Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Mon Mar 19, 2012 6:36 pm
Will have a look at the annual
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Mon Mar 19, 2012 6:44 pm
Looking nice Rob :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by horses45 on Mon Mar 19, 2012 6:50 pm
and all by myself :D now to try it out on a run tonight lol
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Mon Mar 19, 2012 6:53 pm
Get yourself up the lane on sidnope hill dude! i did it up and down yesterday n it was awesome!! :wink:
:D Nothing to the truck but have ordered
http://www.4x4cb.com/public/item.cfm?it ... N=61795570
thats one less thing for strata :D :D
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by kees on Mon Mar 19, 2012 9:01 pm
Finished putting together after doing head gaskit :dance:
kees
Now sold, A series Frontera.
FOG sticker
1997/ p reg 2.2i
Now sold.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Mar 19, 2012 9:24 pm
Passenger window winder.
Tested the new motor on the battery and it worked fine ... result!
Pulled the passenger door card off again (takes me less than a minute including all the handles, ash tray, etc etc) ... result!
Wrestled the mechanism out of the door without breaking the glass ... result!
Compared the Mk.II/III mechanism to my Mk.I version. Although different levers etc the motors were exactly the same apart from the plugs ... result!
Swapped the motors over on the mechanisms and got it back into the door without breaking the glass ... result!
Jury rigged the wiring together and pressed the down button on the drivers door. Window went down ... result!
Pressed the up button and nothing happened ... ar$e!
Pressed both buttons on the passenger side switch and nothing happened ... ar$e!
Remembered that I had 3 spare switches in the garage ... result!
Realised it was now dark ... ar$e!
Trashed the neatly stacked piles of Trooper spares all over the floor in an effort to find switches, as I couldn't really see what I was doing ... ar$e!
Found switches ... result!
Tried all three and no better ... ar$e!
Reversed the wiring on the motor where I jury rigged it and window wound up, meaning window is now shut again ... result!
Got old motor and pulled back the wires and tested it directly on the battery, only to find it works both ways ... was an ar$e of a result!
Realised I might as well put the old motor back on as that means I don't have to start messing about soldering new plugs/terminals on the "new" motor ... result!
Realised I spent approx £20 on a window mechanism I didn't really need ... ar$e!
Couldn't be ar$ed to pull the mechanism out again so slung the old motor and spare switches in the boot of the truck and taped up all exposed wires ... ar$e!
Put the door card and respective switches, handles, ash tray etc on again in less than 30 seconds (starting to time myself now) without breaking anything ... result.
Back at square one, but this time I now realise I have to diagnose a dodgy electrical system on a 22 year old vehicle with no wiring diagram ... ar$e!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Mon Mar 19, 2012 9:28 pm
Jim Royle could have written that post RC :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Mon Mar 19, 2012 10:28 pm
today i fitted my winch soniolide pack and then went out laneing with dan and got to test it
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Mon Mar 19, 2012 10:30 pm
you had to test it ? who got stuck ? :D
& your post was funny in an unfunny way RatCav :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Mar 19, 2012 10:43 pm
At least I am slowly getting to the cause of the problem Fogman. One day I will have an operating passenger window ... one day.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JEOH on Mon Mar 19, 2012 11:04 pm
Kind regards,
Sorry for my pigeonenglish.
JEOH
Vehicle Name: Gentile
EX-GIGANTE (1998) 2018-2022
General Grabber AT2, Soft-Top
G-Wagon Mercedes 300GE 1990
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Mon Mar 19, 2012 11:21 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Mar 19, 2012 11:26 pm
I feel a little sick now of that thought :sick:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Tue Mar 20, 2012 8:13 am
No that sounds about right for our Gregster!!! :mrgreen: :mrgreen:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Tue Mar 20, 2012 9:05 am
:butt: :butt: :butt:
I guess a 2.5 without a glowing eml light could be classed as somewhat naked I suppose! :lol: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Tue Mar 20, 2012 2:01 pm
Igotababyfrontera, good choice of CB. I got the same one for mySWB and a mates Disco, that was 3 years ago and they're both still going strong, the auto-squelch is a big bonus. The only downside is you can't change channels from the mic, though I've never missed that function that was on my previous rig (used to dap the wrong but and change channel inadvertently).
I'm sure you'll be please with it. Supplier has a very good aftersale service with info and other help should you need it.
Regards
Stuart
Fatbaz
Hankook RT03 285/75R16
50mm body lift
:D sweeeet :D
Nice to know I got something right :D
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Tue Mar 20, 2012 2:06 pm
changed the rear dif pan for a 2nd hand one due to having a slight leak & presumed it was holed, once off & inspected inside it looked solid & ok :shock: so it must of not been sealed at the top properly or the connector for the breather pipe was leaking.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by stevd on Tue Mar 20, 2012 2:14 pm
Just found a pic of when my truck was clean, prestine and scratch free with nothing broken......oh the distant memories!!!!! So I have been inspired and tried to clean it up, only to reveal more rust and scratches, should have left it dirty.
stevd
3.5" wind up on front
pro Comp Shocks
Side step removal
Bonet Guard
A fair amount of scratches
Lots of rust to add character
16" alloys from an A Series
Silicone vac pipes
