Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Thu Apr 12, 2012 6:11 pm
Greased all the nipples now that I have the spare parts for my grease gun and it's all fixed.
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Thu Apr 12, 2012 6:15 pm
Well mines in Riches work shop with
•one broken front drive shaft
•two both front bearings gone
•hand brake shot again looks like the shoes have gone
•and one big services As I have it done evey 6 months ,the oil is still clean as its only done 1.6k from the last one ow well more exspence :wall:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dingal2000 on Thu Apr 12, 2012 7:53 pm
Stripped some paint off to get the rust underneath filled sanded and primed, cleaned it out and hoovered it first and last time for 6 months lol,
dingal2000
Vehicle Name: Betty Beast
Modifications: None what so ever just yet due to everything needing fixing first
Skype Username: dingal2000
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Thu Apr 12, 2012 8:14 pm
Not today...but on the 10th I reinsured it :) £93 and a few pennies a month....only £7 better than last year per month...but still better :)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jellybaby on Thu Apr 12, 2012 9:01 pm
took it off road for the first time well up the corner of a mates field. found out the ats are crud in mud. was surprised how she went up the hill just idleing in 2nd low
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu Apr 12, 2012 10:28 pm
I had a fun day the other day i couldnt get it to go anywhere today i couldnt get it to stop. Brakes failed on a downhill in traffic. The pedal went rock hard and it wouldnt stop it slowed a bit but there was no brakes after a few miles i got use to it.
Fluids fine must be pads or master cylinder ahwell
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Thu Apr 12, 2012 11:19 pm
I would say its either the vac pump on the back of the altenator, or the vac hose to the servo is split. Especially as you said you heard hissing the other day. Master cylinder going would give a soft pedal. If it is the master cylinder, its the same as a leafer fronty, or at least a 2.3. Double check your not losing vacuum on the black with red stripe hose.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu Apr 12, 2012 11:59 pm
I will check that out the black/red one was the one that was hissing
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Apr 13, 2012 7:09 am
Here is mine Drinks. I have arrowed it. You cannot see it but I have blocked it off as I have no need for vacuum apart from the brakes. The black/Red one serves the EGR's and QWS (quick warm-up system). The big one is the brake servo feed.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Apr 13, 2012 7:43 am
Guys, techi posts in the techi section pleeeaasee :thumbup:
We dont want to loose good info :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by traction on Fri Apr 13, 2012 5:28 pm
binned the egr :dance:
traction
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Fri Apr 13, 2012 5:30 pm
Fitted my newly made, "landy assistance point"! Il attempt pics later! :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by kees on Fri Apr 13, 2012 8:12 pm
Removed the exhaust system from the cat back, What a pig of a job to get the cat out :x . Changed left engine mount. Tomorow just got o fit the new cat and center box.
kees
Now sold, A series Frontera.
FOG sticker
1997/ p reg 2.2i
Now sold.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Apr 13, 2012 9:27 pm
Cleaned out the inside of a metric ton of rubbish, took off the spare wheel and deposited it in the boot, and then finished off by getting underneath it and removing the side steps. I would of taken the bumpers off but didn't want to temp fate tomorrow on her trip to surgery.
Reattached my side step, only took me two weeks to get round to it and ten mins to sort :oops:
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Fri Apr 13, 2012 10:14 pm
And youll only have it on a week before you leave it somewhere on strata mate!! :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Apr 13, 2012 10:30 pm
Started swapping most of the front suspension from the Dti to the Troop. More tomorrow.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Apr 13, 2012 10:33 pm
Looked at it...but got a pair of cheap track rod ends for her, not needed but you never know :wink:
She has done 3 miles in 4 weeks :lol:
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrTom on Sat Apr 14, 2012 7:32 am
Not if I use them as waffle boards you won't 8)
MrTom
Model: 2.0i Sport Niagra 3dr
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
Insa Turbo special tracks
2" suspension Lift
Spare wheel carrier removed
Rough country Shocks
Roof Rack
4 X 55 Watt roof lights
Tow Bar
Fan over ride switch
Bucket seats
3-point Sparco Harnesses
Rear seats removed
Manual locking Hubs
Rear welded recovery point
Winch bumper
Winch
