Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Mon Apr 16, 2012 10:35 pm
This is what I got done to my Fronty this week:-
Before:-
Primed:-
Finished:-
Just got to get the paint to do a complete re-spray,which is next on the list to do in the next couple of weeks. :lol:
R.I.P Sable!(2005 to 2013)
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rseaville on Mon Apr 16, 2012 10:43 pm
New sump bash plate fitted.
Clever bit is it hinges down so i don't have to remove it when doing checks and oil changes.
rseaville
Vehicle Name: Tera
Skype Username: rseaville
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Mon Apr 16, 2012 11:09 pm
rseaville,that is a good idea. :thumbup: :thumbup:
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Mon Apr 16, 2012 11:29 pm
:clap: :clap: At long last Dave, it's all one colour :thumbup:
how much TiPeX did it take :?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Tue Apr 17, 2012 12:54 am
Not today but yesterday, fitted and wired the 2 over ride switches for the electric rad fans.Stretched the front bumper mounts and bull bar to match the body lift and splashed some paint over the weldy bits. :D :D :D
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dingal2000 on Tue Apr 17, 2012 3:26 pm
not as much as i would like, wanted to prime the drivers door after a rub down to smooth off and taking off the shine, it rains, bugger bugger bugger :evil: ive gone out dried it twice with a smile on my face ready to go walk in make a brew , walk out and its buggering raining again :evil:
dingal2000
Vehicle Name: Betty Beast
Modifications: None what so ever just yet due to everything needing fixing first
Skype Username: dingal2000
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Tue Apr 17, 2012 3:32 pm
spend a couple of hour's on the rear end today
relocated the rear number plate to the tailgate,
lowered the spare wheel mounting point so i can see out of the back window :D
moved the tow bar up by 4" so i now have less to dig in to the ground with :lol:
before,,,,,, i can't see the green car behind me
after,,,, i can see it now
2" body lift & 2"suspension lift
please post your comments for bob here
members ride viewtopic.php?f=46&t=48379&p=523317#p523317
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Tue Apr 17, 2012 4:36 pm
Big Dav,it took 5,000,000 tubs of T1PPX to paint the door. :lol: :lol: :lol:
It was about time I got the door painted,its only taken about 2 or 3 years to paint the door. :lol: :lol: :lol:
When it gets re-sprayed,it will be getting done inside an old caravan awning.
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dingal2000 on Tue Apr 17, 2012 7:38 pm
car is starting to turn in to patchwork LOL rain stayed off enough to do a little roughing and primer , will do a wing tomorrow.
God i think i would have finished the truck in 2020 LOL
dingal2000
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Tue Apr 17, 2012 8:05 pm
I fitted a nice 30 amp push button to finish my ignition bypass. If you dont know where it is you cant start the truck so a little bit more secure as well :D
Vehicle Name: Dino
Fitted my muds on again ready for strata :D 8)
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by davenlin on Tue Apr 17, 2012 9:24 pm
Yesterday I painted the front and rear towbars , the engine and fuel tank guards
RDH Graphics & Decals
davenlin
Modifications: none yet
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by davenlin on Tue Apr 17, 2012 9:27 pm
Today I tinted the rear windows (this is to help keep the kids cool in the sun)
davenlin
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Tue Apr 17, 2012 9:49 pm
Good job mate :thumbup: . Dont you have any problems with the front towbar grounding out whilst laning/off road as it looks quite low!? :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by davenlin on Tue Apr 17, 2012 9:53 pm
davenlin
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Tue Apr 17, 2012 9:57 pm
Theres still room to join the strata trip matey!! :wink: :wink: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Wed Apr 18, 2012 7:25 am
finally got the rear brake pipes fitted and the whole system bled trough..took slightly longer than expected due to both front bleed nips being siezed and then blocked, luck would have it that I had a couple of spares (somehow these appeared to have fallen off and landed into my toolbox from my last scrappy trip)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Wed Apr 18, 2012 7:31 am
:thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dingal2000 on Wed Apr 18, 2012 9:36 am
nothing its to wet
dingal2000
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Wed Apr 18, 2012 12:18 pm
Been laning :D Did 3 lanes and 2 fords to make sure everything was ok after the clutch change. And it was :D
I then washed it and got rid of most of the broseley mud from under the truck :roll:
