Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Fri Mar 30, 2012 8:48 pm
Its started!! My new one has gone into surgery for the first round today at my mates garage so the diff should be on in time for STRATA!! :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Fri Mar 30, 2012 11:39 pm
Found one of the new tyres had gone soft - I have now had the alloy wheel bead wire brushed and liquid rubber compound applied - tyre refitted and leak test looks good so far.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Fri Mar 30, 2012 11:51 pm
Nice one Ian be nice to see it!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Fri Mar 30, 2012 11:54 pm
Stick up some pics of the 2.8...we havnt seen her yet! :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Sat Mar 31, 2012 10:36 am
here he is......Unfinished as yet. got a lot planned for him including full respray
I'll start a new members rides thread
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Mar 31, 2012 10:50 am
Turned the engine over today for the first time in a week, started first go, so all fine to sit another week :thumbup: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Sat Mar 31, 2012 12:22 pm
My new ones still in hospital! :thumbup: Goin out to start tidying up the leafer when the sky mans been so i can put it up for sale after strata.... :(
Just fitted my muds :dance:
Wow it looks much better 8)
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Sat Mar 31, 2012 2:50 pm
PICS PLEASE!!!!! :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Mar 31, 2012 3:11 pm
Picked this up at a scrappy today for £20
Even has convenient spot light mounts.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by adyclemo on Sat Mar 31, 2012 3:20 pm
Just fitted my new steering idler, for once the job went as should with hickups what so ever.
Regards Ady
Comment on the motor here
adyclemo
Full lenght roof rack.
Front tow bar.
CB.
Manual locking hubs.
Suspension lift.
32" BFG's
Snorkle.
Egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Mar 31, 2012 3:32 pm
Just replaced the trailer sockets, boy were they bad, full of mud and corroded silly. Should go a long way to sorting the disco lights on the caravan lol
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Sat Mar 31, 2012 4:10 pm
time for an oil change new filter and some seal conditioner to go in i think while there is still day light
AskDean
Skype Username: askdean
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Sat Mar 31, 2012 5:21 pm
thats better oil change and filter done forte seal conditioner in and now just wait to see what happens hopefully sole the problem now just need to sort out a non air con fan belt till i can be bother to fixed the bearings in the clutch in that lol
AskDean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Sat Mar 31, 2012 7:10 pm
Had a new bumper fitted
And dropped Jim (Wilberforce) off to pick something up.
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Loneranger on Sat Mar 31, 2012 7:18 pm
Carried on with stripping rear axle ready to replace with another one, all this due to pinion seal leaking and cant get another one....so went for an intermediate fix.
When axle off i will then get a seal sorted one way or the other.
Anyway found out the hard way that the leaf spring dont half go "twang" when you release the U bolts, had a jack underneath supporting but for some unknown reason i thought it was in the way....dooh !!!!!!!!!!!!
Now have a bruised hand and an egg shape bruise on my arm which got caught underneath it, second U bolt removed with more respect.
New lesson learnt everyday..
Loneranger
2 inch suspension lift
2 inch Body lift - pending
33" KL71 mud tyres
winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Sat Mar 31, 2012 7:57 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrTom on Sat Mar 31, 2012 8:05 pm
Pictures mate piiiiictures!
MrTom
Model: 2.0i Sport Niagra 3dr
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
Insa Turbo special tracks
2" suspension Lift
Spare wheel carrier removed
Rough country Shocks
Roof Rack
4 X 55 Watt roof lights
Tow Bar
Fan over ride switch
Bucket seats
3-point Sparco Harnesses
Rear seats removed
Manual locking Hubs
Rear welded recovery point
Winch bumper
Winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Loneranger on Sat Mar 31, 2012 8:10 pm
Loneranger
33" KL71 mud tyres
winch
