2.2 petrol frontera drinking petrol water
South of Birmingham
Yeovil to cornwall incl sw
2.2 petrol frontera drinking petrol water by babspayton on Sun Apr 04, 2010 10:43 pm
drinking petrol +water what be problem how to fix it) is doing about 12 to gallon at moment no oil leaks have fixed the water problem with k seal but still smoking white smoke . there is no oil in the water any ideas???
babspayton
Re: 2.2 petrol frontaire eating petrol water by domino on Mon Apr 05, 2010 9:53 am
Welcome :)
- Is there oil in the water?
- Any 'mayonnaise' kicking around under the rocker?
- Any leaks in the system? Checked the rad pipes? Are there pools of liquid under the vehicle when it's been sitting for a while?
domino
Sleeper
Model: 2.5 TDS Transglobe 5dr
Think this needs moving to the tech section where you will get more help :)
Re: 2.2 petrol frontaire eating petrol water by andysd1 on Mon Apr 05, 2010 11:18 am
hi, would you be, Gordon James Paton,
some more info would be good,
how much water a day or week, how much fuel
hi
its doing about 12 to the galllon have put k seal in water which seems to have stopped the water problem. but still using fuel and white smoke from exhaust
babspayton
have you checked the tank for leaks, but it does sound like your head gasket has gone,
thankyoui everyone yes it was the head gasket
babspayton
Return to South West
