Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri May 18, 2012 11:14 pm
Nice one drinks. Need to get a couple of those.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat May 19, 2012 8:03 am
Up early in preparation for Banshees dreaded annual medical (read MOT).
Fingers crossed lads.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sat May 19, 2012 8:12 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Sat May 19, 2012 8:17 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sat May 19, 2012 1:48 pm
and my new rear bumper is done, fitted and painted
:dance: :dance: :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat May 19, 2012 4:44 pm
Took her for a spin to charge the battery up, sussed the passenger side front brake was binding :roll:
So off with the wheel, then the slider, top one fine but then the bottom slider bolt wouldnt budge, and you just now its going to snap....and snap it did :evil:
So whizzed it off and toddled to my shed, checked the brake parts bin and yup you guessed it, a spare caliper carrier and slider bolt was in my brake parts bin :dance:
So just need to wind back the piston and grease up the sliders and reassemble :thumbup:
It pays to be a hoarder :angel:
Ste I had that happen on my last truck ,I just soaked it in wd40 for a bit then drilled a hole in the correct spot to get a punch in to drive it out .I then blocked the hole with a rubber bung and it lasted till the truck died..I still have it in my mates lock up :D
pot bellied pixie
Modifications: Now deceased.
Gone to the dark side a
black shogun sport equippe.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat May 19, 2012 5:46 pm
drove it to pick up a new starter motor. then spent this afternoon search ebay for a bigger set of wheel & tyres no luck as yet :(
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat May 19, 2012 6:41 pm
All sorted, though think it may need a new caliper :roll: it keeps sticking
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Sat May 19, 2012 6:55 pm
Moved the number off the grill to a proper mounting point just to keep mr policeman happy.
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat May 19, 2012 8:31 pm
Well done drifty. Probably find you just need a new seal and repair kit to sort it.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat May 19, 2012 10:03 pm
Found an old caliper after a bit of ferriting around in the shed so will treat the to the kit I have had in the shed for a while :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat May 19, 2012 10:08 pm
Bit of grafting with a wire brush and some wire wool, and your done then.
Not today but over the last week or so,
2 new drop links - nice gold ones :D
2 new top ball joints - now flipped :D
1 new outer cv joint -OS
1 new inner cv joint -OS
1 new driveshaft - OS :evil:
1 new interior - complete leather kit with door cards oh and the fronts are heated :twisted: :dance:
Cut some of the panels so they are completely scratch free and good wax :mrgreen:
Later today will go with fuel filter and oil and filter change.
What would normally get changed at the 120,00 mile mark? Not there yet but might as well pick the stuff up for it.
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Sun May 20, 2012 8:25 am
you have to be a bit careful when changing the fuel filter on the dti dont you ?
Nah not with changing it, just with starting it afterwards making sure you either bled the fuel through to the rail or get no air in there to start with- there's a little how to on here I followed the first time I did it and it works a treat :D I'll find the link in a min.
viewtopic.php?f=41&t=21801&p=246972&hilit=Diesel+fuel+filter#p246972
Found it :D
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun May 20, 2012 6:57 pm
I refurbed a couple of old calipers this afternoon :thumbup:
viewtopic.php?f=41&t=49791
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by frontlee3 on Sun May 20, 2012 9:51 pm
fitted a blue led interior light to match the truck colour :dance: just waiting now for the blue dash bulbs to turn up and change them too :tuble:
must get it mucky
frontlee3
Vehicle Name: blue beast
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Mon May 21, 2012 12:47 pm
just fitted new air filter as not allowed to go off roading any time soon lol
AskDean
Skype Username: askdean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jimmybhoy on Mon May 21, 2012 4:27 pm
Pealed off all the window tint & fired it in for a valet, will re do the tints when it comes back tomorrow.
jimmybhoy
Registration Year: 2004/04
Users browsing this forum: No registered users and 55 guests
