:
For this though, HUGE THANKS are due to Snapper for his time and energies on the project.
Frank very kindly offered the use of his drive for the job as he was planning on doing his too, so I could watch and ask stupid questions as required while doing mine.
As it turned out though, his bits didn't arrive in time so it was just mine done, with Frank doing the bulk and me playing apprentice / tool passer.
Thanks for Saturday bud, the truck is running just lovely and at least one odd noise from under the bonnet has gone (still sounds like a sack of spanners though, really must work out why at some point :lol: )
Proof of the pudding was in going back to Southampton via Gloucester and Salisbury when I visited CheekyChick and didnt fancy the motorway on the way back.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Mon May 28, 2012 1:33 pm
took my truck into get the air con re-gassed after fitting a new air con pump to find the pipe from the condensor down to the rad had been rubbing on the chassis and it had sawn half way through the pipe. so had to pull the grill forward to get to the pipe and them pull it out and get it welded. then put it all back together and tested it re-gassed and running cold as ice now an only cost £60 including the re-gas and pipe welded.
cracking job by http://www.autosupplies-nottingham.co.uk/air-conditioning
AskDean
Skype Username: askdean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Mon May 28, 2012 7:31 pm
No problem Jim, it was a good day and I'm glad it actually made it all the way home!
Roxy helped too.... Just look at those spanners, spankers they were, no sign of any grease, muck, use.... at all :lol:
In true FOG tradition, some red-neck engineering was carried out, a technically weighed stack of bricks and a ratchet strap was used to tension it all up.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Mon May 28, 2012 8:11 pm
i found out my oil leak has returned wishing could same for my brakes
Driving down my grove and one of the misfits drove a mini moto in to the front left wheel of my truck..
Damage to truck..... Nothing :D
Damage to mini moto..... Fooked, snapped forks split frame and a broken wheel :D
Look on the kids face....priceless :lol:
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Mon May 28, 2012 8:21 pm
:ttiwwp: its near as i could see lol shame no pics
AskDean
:oops:
Sorry I forgot, at the time I was worried about damage-to the truck obviously.
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue May 29, 2012 6:25 pm
New power steering belt and alternator belt. Was no where near as difficult as the one we did at the annual on Bobbinsjobs 2.8 funnily. Belt just slipped straight on. Also meant I have the right length belt on the power steering pump as the one I had was for an air-con version. They are longer so had to redneck a fix for it. Now its all back to how it should be.
Talking to the guy at the parts shop he pointed out the belts for these engines are extra heavy duty bringing them to agricultural/commercial standard.
Also noticed the fitting for the power steering pump hose was leaking (well it has been for ages, but thought I should do something about it today)
This is the fella:
Took it out and changed the o'rings. Looks like problem solved. Well done cheap Rolson o'ring set I got years ago "just-in-case".
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by davenlin on Tue May 29, 2012 8:17 pm
got mine through it's MOT , might put him up for sale now not sure yet, don't want to but needs must. :( :( :(
RDH Graphics & Decals
davenlin
Modifications: none yet
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Tue May 29, 2012 10:48 pm
con grats on the mot chap
went out and gave mine another wash today and then got ot the autoglym and gave it a polish
starting at the front
finishing like this at the back
before i got carried away and did this
some times the truth is hard to hide lol
AskDean
Users browsing this forum: No registered users and 55 guests
