Re: WHAT YOU DID TO YOUR TRUCK TODAY! by kingfisher on Fri Jun 05, 2009 12:51 am
does a body lift improve the handling , as when i go round islands especially in the wet it does slide about a bit :?:
kingfisher
Vehicle Name: The money pit
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Jun 05, 2009 12:57 am
Theoretically at least a body lift should make the handling worse as you are raising the centre of gravity, you still have the main heavy stuff sitting at the lower height like the gearbox, engine and axles but you are increasing the height to weight ratio,.
A body lift other than that has no effect on the suspension.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Fri Jun 05, 2009 1:08 am
Phew!
Fitted a new gearstick plastic bush thingy,
Cleaned all the old broken glass from around the window in preparation for new glass.
Fitted the new trailing arm that I got from Alex (Ta very much again Alex!)
Finally worked out how to seal the Cat to exhaust centre section without the stupid wire mesh gasket coming loose.
Fitted some exhaust wrapping to the manifold and Cat in an attempt to reduce under bonnet temperatures.
Got the new tyre fitted to the rim to replace the one that was skewered in the accident, I now have my spare back. The garage didnt even charge me for it :D :D :D
Many thanks Dovey Autocraft.
Started cutting some plastic drainpipe in an attempt to make some wider wheelarches.
Made a new locking wheel nut remover with a grinder and deep 15mm socket as the proper one broke (all 4 studs snapped off). I have successfully removed 3 of the blighters but the 4th and final one still resists all my attempts and one liners.
Set the time on the clock ;-)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by weave67 on Fri Jun 05, 2009 5:33 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Fri Jun 05, 2009 9:23 pm
good going Phil, is she road worthey now?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by cheekychick on Fri Jun 05, 2009 10:18 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Sat Jun 06, 2009 2:37 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sat Jun 06, 2009 10:51 pm
i started to play with my new tank guard, thank Jase
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Jun 06, 2009 10:54 pm
Thats BLING 8) :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sat Jun 06, 2009 11:16 pm
its not staying like that, god save the queen, (a clue)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Jun 06, 2009 11:19 pm
:wink: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Sun Jun 07, 2009 1:52 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Sun Jun 07, 2009 6:23 am
union flag :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by weave67 on Sun Jun 07, 2009 8:03 am
well over the weekend i was hoping to do a 2"body lift on the dirty diesel,but intead all ive done is watch the rain,fall on my frontera :cry:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sun Jun 07, 2009 10:52 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Roo on Sun Jun 07, 2009 1:12 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by woodwizzard on Sun Jun 07, 2009 3:08 pm
Haven't had to fix anything for awhile (jinxed it now) so just keep on working it, shifted 10 ton of stone onto a woodland track, got well stuck, freed by the winch, got soaked and filthy dirty (me and the truck) and then came home. Got offered £800 for my truck but turned it down, does its job too well :)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by weave67 on Sun Jun 07, 2009 3:13 pm
you know it makes sense jimbo :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Krusher on Sun Jun 07, 2009 5:18 pm
freed off the seized rear brake caliper ready for MOT retest :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Jun 07, 2009 9:01 pm
Ive fitted new front discs and pads, all went fine but for one stubborn slider, but I beat the git.
It sounds like one disc is rubbing on the mud stone guard on one wheel, so out with the screw driver to bend it back tomorrow.
My brake caliper rewind kit came in handy :dance:
