// Frontera Technical Support • View topic - Fronty4x4spares...Quality Used Parts, rapid delivery.
Re: Fronty4x4spares...Quality Used Parts, rapid delivery.
Postby gregster on Fri Apr 28, 2017 11:38 pm
2.2i clutch and flywheel from an A might work...think I have one here...
Postby Furryroo on Sat Apr 29, 2017 2:41 pm
is the 2.2i flywheel a 6 bolt or 8 bolt flywheel? the redtop is 8 bolts annoyingly and everything else seems to be 6 bolts, the 2.2 in my B is only 6 bolts wheras the V6 ones are 8
Furryroo
Vehicle Name: Tonka
Modifications: Standard
Postby gregster on Mon May 01, 2017 3:55 pm
I will have a look tomorrow when I am back at work, having a chill out BH weekend and some time off...
Postby gregster on Tue May 02, 2017 3:14 pm
2.2i A is 6 bolt flywheel sadly
Postby RatCav on Tue May 02, 2017 4:10 pm
Redtop flywheel part number is 90448559 if that helps. Used on following applications.
Postby Furryroo on Tue May 02, 2017 7:55 pm
Thanks for the info, the issue i am having is finding a flywheel that is the correct thickness to fit so that the clutch will reach, a standard C20XE one is sadly not thick enough, i have purchased a Vectra V6 one as it looks very similar and is an 8 bolt flywheel so hoping that one will fit
Furryroo
Vehicle Name: Tonka
Postby Furryroo on Sat May 06, 2017 2:24 pm
yep! Vectra V6 flywheel is the same size as the 2.2i flywheel only difference is 8 bolts instead of 6 just in case anyone else wants to redtop a frontera, again thanks for the info!
Furryroo
Vehicle Name: Tonka
Postby boatmover on Tue May 16, 2017 9:53 pm
Hi. I am looking for another head if poss.
2.2 Ltr petrol. X22se engine block code if that helps.
Thank you
2.2 ltr petrol lwb 5dr.
boatmover
Vehicle Name: money pit
Modifications: front towbar only
Postby gregster on Tue May 16, 2017 11:13 pm
boatmover wrote:Hi. I am looking for another head if poss.
Thank you
PM sent
Postby sarge on Sat Jun 03, 2017 2:24 am
Received the rear bumper and interior assist handles for the 2.8dti on Friday afternoon
Thanks Greg for excellent service and quick delivery
Mikec
sarge
Postby gregster on Mon Jun 05, 2017 1:17 pm
Cheers Mike...much appreciated.
Postby Ricko on Wed Jun 07, 2017 9:16 pm
Hi Greg, I'm after a factory drivers side floor mat, have you got one?
Ricko
2000 Vauxhall Frontera 2.2 DTI Limited LWB
Ricko
Modifications: Completely original!
Postby gregster on Fri Jun 09, 2017 9:05 pm
Most are worn bud...You might do better trying the european ebay sites where your drivers matt is there passengers one.... :wink:
Postby Ricko on Sat Jun 10, 2017 9:04 am
Good shout, I'll try that!
Ricko
Postby Furryroo on Mon Jun 19, 2017 7:29 pm
Hey
i dont suppose you have a B series SWB boot door with glass do you? prefferably in Arden blue (paint code 12L)
Furryroo
Vehicle Name: Tonka
Postby red5 on Tue Jul 25, 2017 4:50 pm
Hola Greg et al,
am after a VX detachable towbar for a A series - PO seems to have misplaced it.
Cheers,
Sam
red5
Some dentage.
Postby Greekfronty on Mon Sep 04, 2017 9:12 pm
Hi I am looking for the rear window (LH) drivers side electric motor from a LWB frontera?
Greekfronty
Modifications: New wheels Irmscher 17" on with 245/65 michelin tyres, xenon H.I.D. kit 6000K, K&N Air Filter,
Postby gregster on Thu Sep 07, 2017 4:03 pm
Yes I have these....if you pm me your address details I will price up shipping for you.
Cheers Greg
Postby Bearcat on Thu Sep 07, 2017 7:10 pm
Hi Greg, Have you got a fuel lift pump for a 2.3TD ? also after searching for 8 years, an oïl tempreture thermostat, and a rear alloy Wheel hub cover ? regards Peter.
Bearcat
Registration Year: 1994/M
Vehicle Name: Cat-Cat
Modifications: No Mods
Postby 4x4lover1 on Sun Dec 03, 2017 10:01 pm
I'm
Agyerthesidesteps mines a five doir2.2i
4x4lover1
Vehicle Name: 4x4loverdiscreet
Modifications: Colour match
2.2i petrol limited edition
