Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sun Apr 22, 2012 9:57 pm
That just looks like a heat shield, bent at the bottom (sit on top of the block) and another formed dent on the top edge that quite possibly lines up with some pokey out bit on the head, and they have stuck the four individual exhaust manifold gaskets to it as an aid to getting the things easily lined up during re-assembly.
Don't forget to replace all the studs when putting it back together along with the nuts.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Retro Pedro on Sun Apr 22, 2012 10:08 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sun Apr 22, 2012 10:21 pm
I have a Milners one on mine. I cut a notch in that flange to give me room to get spanners onto the manifold bolts. Never had an issue. Though I noticed I have a missing bolt (bottom right) Those ones always fall out.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Spike on Mon Apr 23, 2012 11:35 am
Stripped off all calipers, unsiezed 2 of them, and replaced with new pads all round.. Still sitting on axles stands deciding what set of wheels and tyres to buy for it....
Spike
Modifications: 2" + Landrover Springs on rear.. 2" lift on Front.
235/75 x 15" Recip Tyres all round 80% mud, 20% Road
Light bar on roof, 4 front facing spots, Wired to come on via full beam via switch 2 rear facing wired through reversing lights, via a switch.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Mon Apr 23, 2012 12:04 pm
"" BIG ONES""" :thumbup: :mrgreen:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Spike on Mon Apr 23, 2012 12:12 pm
Definetely, looking at 32" or maybe 33" s...
:drink:
Spike
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Mon Apr 23, 2012 12:21 pm
just got robbed by the goverement again said £118.35 on letter was £121 on website
Vehicle Make: VAUXHALL
You have selected a tax disc for:
6 months at a duty of: £121.00
but at least it is done for another 6 months
AskDean
Skype Username: askdean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Mon Apr 23, 2012 12:52 pm
I took mine round the post office on the 2nd of the month and the lady gave me it for £118, it changed on the 1St April but they didn't change it on there web site!! Ha!Ha! so I robbed them for a change!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by wideformat on Mon Apr 23, 2012 2:19 pm
Just ordered a set of Nitro 8000 shocks from Llama 4x4 and a set of Insa turbo Sahara tyres to fit on my LWB to go along with the new springs.
Need to get it sorted before the end of May so I can tax it instead of the shorty for the summer.
wideformat
Vehicle Name: More Trouble
CB Radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dingal2000 on Mon Apr 23, 2012 2:42 pm
Just started on the paint work on the tailgate, removing scratches and chips, and found a crack, will have to opening it up slightly later and fill it
dingal2000
Vehicle Name: Betty Beast
Modifications: None what so ever just yet due to everything needing fixing first
Skype Username: dingal2000
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Mon Apr 23, 2012 7:01 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Mon Apr 23, 2012 7:17 pm
Had to get a tyre fitted to the front passenger side today. :thumbup:
R.I.P Sable!(2005 to 2013)
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Mon Apr 23, 2012 7:18 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Mon Apr 23, 2012 7:33 pm
Picked up a 265/75/16 BFG AT tyre as a spare for when ive got my 16" muds on. :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Spike on Mon Apr 23, 2012 9:12 pm
Hipo did the 32" MUDS, go on the front without any mods, apart from taking off Mudflaps....
Spike
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Mon Apr 23, 2012 9:31 pm
he had to mod the rear part of the arch quite a bit spike :wink: look on his members ride
viewtopic.php?f=46&t=35174
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Mon Apr 23, 2012 9:52 pm
Yes as above, I had to cut about an inch extra away from the rear of the front arches (I had previously cut them back, but I cant remember how much by so I cant say how much you need to take out of a unmodded truck, but prolly about 1.5 inches) - Not a hard job with a hammer and a angle grinder :). Infact the hardest part of it is getting the plastic trim to sit right so it looks normal...oh and yeah...loose the mud flaps :P
Oh and on another note...unless u have at least a 2 inch lift then you'll need a body lift because with my boot full of stuff (thats normal...i never have a empty boot) the rear wheels rub on the top of the arches if I hit speed bumps too quick lol. But its ok offroading because of how the axle twists it tucks the top of the tyres into the arches so they dont (only just) catch
Hope that helps fella
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Mon Apr 23, 2012 10:04 pm
Guys can you keep the techi chat in the techie area pleeeaasseee :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dingal2000 on Mon Apr 23, 2012 10:16 pm
Lower suspension 6 inches, fitted a new wider body kit, under car neons quad turbo now fitted with kick in supercharger, 100 litre take fitted running pure alcohole giving out 900 BHP ............................................ who just nudged me?????????? LOL nothing else since this afternoon
dingal2000
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Mon Apr 23, 2012 11:00 pm
:shock: :lol: :lol:
