Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Mar 10, 2012 4:25 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sat Mar 10, 2012 4:33 pm
and as promised pic's and little write up. if any one would like me to do a full write up just ask and i will.
so first of all get one winch
then remove nearly all the front of your fronty and sit the winch in it desired location, mine is on top of my recovery bar.
cleck it is in right position and correct way round
then i tacked the winch tray into place.
then get bumper and check fitting and if you need to do any adjustment do so
then offer up your bullbars and see what you need to remove from thoes.
luckly i did know what i needed to remove, and it was only one tube.
so then it is all looking right, remove bullbars and weld the hell out of it. and then refit the bullbars
now all i need is the control box(on order) and then some new rope
Sod all :evil:
I can't hold the tools never mind do anything with them :evil:
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Sat Mar 10, 2012 6:58 pm
Transported the last of the 4 tonnes of brick and rubble sat on my drive. This thing really pulls well with serious weight in it :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Mar 10, 2012 6:59 pm
had a bit of work to do on Bob the 2.5 today :lol:
2" suspension lift with springs from mark (mgautos)
replaced rear anti roll bar drop link's
replaced the rear diff cover with one from Christine (was new 6 month ago for £10) :D
replaced top radiator pipe with a new one from VX £10:62
with the 2" suspension lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by wideformat on Sat Mar 10, 2012 7:37 pm
Jet washed half a hundred weight of mud off the underneath off my truck, fitted a new recovery point on the rear tow bar for the trip to Strata next month and checked the swr on my CB after repositioning the antenna :thumbup:
Still think the rear brake may be binding on sometimes, may need further fettling :thumbdown:
wideformat
Vehicle Name: More Trouble
CB Radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Sat Mar 10, 2012 7:46 pm
Almost certainly the caliper WF. Not difficult to refurb and free as long as the rubbers aren't split
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by wideformat on Sat Mar 10, 2012 8:05 pm
wideformat
CB Radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sat Mar 10, 2012 9:24 pm
Stuck 15 liters of bio diesel in the trooper got to say the 2.8 runs better on the bio than the 2.5 did and it gives better running compared to diesel.
I also fitted battery to the swb trooper and freed of the alternator just got to get it re fitted
edit for my spelling
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Sat Mar 10, 2012 9:29 pm
WF - some wire wool would be handy. Assuming the main piston rubber isn't ripped, extract the piston from the caliper and polish the piston with the wire wool, also get the wire wool in the piston chamber and carefully remove grit/rust from the ring . Polish caliper slides with wire wool, grease and refit.Refit piston, and Robert's yoru fathers brother :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by wideformat on Sat Mar 10, 2012 10:19 pm
wideformat
CB Radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Sun Mar 11, 2012 12:37 pm
finally fixed the passenger window,it now goes all the way down & up again which is a bonus :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sun Mar 11, 2012 12:44 pm
Do you want to come over and do mine Foggy ... mine doesn't move at all. That is a bigger challenge.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sun Mar 11, 2012 2:28 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by taylor6632 on Sun Mar 11, 2012 3:05 pm
Wired in my roof spots and will be testing later this evening.
Also, shopping around for a wing mirror at local breakers yards as it was smashed off on friday! AHHHH! Nothing around bristol with frontera's in.....
taylor6632
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Sun Mar 11, 2012 5:01 pm
Decided to go green laning today - on foot!
There's a lane that I've known about which starts literally 65 yards from my front door, but I've never bothered to investigate before :oh yer: Well as the sun was shining I decided to take a wander up with the dogs to check it out. Turns out it's a bloody cracker!! Can't believe I've never bothered to go up there before :oops: :oops:
This is the start of the lane
With some pretty decent drop off's
Major incline all the way up with rocky / mud surface
This was outside the farm on the lane which made me chuckle .... :lol:
And the view from the top isn't bad either 8)
You can just about make out the paragliders in the distance (crappy camera phone)
As usual the camera doesn't do any of it any justice , but I'll be driving this very very soon!
Rest of the pics can be seen here > http://s54.photobucket.com/albums/g85/b ... =slideshow
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Sun Mar 11, 2012 5:13 pm
Finally got round to fitting the rear light guards I bought off Drinks Optional a few weeks ago...
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sun Mar 11, 2012 5:55 pm
Well did'nt do it to mine but had some fun working on Horses45 and adding his new spings and shocks!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Sun Mar 11, 2012 6:11 pm
Landy springs ?
That's a nice lift at the back :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Sun Mar 11, 2012 6:16 pm
:thumbup: Looking cracking that now boys!! Just in time to try it out next sunday :dance: :clap: ! Will you be joining us Bobby?????? :think:
