Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Mon Apr 09, 2012 4:04 pm
EP90 & Molyslip into new diff and old diff so we now have 4wd ready for the trip to wales! :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by kees on Mon Apr 09, 2012 4:50 pm
Took a load of rubbish to the tip. Good job that i had taken my light bar off as there is now a hight restriction at the tip, my arial catches the bar but my roof rails miss by about 2cm :lol: . They are trying to stop companies in unmarked vans from dumping.
kees
Now sold, A series Frontera.
FOG sticker
1997/ p reg 2.2i
Now sold.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Mon Apr 09, 2012 5:51 pm
i hate the max height i keep thinking the hi top is gonna skelp the bar in the trooper
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BadBoy on Mon Apr 09, 2012 6:51 pm
I taxed mine for another year as I got the reminder in the post - £220 :shock: :shock: :shock: :shock:
Skype Username: paul.bush21
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Mon Apr 09, 2012 7:49 pm
got the military tow hitch fitted today 8) 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Mon Apr 09, 2012 8:06 pm
Well done Ian...it coming together, at last... 8) 8) 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Mon Apr 09, 2012 8:25 pm
yes mate. had a look on that milweb site you said about but couldnt find the paint...sorted for panel wipes, tack cloths n mix cups though :D :D :D
is this paint the right stuff?
http://www.ebay.co.uk/itm/180571296238? ... 1436.l2649
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Apr 09, 2012 10:23 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Mon Apr 09, 2012 10:42 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Tue Apr 10, 2012 12:39 am
Got the electric fans wired in and tested, that just leaves the 2 overide switches to do. The wiring looms are all ready, just coiled up under the bonnet, it was raining so I was reluctent to be pulling the glove box and dash apart.
Just for info, the range for the temp switch to cut the fans in and out is 88 in and 79 out, using a "Fluke" meter temp probe in the header tank the fans cut in at 83 and out at 75 (appreciate the header tank will be cooler). However, when the fans cut in the temp gauge was showing 3/4's ( this being the mark above the horizontal marker being half), this leaves one more marker (full) before you get to the red.
12 months ago I fitted a new stat (82 degree) for the winter and thats roughly where the neddle pointed then, though I changed it back for the old one as it ran cooler.
Those with 2.8's, where does any one elses' needle read when the stat opens as I think my gauge may be reading high!
Regards
Stuart
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Tue Apr 10, 2012 6:58 am
never seen my 2.8's temp move from cold :shock: :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Tue Apr 10, 2012 7:10 am
Ian check your stat as mine was like that and it was stuck open changed it and now sits just above a 1/4
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by adyclemo on Tue Apr 10, 2012 9:15 am
Never seen mine go any higher than 1/4 and that was round the Yorkshire dales with a car and trailer on the back. Otherwise it never moves from the top of the cold mark. Put my heater on number 4 and it blows a draft rather than warm air.
Regards Ady
Comment on the motor here
adyclemo
Full lenght roof rack.
Front tow bar.
CB.
Manual locking hubs.
Suspension lift.
32" BFG's
Snorkle.
Egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Tue Apr 10, 2012 9:39 am
Hound Dogs Tractor
Hound Dog
Missing In Action
Missing In Action
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Tue Apr 10, 2012 9:40 am
Hound Dogs Tractor
Hound Dog
Missing In Action
Missing In Action
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Apr 10, 2012 10:01 am
Had the same in my 2.8 in the Trooper. Did the same as Hound Dog and fitted the 85 degree stat from a 3.1. You want the QTH411K stat. Mine now sits at the 1/4 - 1/3 mark and both heater matrixes are toasty warm.
One thing I did do though is properly flush the coolant out using the intended drain plug at the bottom of the engine in front of the starter motor. If you don't you still have a block thats half full of water/sludge which doesn't help matters.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Tue Apr 10, 2012 8:17 pm
the heater works fine, lovely n toasty, but the temp guage dont move
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mickh on Tue Apr 10, 2012 9:00 pm
Rob you've got to get out more and work less :crazy:
mickh
Modifications: 2" lift.
Front winch.
CB radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Apr 10, 2012 9:11 pm
Washed her ... and for good reasons as well.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by wideformat on Tue Apr 10, 2012 10:08 pm
I stood and watched the rain wash the mud off my truck through the window :wtf:
wideformat
Vehicle Name: More Trouble
CB Radio.
