// Frontera Technical Support • View topic - Fronty4x4spares...Quality Used Parts, rapid delivery.
Re: Fronty4x4spares...Quality Used Parts, rapid delivery.
Postby gregster on Tue Jul 19, 2016 1:56 pm
bryn wrote:Hi Greg,I'm after a brake servo vacuum pipe for a 2.2 dti b series frontera if you could help please
Bryn
Sorry only just saw this...Which pipe is it that you need, the rubber pipe down to the pump from the cross pipe?
Postby PeterFD on Wed Jul 27, 2016 6:20 pm
Hi Fronty4X4spares.
I've go a Frontera estate 3.2i (V6) year 2000 (W reg) - and the cylinder head gaskets have just blown in a big way - possible oil pump/big-end-bearings problems etc. :cry:
I noticed you've got an engine for exactly the same model (W-reg) for sale on e-bay at a fantastic 250 pounds. However, can you ship economically to France? :)
The photo on ebay is exactly what I want and I'm assuming my local garage can simply remove my battered engine and install your replacement.
If what you see is what you get, I'm assuming everything is included once the cables and fuel line is disconnected (allowing for the separation from the gearbox - is the clutch etc included to allow a simple "back-end" attachment to the gearbox?).
Your ebay text has been recently amended to state that the engine is now out of the vehicle - any chance of a couple of photo's to pass onto the garage?
I hope you can help,
Many thanks,
Peter
PeterFD
Registration Year: 2000/V
Postby gregster on Thu Jul 28, 2016 11:17 am
I have sent you a message Peter...
Postby madmadmic on Sun Aug 07, 2016 12:23 pm
Hi guys,after both wings and inner plastic splash guards for a SWB a series and front bumper,Cost including postage to DN16 1LG please. Thanks Mick.
madmadmic
Modifications: Jeep Cherokee XJ 4.0,sprayed desert sand colour,Led spot bar and led work spots a the rear, 3 core aluminium radiator, silicon hoses, 4.5 inch lift . The 15" gloss black steel wheels matching A\T tyres,
Postby gregster on Sun Aug 07, 2016 5:46 pm
Will have a look tomorrow and see what we have got Mick...
Greg
Postby migbrikev on Thu Aug 11, 2016 11:07 am
hi there looking for a throttle body/throttle position sensor for mkII frontera 2.2dti ,,y22dth ,,
migbrikev
Postby bryn on Sun Aug 14, 2016 12:16 pm
Bryn
Yes that's the one.Sorry about the late reply I've been away working
bryn
Postby gregster on Sun Aug 14, 2016 1:32 pm
migbrikev wrote:hi there looking for a throttle body/throttle position sensor for mkII frontera 2.2dti ,,y22dth ,,
I havent one at the moment, but will give you a shout as soon as I get another one.
Cheers Greg
Postby bryn on Sun Aug 14, 2016 5:25 pm
Cheers Greg
Cheers Greg
bryn
Postby Spikey on Sun Aug 28, 2016 1:26 pm
Hi Greg, would you have a the offside rear quarterlight for a 99 plate 3 dr 2.2i Sport hardtop? Or would it just be easier to plate it?
Cheers in advance.
Spikey.
Frontera B Sport 2.2i 16v
Cardio, check the back seat, double tap
Spikey
Vehicle Name: Bug
Modifications: Dents and scrapes :\
Postby lee771 on Thu Sep 01, 2016 7:58 am
Hi Greg
I'm after a tank carrier and a steering box for a 2.0 sport.
Thanks
Lee
lee771
Modifications: +2" suspension
33 12.5 15s
-32 offset steel rims
Landrover arch extension
Postby gregster on Thu Sep 01, 2016 8:16 am
Spikey wrote:Hi Greg, would you have a the offside rear quarterlight for a 99 plate 3 dr 2.2i Sport hardtop? Or would it just be easier to plate it?
Cheers in advance.
Spikey.
Havent got one at the moment sadly, have been asked for a few of these lately, so will pull them out of the next sport B we get in. Sorry
Postby gregster on Thu Sep 01, 2016 8:19 am
lee771 wrote:Hi Greg
Thanks
Lee
Hi Lee...I have steering boxes on the shelf, and a couple of usable tank guards...Give me a ring on 01622 739908 after 10 and we will sort you out, can have these shipped today on a 24hr service so you should have them for the weekend.
Cheers Greg
Postby lee771 on Thu Sep 01, 2016 5:57 pm
Sorry mate only just seen this will bell you in the morning!!
lee771
33 12.5 15s
Postby gregster on Thu Sep 01, 2016 6:37 pm
No problem lee...will be in the office from 10. Cheers Greg
Postby Fatbaz on Thu Sep 01, 2016 11:08 pm
Hi Greg
Looking for the complete front axle for a 2.8 swb with a 4.56:1 ratio. What you got and how much. might need a complete steering column as well if you got such a thing......one would imagine you have plenty.
Regards
Stuart
Fatbaz
Modifications: Suspension lift curtesy of TJM +2 springs
Hankook RT03 285/75R16
50mm body lift
Custom built winch bumper
Trooper axles front and rear LSD
LED head lamp bulbs
Postby gregster on Fri Sep 02, 2016 2:03 am
Hiya mate...have these in stock...give me a ring tomorrow on 01622 739908
Postby Spikey on Thu Sep 22, 2016 1:46 pm
Hi Greg, due to a slight accident involving a dry stone wall i'll be needing the following bits if you have them
NSF Hub carrier (Complete if possible)
NSF indicator lens
NSR light cluster cover
NSF wing *colour not important, and whole things going matt black anyway*
Thanks in advance.
Spikey
Vehicle Name: Bug
Postby gregster on Fri Sep 23, 2016 10:00 am
Hiya...your parts are on the way. I also have wings and front indicators in stock, when you are ready just give me a ring on 01622 739908.
Postby Spikey on Fri Sep 23, 2016 3:18 pm
gregster wrote:Hiya...your parts are on the way. I also have wings and front indicators in stock, when you are ready just give me a ring on 01622 739908.
Cheers Greg :)
Checked the tracking, and it seem's they are delayed. Nowt we can do about it though, so it's a case of wait an see... Ah well, couple more days won't make much difference.
Spikey
Vehicle Name: Bug
