Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dingal2000 on Sat Apr 14, 2012 12:58 pm
nothing today, its family day :D
dingal2000
Vehicle Name: Betty Beast
Modifications: None what so ever just yet due to everything needing fixing first
Skype Username: dingal2000
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Sat Apr 14, 2012 1:10 pm
Drove it to Robs to pick up wideformats new spring that i will take to strata for him and put £100 of fuel in :shock: so now ive got 3/4 of a tank of fuel!! :shock: :shock: Im sure this tank came off a 7.5tonne truck!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sat Apr 14, 2012 2:46 pm
well not today, but last night my boot wouldnt open after i locked it with some stuff in
so i removed the rear glass, and plastic boot card to get to the mech, and there wasnt anything wrong with it :roll: so i just lubed it up and put it all back together, and now working ok.
pot bellied pixie
Modifications: Now deceased.
Gone to the dark side a
black shogun sport equippe.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Apr 14, 2012 3:16 pm
:lol: :lol:
Well took the truck out to Aintree to get bulbs, oil and oil filter for the picasso.
Got home sorted the bulbs but saving the service until tomorrow as had a few beers and watched the match.
But just popped out to the fronty as spotted some damp on the rubber in the footwell earlier, turned the rubber flooring back and it was full of mud and water, after extensive finger shoving and getting filthy I found the leak was from under the kick plate when going through deep water. I had sealed this a few years ago on all the doors but as the drivers side is pretty much all thats used the sealant had worn away, so drying it out and will reseal it in a few days :thumbup:
Would have stunk had I not had rubber floors :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Sat Apr 14, 2012 8:55 pm
Well today I fitted a new uj on my prop, and finally fitted the hindges I got off boxcleva with help from Jim (Wilberforce) thanks Jim
Also refitted my spare wheel carrier and spare wheel.
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by kees on Sat Apr 14, 2012 8:58 pm
Fitted the exhaust and did on oil and filter change :D
kees
Now sold, A series Frontera.
FOG sticker
1997/ p reg 2.2i
Now sold.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Sat Apr 14, 2012 11:22 pm
i took two wheel barrows of tools and engine spares out of the boot so my wife could fill it with garbage for the car boot tomorrow.
the positive is i just raised the backend about 6inches without spending a penny lol
AskDean
Skype Username: askdean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sun Apr 15, 2012 1:01 am
Well today me and andytats changed my front wheel bearings. They were well mullered because when we took the off side ones apart half the inner bearing stayed on the spindle lol. More rust than grease and generally not a pretty site lol.
Also found out that I can get about 440 miles from a tank of diesel (85 litres)...haven't done the math yet but I'm going to hazard a guess its high 20's to low 30's (could do better as it has about 60kgs of tools in the boot plus sub and some of fudges recovery gear etc etc)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Apr 15, 2012 1:03 am
Dan, the tank only holds 80L :thumbup: thats on an A not sure the B series may be smaller, or is it the B series sport that hold less?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sun Apr 15, 2012 1:06 am
B lwb has a 80l tank plus give or take 5litres in the pipe. And yes the b swb holds less, but can't remember how much less off hand
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Apr 15, 2012 1:10 am
No way is there 5 litres in the pipes and filter Dan :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sun Apr 15, 2012 1:17 am
Can't be far off? Remember the tank on a b is under the near side seats so the filler neck is fairly long :P
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Apr 15, 2012 1:34 am
No where near fella :wink: but heyho
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dingal2000 on Sun Apr 15, 2012 1:46 am
isnt the connecting pipe from the tank to the filler narrow?
dingal2000
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Apr 15, 2012 1:47 am
Very :roll: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sun Apr 15, 2012 1:50 am
About 1.5 inch diameter and its about 25cm long from memory.
Edit: I've just looked at a pic and it looks longer than 25cm tbh. Will post the pic tomorrow :P
Gotta admit I thought the lwb was 85 litres and the shorty was 55. :oops:
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Sun Apr 15, 2012 8:27 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sun Apr 15, 2012 11:12 am
Yersterday:
Went to the "Truck Surgery".
Winced as we found only a few but awkward to repair age related body issues.
Set about the first stage of cleaning the affected areas and starting the rebuild process.
Many many thanks to RobFog for giving me a lift home last night at stupid o'clock. Your a star and credit to the site.
