Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Sun Mar 25, 2012 12:29 am
Refitted the now dried out and brushed loadspace carpet, bolted the rear seat mounts too.
Having the write the wiring diagrams for the pair spots to be fitted to the roof as I will be using a common low current circuit already in place with the existing two roof lights but having them switched independently.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Mar 25, 2012 3:21 am
Dan mate I love you, as your nuts and have buckets of enthusiasm :thumbup: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Sun Mar 25, 2012 4:26 pm
Spent the afternoon trying to fix my ignition problem. New barrell and key. No difference, new switch. no difference, checked system only 4 volts at solenoid so new switch no good either. Run a hot wire into cab with a flick switch between the terminals so it starts every time for the minute. Will try and find a new ignition switch next week. Have tried 3 second hand ones so far and all have had the same fault on. :( :(
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by horses45 on Sun Mar 25, 2012 6:37 pm
well changed the rear springs took the heavy duty plus 2's off and put the originals back on, changed the new prop or should i say put it on then done rewar and front diff oils and topped gearbox oil up took it to the carwash and then back for a beer o clock and a chill as it has been a long day now to see if i lose the prop after dropping the height down ,but i think thats what my prob was as the uj's just could not handle the angle and pressure of it.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by carlisletiger on Sun Mar 25, 2012 7:23 pm
quite sad and lazy but i paid the local Arc car wash to T-cut and polish it, £20 quid well spent
carlisletiger
Vehicle Name: Tiger
Well i got my power cable fitted :D as well as my rear work light :D s and my cb in. :dance:
does any one know the best way of checking if a cb is working correctly? :oops:
(I have a swr reading of 1.8/1.9 on channel 20 - listening to static though)
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by wideformat on Sun Mar 25, 2012 9:03 pm
I moved mine about 15 feet down the drive so I could sweep up all the mud which had dropped of the undercarriage.
Must have swept up a bucket and a half of Salisbury Plain. :D
wideformat
Vehicle Name: More Trouble
CB Radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Sun Mar 25, 2012 9:08 pm
repositioned the lpg filler nozzle and then changed the seals on the pipe behind it to make them seal properly so stop letting some escape when filling lol check the oil and after then threatened it with a hose
AskDean
Skype Username: askdean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Sun Mar 25, 2012 9:13 pm
Drove it to a mates to help him with his Mk3 Zodiac. Very nostalgic and after a while sorting the timing the engine fired up - great straight sixes!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Sun Mar 25, 2012 9:15 pm
I checked and topped up the oil and power steering fluid. I also found out that my EGR gaskets are leeking like a sieve...and there's carbon/oil or something black and horrible all over the driver's side of the engine. :cry:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Sun Mar 25, 2012 9:46 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Sun Mar 25, 2012 10:03 pm
I used it to help Greg out of a hole he was in !!!
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Sun Mar 25, 2012 11:00 pm
went down to maccy dees for a banana milk shake and on a sunday night we get all the kids in there rinky dink glow in the dark corsas and golfs doing burn out and drifting round the round abouts and upset a pair of nuggets at the lights when they lined up next to me in lanes 2 and 3 to have a wee race of the lights against each other thinking they would drive right past me before it filtered into one lane down to the next round about and was so not amused when left the pair of them behind to 50 which was the limit and then sat there laughing my socks off
to make it worse when i pulled round the front of maccy dees with my milk shake in hand the kids where laughing at them as they parked up getting the bleep ripped out of them for getting done by a fat git in a fronty lol i just raised my shake to them and smiled and tootled off at tick over
good i love my v6 and this is exactly why even after 3 months of it doing my head in and refusing to work properly i refused to give in on my baby :dance: :dance: :dance:
AskDean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Sun Mar 25, 2012 11:05 pm
Replaced all the fuel lines with nylon ones (got loads left if anyone wants to buy some)
Replaced one of the rear bumpers (thanks 2much)
Cut out the rotten part of the sill ready for welding plate in next weekend
Removed rotten side steps
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrTom on Sun Mar 25, 2012 11:47 pm
MrTom
Model: 2.0i Sport Niagra 3dr
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
Insa Turbo special tracks
2" suspension Lift
Spare wheel carrier removed
Rough country Shocks
Roof Rack
4 X 55 Watt roof lights
Tow Bar
Fan over ride switch
Bucket seats
3-point Sparco Harnesses
Rear seats removed
Manual locking Hubs
Rear welded recovery point
Winch bumper
Winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sun Mar 25, 2012 11:54 pm
And if you are really lucky, MrTom will bring his CB with him too! :lol: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrTom on Sun Mar 25, 2012 11:58 pm
Only if he is really lucky mate! :shh:
MrTom
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
2" suspension Lift
Roof Rack
Tow Bar
Bucket seats
Rear seats removed
Manual locking Hubs
Winch bumper
Winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Mon Mar 26, 2012 9:35 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Mon Mar 26, 2012 9:56 am
