[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead Frontera Technical Support • View topic - broseley 4x4 28th nov
Modifications: nothing........really, A set of A series rims (31" kl71's) +2" nice orange springs (mgautos) +2" rough country shocks (mgautos) 40mm Body lift Flipped top ball joints Steel belly pans Rear recovery points CB radio in glovebox Rear work lights A big fat 12v power cable to the boot 1 Farad power cap H.I.D Headlight Conversion Roof rack with 4x55w lights on DVD head unit Twin amp & Twin sub setup Playstation 3
I'll just fit a tow rope front and bk and hope for the best at least with a standard car I won't be able to go 2mad now what tow ropes to get 3/6 meter or wire or rope any idears??
