Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Thu Mar 29, 2012 10:04 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jimmybhoy on Thu Mar 29, 2012 10:09 pm
Nice Pics BOX, that looks identically like the same Hose from the BP Garage hoover,
i only know that cause mine looks the same Image
jimmybhoy
Registration Year: 2004/04
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Thu Mar 29, 2012 10:11 pm
Well when you go tomorrow and the hoover is out of order you'll know the reason why :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by wideformat on Thu Mar 29, 2012 11:04 pm
wideformat
Vehicle Name: More Trouble
CB Radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Thu Mar 29, 2012 11:54 pm
It went click again at work and one was forced to get a jump start, the truck that is, not me sadly, although she was cute... (very) still I degress... Picked up a new battery thing from hellfrauds so it was old battery out, new battery in when I got home ... Bonus, truck starts :dance:
Now got one of these things under the bonnet. (111 beer tokens wth the discount card).
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Thu Mar 29, 2012 11:54 pm
Put my ATs back on....god they look small now :(
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Fri Mar 30, 2012 2:40 am
Up-date on the body lift drama of yesterday, barrowed a gas axe and sliced the head off the bolt to the OSF mount, lifted the body after disconnecting various bits and fitted the pucks barring the OSF and NSR. Free'd off and remove the sheared bolt from the NSR and fitted the puck, removed the viscous fan in readiness for fitting the electric fans when they arrive tomorrow. Hopefully my "new" mount for the OSF will arrive tomorrow as well, thanks Andy.
After that I can tighten all the mounts up modify the gear shift appature in the tunnel and refit all the carpets; seat; threshold liners and the various disconnected bits. That leaves the front bumper lift ( do the same to mine as I did to Pete's (Loneranger) and rework the heavy duty fella at the back.
Down side is now I'll need a stepping stool to be able to get in but it does look the bogs dollocks.
Regards
Stuart :D :D :D
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Fri Mar 30, 2012 9:55 am
yesterday I welded the plate onto the o.s sill and repainted it. also done the door and wheel arch rust and painted.
fitted the other rear bumper and the manual hubs. just 2 bulbs to replace today then MOT at 5pm tonight :| :|
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Fri Mar 30, 2012 12:58 pm
Good luck Ian!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Fri Mar 30, 2012 3:29 pm
today i took mine in for the rematch, errrm i mean retest
and it passed this time :dance:
and then gave the tax man £215 just to have a car :boohoo:
then had to get some fuel.
was 2nd in a line when i got there :twisted:
and then got £70 of fuel
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Fri Mar 30, 2012 3:54 pm
cheers guys. nice one fudge
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by stevd on Fri Mar 30, 2012 5:08 pm
Starter motor refurbed and refitted for £60, winner :) and wheel bearing tightenend, although it needs replacing. Any suggestions where to get a decent one from? tthat one lasted 6 months :(
stevd
3.5" wind up on front
pro Comp Shocks
Side step removal
Bonet Guard
A fair amount of scratches
Lots of rust to add character
16" alloys from an A Series
Silicone vac pipes
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Fri Mar 30, 2012 6:46 pm
its only took a year but finally got round to taking the bottom set of spots and bottom fog logs off and washing the mud out of them form when i sunk the sub last year in the clay pit
theres was things swimming around in the bottom of the left one lol
AskDean
Skype Username: askdean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Mar 30, 2012 7:18 pm
Removed with a hammer I see ... like your style!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Mar 30, 2012 7:28 pm
Removed rear mudflaps, checked rear diff oil level , greased UJ's , dropped tyre pressures, sealed air box lid, checked engine oil and coolant . Repositioned CB aerial.
Also fitted a very dodgy home made sump bash guard, it will be interesting to how long that lasts :lolno:
Laning tomorrow :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Fri Mar 30, 2012 7:38 pm
AskDean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Fri Mar 30, 2012 7:40 pm
Took the new truck for its test and................................
IT PASSED!!!!!!!!!!!!
fitting stereo, cb and greasing props tomorrow :D :D :D :D :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Mar 30, 2012 7:45 pm
Nice one Ian :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Fri Mar 30, 2012 7:46 pm
nice one mate :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Fri Mar 30, 2012 7:59 pm
Nice one Ian another 2.8 on the road.
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
