Just taxed the begger ........Ain`t computers brill :D :D :D no queuing up with the grannies in the postie:)
pot bellied pixie
Modifications: Now deceased.
Gone to the dark side a
black shogun sport equippe.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Tue May 22, 2012 3:45 pm
in the middle of the mnth!? :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Tue May 22, 2012 5:19 pm
What do you mean, middle of the month? It's only a week or so 'til June.
Anyhow, as long as you're doing things after the "don't apply before" date, you get a disc for next month unless you say otherwise.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by frontlee3 on Tue May 22, 2012 8:18 pm
changed a track rod end and checked the timing belt to find its a tooth out :evil: and now reset it back to how it should be :D
must get it mucky
frontlee3
Vehicle Name: blue beast
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Tue May 22, 2012 10:19 pm
Fitted replacement brake servo as i popped it at the annual and had to drive back up the M1 on the handbrake! :oops: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu May 24, 2012 3:19 pm
I washed the bighorn an bought a new oil filter and oil just need to get round to fitting it got too much too do
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Fri May 25, 2012 12:15 pm
Well not yet but will be later. I'll be making a start on the head gasket it's going to be fun . :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Fri May 25, 2012 3:50 pm
Put the swb coiler on Ebag! If anyones interested in it drop me a pm, its the one i did strata in. :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri May 25, 2012 6:21 pm
Please dont advertise here :wink:
Danny stick it in the for sale section mate :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by ttphoenix on Fri May 25, 2012 9:21 pm
No central locking on rear door (for months haha), so,
Removed the rubber conduit from rear door to main shell to find a broken wire
...after a quick solder and insulation tape repair, bingo - rear central locking back to life :)
A wise man speaks because he has something to say, a fool because he has to say something
ttphoenix
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by cheekychick on Fri May 25, 2012 9:53 pm
Put him on charge, it's not looking good :(
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Fri May 25, 2012 10:47 pm
From 2:30 this afternoon until 9:15 tonight I was striping the cylinder head's off Bob. About 3 hours of that was trying to undo two bolts from the exhaust manifold in the end I had to remove the turbo. Whilst I was at it I removed the starter motor I have a new one to fit. Then started cleaning up the cylinder head's and water pipes.
Tomorrow I will be putting all back together I just hope it sort's out the oil in water.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Sat May 26, 2012 9:22 pm
after taking a run over and meeting Ian and his good wife in there 2.8 on the long drive north to drop off fudges alternators off rob, i went on a killing spree down a country lane as by the time i got back i had half of Nottinghams insects plastered over the truck so had to give it a was as couldn't safely see out of the window and then decided that after a year i would finally wash the last of the pit sludge from the engine bay
AskDean
Skype Username: askdean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat May 26, 2012 9:28 pm
I accidentally cleaned the wing mirror by brushing past it this afternoon on the way to the pub :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Sat May 26, 2012 9:32 pm
thats shocking drift :shock: i hope your ashamed of yourself :D
picked up a fence post in mine :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sat May 26, 2012 9:50 pm
i cleaned and waxed mine again
ohh and got some new winch rope sorta thinngy comming :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bazzasglovers on Sat May 26, 2012 9:52 pm
Removed the roof etc and went for a COOL drive!!!!! :D
bazzasglovers
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sat May 26, 2012 10:02 pm
changed the oil an had to buy a new filter the one i got for a 2.8 the thread was narrower got one that was for a 3.1 . Fixed oil leak
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Sat May 26, 2012 10:07 pm
Bazza, you should have joined us at Hinkley for a spot of laning, had a good day out.
Regards
Stuart
PS just jet washed the big bits of mud off while fueling up at Tesco. They do say you can get anything at Tesco's, well now you can also get mud, cause I left mine there.
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by ttphoenix on Sun May 27, 2012 9:20 am
(Yesterday - too late to post it up!)
Fitted new Water Pump, Timing Belt and Aux Drive Belt :dance:
ttphoenix
Users browsing this forum: No registered users and 55 guests
