Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Roo on Tue Jun 09, 2009 11:03 pm
Hi Guys :D
sorry to ask but do all Fronty's come with a guard that protects the tank or do you have to buy that separate please? and if so how much do they cost please?
Sorry for posting it here but I wasn't sure where to put it :oops:
Thanks :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Tue Jun 09, 2009 11:08 pm
Its a standard Item Roo, wouldnt be much use without one off road, my old one is on the drive by that split tyre. They are made fom metal and will take a hell of a pounding but the trucks are at an age now where they are starting to rust through. I got a 2nd hand one for 20 quid in good nick when I replaced mine tho.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Wed Jun 10, 2009 8:33 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JueOmega on Wed Jun 10, 2009 9:18 pm
JueOmega
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Wed Jun 10, 2009 9:56 pm
Put the new rear side window in and hoovered all the glass up.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dupe on Thu Jun 11, 2009 8:01 am
Auto glass have been fixed crack in front screen :dance: ready for the laneing session :party:
Dupe
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Thu Jun 11, 2009 7:49 pm
Got underneath her and put all the pipes back in their relevent clips that have fallen out. Checked rear diff levels. General look around for oil leaks and found one that I think is from one of the power steering hoses so they all got cleaned and tomorrow should show which one (it's only a small leak but it has made alot of mess, fluid level a little low so it's been topped up) looks like the "wind" from the belt has blown it all over the passenger side suspension/steering components. Also found a drop of oil on the sump plug so again cleaned prior to tomorrows re check.
neither leaks appeared to be serious (ie oil/fluid p**sing out all over the place) but there is a lot of mud and grime that it has soaked into making it look worse.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by simo_d on Fri Jun 12, 2009 11:05 am
i put a air horn on my car :),
think it sounds more like a party blower than a air horn :shock:
simo_d
AKA The Cosmic Fool
AKA The Cosmic Fool
Vehicle Name: Elizabeth
Modifications: 2"lift,
buckshot mudders
air horn
yellow bash plates :)
internal snorkel
light guards all around
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MuddyD on Sat Jun 13, 2009 8:21 am
painted and replaced rear diff plate, plus obviously a service on it with new oil and molyslip. Was releif to see only a few shavings on the magnet, and no teeth missing :D
so now that job is done time to work on wheels
24 beers in a case, 24 hrs in a day...... coincidence ???
MuddyD
Modifications: None as yet
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Sat Jun 13, 2009 9:31 am
Today I will be stripping down the rear axle of my shorty to use the bits on my LSD ready to swap that over maybe next weekend.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Sat Jun 13, 2009 10:53 am
Engine oil change, good clean inside and fitted new seat covers.
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Jun 13, 2009 12:18 pm
Just waiting for the hangover to clear :oops:
Then rear brakes strip and clean and oil change and a good jet wash underneath all ready for the MOT :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BadBoy on Sat Jun 13, 2009 7:18 pm
Key damage has now been resprayed, and what a job that was.
Had to take the affected areas of the panels down to bare metal, prime, and respray.
Just need to wait 24hours to blend the paint then lacquer and jobs a good'un.
Skype Username: paul.bush21
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andyvee on Sat Jun 13, 2009 7:57 pm
Took it for the MOT and failed on the steering column being loose!
Replaced the three top bolts and will be back for the retest next week!
Got a scary list of advisories - discs all round, corroded brake pipes, perished CV boots - none of which were bad enough to fail but still means more £££££'s to find and out with the copper pipe and the flaring tool....
Andy
Ex Frontera Owner
... but I know have a Skoda Octavia Estate 2.0TDI with 300lbft of torque mmmmmmmmm
andyvee
Modifications: Ex Frontera Owner
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Jun 14, 2009 7:57 pm
Well I did all the jobs I was going to do yesterday today as she had me doing the garden :roll:
Well today stripped and cleaned rear brake calipers and did an oil change and jet washed the underneath.
The jet washed most of the house and next doors, cleaned the mini shed out and a bit more gardening :roll: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by neal on Sun Jun 14, 2009 8:01 pm
fitted a new cd headunit today
still got a list of things to do will get there sooner or later :lol:
neal
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sun Jun 14, 2009 8:24 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JueOmega on Sun Jun 14, 2009 10:29 pm
Played about with trugga's LWB, and cleared MY fault code
JueOmega
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Sun Jun 14, 2009 10:37 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sun Jun 14, 2009 11:06 pm
Made my chevy/brava fing look FAT!!
