Re: WHAT YOU DID TO YOUR TRUCK TODAY! by horses45 on Wed Mar 21, 2012 6:15 pm
well the replacement prop came today so old uj's out and new ones in. then fittedthe prop and changed the gearbox oil while i was on, then went to turn it over and click flat battery after having the hazards on for 7 hours yesterday but battery on charge then later on battery on and ready for work in the morning :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Wed Mar 21, 2012 6:44 pm
glad to here the ruck up and running lol
just need to get your new nudge bar unbolted off this and sprayed black and your finished for the day
AskDean
Skype Username: askdean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Mr Mud on Wed Mar 21, 2012 7:11 pm
Hi hippo1024 I like those ally wheels where did you get them :?:
Mr Mud
Vehicle Name: Hippo#2
Wind Deflectors.
Xenon HID Lights.
LWB Rear Light Conversion.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Wed Mar 21, 2012 7:23 pm
Hats off to you Dean, and see Rob silver lining and all.
The rest of you are busy for a midweek Frontyfest today :shock: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Wed Mar 21, 2012 8:20 pm
i jacked min up and changed the rubbers in my lpg filler pipes as i had to put some more gas in after my little adventure yesterday and was surround in a cloud of gas as the pipe had come loose as the rubber seal in the joint had perrished and when i filled it the pressure just blew it out lol
made the guy filling his up with petrol jump lol but all sorted now :dance: :dance: :dance:
AskDean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Thu Mar 22, 2012 3:08 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Thu Mar 22, 2012 10:14 am
Took delivery of new fuel line, new rear bumpers (thanks 2much), ordered ball joints to replace the ones horses45 lent me :D and also got my new shiny manual hubs :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by horses45 on Thu Mar 22, 2012 2:19 pm
nice one ian well i broke my new prop so a 4 inch lift and a 2.8 swb dont work so gonna have to take my new springs back off and put the old ones on ,so anyone inm desperate for a swb 2.8 prop if you have one and can post it if you cant post it im sorry but thats no use to me at all.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Thu Mar 22, 2012 3:47 pm
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Thu Mar 22, 2012 3:57 pm
Thought as much. Well that is that mystery cleared up then. Nice one Hound Dog.
One thing I will say is that I wouldn't run around with any hubs on at all. If the circlip falls off your CV joint will float and then the needle bearings in the hub stub will wear out in short order. Also without a hub on the outer wheel bearing is exposed an you will find that it may well dry out quickly (especially if driving through water/puddles) as it doesn't have a seal on like the inner one has.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Thu Mar 22, 2012 4:21 pm
what do you gain fitting a set of b series hubs on an a series guys ?
checked my new 2nd hand diff pan & no leaks :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Thu Mar 22, 2012 4:37 pm
It locks the wheel to the axel Foggy. Much like running around with manual hubs locked all the time. With the old A series 4WD lever operated system it will not only allow you to shift between 4WD and 2WD on the fly (up to around 30-40 mph), you can also be guaranteed that you avoid the snatch effect when driving forwards and driving backwards you get with autos as they lock and unlock between the two directions. Point of note. You can run in 2WD with the front hubs locked on an A series without wind-up. What you might get is extra wear on the CV joints and possible decrease in fuel economy as your now always turning the front drive train.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by davenlin on Fri Mar 23, 2012 1:57 pm
Got the roofrack on
just need some better spots now these ones are nacked
RDH Graphics & Decals
davenlin
Modifications: none yet
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Fri Mar 23, 2012 2:07 pm
Had two new tyres fitted on the front so I've got good rubber all round again. :D
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by wideformat on Fri Mar 23, 2012 5:02 pm
Drove mine to work today and it's running better than ever which is a bit of a worry, something must be about to break :D
wideformat
Vehicle Name: More Trouble
CB Radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Fri Mar 23, 2012 5:09 pm
took the denso plugs out and reverted to a nice shiney set of NGK R laser platinum jobbies and feels so much more responsive for it.
AskDean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by screwyuk on Fri Mar 23, 2012 6:14 pm
Removed a leaking radiator :-(
screwyuk
Modifications: frontera sold :-(
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Mar 23, 2012 7:34 pm
Drove like a dream, but had to thump the front flasher as its loose and went on strike, now sorted :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Fri Mar 23, 2012 7:38 pm
on the 2.2 removed the exhaust and wrapped it in black plastic so it wont make a mass in jim's car for the FOG express. then changed the engine oil & filter on the 2.5. :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 2much on Fri Mar 23, 2012 9:12 pm
not quite today but.....
removed front bumper, picked up my wheel arches from Bobbins (lucky he didnt charge me for storage (would have cleaned me out!) cheers Ian :D
2much
Modifications: 2much!
Users browsing this forum: Google [Bot] and 11 guests
