Frontera Technical Support • View topic - Technical help and advice wanted please?
Personally I've given up on Garages, main agents and the like.
I'd rather spend my money on an old banger which will get me about until I can find out how to fix my motor cheaply and properly myself.
I don't have a workshop so I have to wait for good weather and when the problem is fixed I sell the banger and go back to the origional motor.
If I cook it up it's my fault end of story. If a Garage fooks it up I still have to pay. DIY takes longer but you know where you are.
Good judgement comes from experience and experience comes from bad judgement.
At least you aren't a poor Haitian about to be shafted by the Americans yet again.
Frenchfarmer
It works!!!!
Re: Technical help and advice wanted please? by lloyd on Wed Jan 27, 2010 12:40 am
There's much truth in that, French Farmer. I always used to do all my own work on previous vehicles, because I felt that a garage mechanic is casual and just earning his pay. I on the other hand would treble check everything to be certain because I was well aware of my weaknesses. At that time I was buying MG Midgets, Austin Healey Sprites , Spitfires and GT6's and doing them up over winter in my garage. If I got it wrong I learned the hard way. With this vehicle and my current job, I took the easy route and decided to pay sopmeone rather than do it myself in bleak midwinter but am now in a confustication (cluster f**k) of half truths, ambiguity and lies. I depend heavily on this forum and the many helpful posters, and would be lost without it, so thank you all.
lloyd
Registration Year: 2004/04
Vehicle Name: Aaaaarse
Re: Technical help and advice wanted please? by lloyd on Thu Jan 28, 2010 12:39 am
A few pics of my pots and the emulsification which only became apparent after head removal.
Not checked, but you may also be able to see the crack in the exhaust manifold in the first one?
lloyd
Re: Technical help and advice wanted please? by fogman on Thu Jan 28, 2010 1:15 am
looking at your 1st pic are you going to give your egr valve a clean while you can get at easily now the heads off ?
is that the breather pipe with what looks like custard in it in the 3rd pic ?
Re: Technical help and advice wanted please? by lloyd on Thu Jan 28, 2010 1:25 am
Too late for that as he put the head back on wile I was at work. The mayo pipe goes off the back of the head towards the bulkhead and down, if that helps?
lloyd
Re: Technical help and advice wanted please? by fogman on Thu Jan 28, 2010 1:28 am
pity about the egr valve mate :|
i think the mayo/ custard pipe is the crankcase breather pipe
Re: Technical help and advice wanted please? by lloyd on Thu Jan 28, 2010 1:44 am
If so shouldn't cause too many probs and gradually clear itself then. I hope.........
What do EGR valves do?
lloyd
Re: Technical help and advice wanted please? by fogman on Thu Jan 28, 2010 1:41 pm
in another thread sir doris suggested that its not unusual for the pipe to collect mayo through the winter so i suppose that you clean as much out that you can before refitting :|
egr valve info - http://answers.yahoo.com/question/index ... 814AAK001R
Re: Technical help and advice wanted please? by lloyd on Thu Jan 28, 2010 6:35 pm
Good plan.
I wonder why only in the winter?
lloyd
Re: Technical help and advice wanted please? by fogman on Fri Jan 29, 2010 5:16 pm
my head was stripped today & ive got a mayo filled crankshaft breather pipe as well :|
Re: Technical help and advice wanted please? by lloyd on Sun Feb 14, 2010 3:14 pm
Well, £981.61 and six weeks in total later, she's running again. :D :drink:
However.........New development, related I think to standing so long in all weathers, maybe.......When I brake I get a rhythmical knocking through the brake pedal. The faster the road speed the faster the knock and vice versa. Any ideas, anyone?
lloyd
Re: Technical help and advice wanted please? by Drift on Sun Feb 14, 2010 3:44 pm
Hi Lloyd, post the question about the brakes in the brakes section of the forum then any info gleamed on that particular issue is not last in a long thread about other issues and thus may help others, plus its more likely to get better technical answers in the correct area 8)
Glad its sorted bud. Brakes are probably just rust scale buildup which will wear off shortly.
Re: Technical help and advice wanted please? by lloyd on Thu Feb 18, 2010 10:46 pm
Yep, thanks SD, all sorted now. And with the slightly increased compression post-skim I believe she's a mite quicker too!
lloyd
