Frontera Technical Support • View topic - Pay and Play Day at Whaddon 4x4..Anyone fancy it?
Ok so i am pretty sure Paulhooligan will be in as he like I lives 5 minutes up the road but I though it would be very antisocial not to invite you lot :D
So http://www.whaddon4x4mx.co.uk/opentimes.html for the dates..
I can't do this weekend as I may not have The Hulk back or the the 28th as I will be at Knockhill or the 11th Nov as its the wife and I birthday weekend (we are both on the 8th)! So.. Anyone up for December 9th? or 23rd?
geeks
Vehicle Name: The Hulk MK2
Modifications: To Come:
Stuff...
Also:
The Beast (2.8 SWB A Series)
Previous:
Skype Username: geeksandlies
I could be tempted, the December dates almost certainly.
It's actually closer to me than the SE woods.
Something on this forum about this
viewtopic.php?f=32&t=48652
It's still a bit alarming though
bhcalcutta
Intek CB
Kenwood head unit
wound up torsion bars
monroe adventure front shocks
avm manual lockers
Modified TLC80 Snorkel
Trooper clutch
flappy paddle delete
egr delete
Hmmmm a quick google and some research shows people who have been recently i.e from then on have been happy with the place although are all cautious about leaving wagons there so... In the event that anyone is unable to drive their fronty home they can leave it on my driveway if needs be i live 5 minutes round the corner so can tow you back and you will have somewhere a bit safer to leave it untill you get it sorted.
Other reviews on the site seem positive but caution is advised as its easy to get stuck, but that could be said for anywhere i guess! If we organise ourselves then we can make sure no one gets stuck and someone is available to do the tow outs!
I say we press ahead :D
geeks
Stuff...
Also:
Previous:
Folks,
Whaddon site is a bit old site, with plenty for everyone, some flat some more iutted, boggy areas dont enter if you have no way of winching out. Some very wet and deep areas.
Just depends what you want to do, what allegedly happened with vehicles up there has nothing to do with you having a good day on the site.
You pay you money and you drive where you want.
However i went there a couple of weeks ago with my local 4x4 club, northants4x4.com and i have had to remove and clean alternator and have got to strip rear drums as i have lost the use of the handbrake, probably full of silt.
So if its your everyday car make sure you give it a damn good clean after, the silt there gets everywhere.
Pete
Loneranger
2 inch suspension lift
2 inch Body lift - pending
33" KL71 mud tyres
winch
Thanks for that Pete. So you in as well? :D
geeks
Stuff...
Also:
Previous:
Sorry guys, didnt mean to pee on your bonfire, so to speak by posting above, I was just googling reviews to see what the site was like and came across the thing about car thefts, so thought it prudent to post it up incase it was still an issue. The fact that they are still operating after this time would tend to suggest this was an isolated incident I would think, and there are always two sides to every story.
Indeed, as long as we are sensible about it then all should be ok :D
So you in Gregster?
geeks
Stuff...
Also:
Previous:
Would have to see nearer the time, but i did promise the truck that i wouldnt put her through that clap again, been off the road for two weeks.
But never say never....
Loneranger
33" KL71 mud tyres
winch
Pete, you take your truck through there again and I might have to give you a poke in the eye to make you see sense!! Seriously peeps, Whaddon is a truck eater unless you just pussy around watching the headcases play hero.
It's a steep descent into the site, across a stream with a loose base then up the steep side of the field opposite. Once you make it this far there are some easy tracks linking the play areas. This time of year you will need mud tyres to get this far. LWB's with out a lift can expect to belly out regularly, what you have to bare in mind is this site is regularly abused by Mega tyred (33's, 35's and 37's), lifted green ovals that take great delight in spinning holes in ruts, wollowing in mud holes and generally ripping the site up, as is their right.
If your truck is just for play sites fine but if you want to keep it reliable and in road useable condition think twice about going to Whaddon!
Just my opinion, but an opinion based on experience of the place.
Regards
Stuart
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Sounds like a good bit of advice there FatBaz...certainly to stay out of the deeper stuff...
Realistically I wont be able to make it Geeks...time/finances/need the truck being the main factors, and trailering up the BGL just adds massively to the £££ sadly.
