Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Mon Apr 30, 2012 7:43 pm
good idea..i like that one, just like cleaning a penny..cheers mate
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Mon Apr 30, 2012 8:03 pm
That sounds like last time if i remember right Jon, she threw you out!!!! :axe: :thumbup: :wave:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by coops555 on Mon Apr 30, 2012 8:05 pm
well took it wading today for the first time through the floods :) was a big worried as its a 3.2 petrol but went through no probems and chuffed to bits as the only non landrover getting through. Was going to ask how good they are at wading last night but forgot so thought i best find out the intresting way lol
coops555
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Mon Apr 30, 2012 8:09 pm
Cops just be careful bud your air intake is behind the head light, :thumbup:
John if it doesnt pass I can give you a lift mate, save you the juice money :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dingal2000 on Mon Apr 30, 2012 8:12 pm
finally got around to doing the back wing :)
dingal2000
Vehicle Name: Betty Beast
Modifications: None what so ever just yet due to everything needing fixing first
Skype Username: dingal2000
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by coops555 on Mon Apr 30, 2012 8:19 pm
its just a standard 3.2 the air box is behind the head light and goes into the wing i think. Water was no where near the headlight dept maybe just above the floor. Took my freelander through loads in past so thought if that can make it frontera should be fine :)
coops555
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Mon Apr 30, 2012 9:25 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Mon Apr 30, 2012 9:32 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rospicer on Mon Apr 30, 2012 9:35 pm
Is it all done then? do we get any pics? :D
SHE MUST GET BIGGER BOOTS
rospicer
Vehicle Name: COMING SOON
Skype Username: spicechop
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Loneranger on Mon Apr 30, 2012 9:40 pm
Got 6 months road tax.....yipeeeeeeeeeeeeeeee
Dreamt of having 33's
bid of bodywork sculpturing would be required though.
Loneranger
2 inch suspension lift
2 inch Body lift - pending
33" KL71 mud tyres
winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Mon Apr 30, 2012 9:52 pm
Went to work in it :thumbup: cos ive sold my gti :cry: Its still filthy from strata tho! :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Mon Apr 30, 2012 9:54 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rospicer on Mon Apr 30, 2012 9:59 pm
Dam, I think he want to unveil it at the annual :( I might not make it, well at least there'll be loads of pics :D
rospicer
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Mon Apr 30, 2012 10:03 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Mon Apr 30, 2012 10:21 pm
Here's what 35" look like fitted properly!!!
This is Manny's truck. 80mm body lift. Suspension lift being done shortly.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Mon Apr 30, 2012 10:26 pm
I WANT!!!!!!!!!!! THAT LOOKS AWSOME!!! :shock: 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Mon Apr 30, 2012 10:43 pm
It is Danny and its a 2.8. Pulls like a train!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Mon Apr 30, 2012 10:44 pm
MMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Mon Apr 30, 2012 11:19 pm
Did an oil and filter change last night, between rain drops.
Today, I swapped the old bull-bar for a better (not twisted) one I've had kicking round the garden for about 8 months. Decided where the recovery points are going and made up some plates to beef up the front locations, drilled out and threaded the bolt holes and bolted them in, that bull-bars going nowhere unless the front of the car falls off with it. Going to drill out the holes on the bottom of the bull-bar for the front shackles tommorrow and same for the rear once I get the mounting points in the post.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by woody13 on Tue May 01, 2012 2:13 pm
Very nice,my kinda bus... :twisted: :mrgreen:
woody13
Vehicle Name: Anvil
