Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rospicer on Tue Apr 03, 2012 9:37 pm
spot on there danny, its a coiler
SHE MUST GET BIGGER BOOTS
rospicer
Vehicle Name: COMING SOON
Skype Username: spicechop
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Tue Apr 03, 2012 10:49 pm
Picked up one of these from Maplin today, gonna fit it into the ashtray slot over the weekend. Not sure where the antenna's going to end up though.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Tue Apr 03, 2012 11:02 pm
that reminds me i need to take mine out and fix it no tx loose plug for mike needs putting back on motherboard.
AskDean
Skype Username: askdean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Wed Apr 04, 2012 2:10 am
Snapper, that looks very like a TTI 550, if it is you have every right to be pleased with yourself, it's a first class bit of kit.
Regards
Stuart
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Apr 04, 2012 9:15 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Wed Apr 04, 2012 7:36 pm
So it were a bit of a score then... :thumbup:
And I was thinking of trying to get hold of a working VRC 321 and fetteling that into the car somewhere... Not sure if it would have worked as a CB, but the output at 30 watts would have been impressive.... :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Wed Apr 04, 2012 11:45 pm
Well, the units in, just need to do the wiring bit and clean up on friday. Fits quite well in the 'ashtray' slot and plenty of space behind for the wiring stuff as well :D
Antenna thing is going on the roof via one of the two 'covers' located above and forward of the rear side windows once I've made something up to take the mount on.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by wideformat on Thu Apr 05, 2012 1:33 am
[quote="snapper"]Well, the units in, just need to do the wiring bit and clean up on friday. Fits quite well in the 'ashtray' slot and plenty of space behind for the wiring stuff as well :D
I may be stating the obvious but have you got an extension speaker ? only I tried mounting my CB where you have put your's it looks a neat job but I could not hear a bl**dy thing when the car was moving due to the built in speaker being underneath the unit and with the engine running even on full volume could not hear a thing anyone was saying also it was a nightmare to swr the unit unless you leave the meter plugged in all the time as it's a fiddly job connecting and unconnecting the antenna socket.
Just a thought !!
wideformat
Vehicle Name: More Trouble
CB Radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by wideformat on Thu Apr 05, 2012 1:36 am
Found out the "P" reg LWB I have just brought has a fuel leak, must be a common problem on Fronties as my shorty also had the same.
It may be a silly question but how do I find out if it's an "A" or "B" series ? :?
wideformat
CB Radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by horses45 on Thu Apr 05, 2012 4:32 am
should be pics in the A and B series links on here gary and the B seems to be a bit more curvey, if i wasn't at work would of put the pics up for you to see the difference
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Thu Apr 05, 2012 7:31 am
Got truck back yesterday after having the clutch sorted. Love driving it again!!!! :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by adyclemo on Thu Apr 05, 2012 9:17 am
@ snapper I got that same CB kit for Christmas from the partner and its an excellent piece of kit.
Yesterday I bolted the bull bar back on and taxed it for 6 months.
Regards Ady
Comment on the motor here
adyclemo
Full lenght roof rack.
Front tow bar.
CB.
Manual locking hubs.
Suspension lift.
32" BFG's
Snorkle.
Egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Thu Apr 05, 2012 1:48 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Thu Apr 05, 2012 8:02 pm
Was wondering about the speaker myself. Consideration was to use one of those combined speaker/mike things but will probably end up going down the line of a seperate speaker. I've got a few kicking around the shed.
Antenna? going to run the cable up through the car and terminate it in a socket where one of the blank plates is located above the o/s rear window as a temp measure then fit a new plug onto whats left of the mag mount cable so I can plant that in the middle of the roof for now. The perm installation will see a junction box replacing the blank plate with the co-ax terminating in a socket there along with a water proof switched 12v outlet for some roof lights.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by wideformat on Thu Apr 05, 2012 8:23 pm
wideformat
CB Radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Fri Apr 06, 2012 6:52 am
came very close to scrapping it, just after taking a match to it........
why does a "simple" job turn into a major disaster?......
rotten fuel pipes over rear axle removed..simple job, got covered in fuel..doh number 1
then it's time to do the rusty rear brake pipes..simples, it's just the two along the rear axle..just 4 unions
nope..
both caliper ends come off fine, but the two at the flexi part wouldn't move..snapped my brake spanner (the one with the slot)..result rounded unions..bent the mole grips.
so flexi pipe off but neither of the unions to the load valve would move, result pipe bent and split..now i'm covered in brake fluid as well..at least the flexi pipe is off..luck would have it that i have a spare (no idea where it came from)
so i've got a stuck union in the load valve, that it nearly rounded. a bent pair of mole grips, a snapped brake spanner and need 3 lenghts of brake line and 6 unions, instead of two pipes and 4 unions. as well as turning myself into a fire hazard..
oh forgot, noticed that the diff plate is leaking..
getting close to that point now..
Last night, I changed the wheels back to my ats and while I had the wheels off I jet washed the rest of the mud off from Sunday :oops:
Think I need to take the bash plates off next to see what muds left under them :shock:
Also had a look on how to fix my side step as the top cover fell off! Hopefully once I drilled the remains of the metal pins out it can just be self tapper screwed in and the plastic plate screwed back on :D
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Fri Apr 06, 2012 12:52 pm
today i changed the oil and air filters and the oil.
so now running nice and sweet :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Apr 06, 2012 1:30 pm
Gave the engine its weekly turn on, started on the first turn in fact I think I left it more than a week this time :roll:
Fixed the rear passenger door lock, it was stuck shut so I lost my rag and with suitable force ripped the door card off and lubed up the mechanism, it now works but the door cards is in a bit of a state :oops:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Fri Apr 06, 2012 2:31 pm
Who do you think you are Horses45?????? :thumbup: :wave:
