// Frontera Technical Support • View topic - Fronty4x4spares...Quality Used Parts, rapid delivery.
Re: Fronty4x4spares...Quality Used Parts, rapid delivery.
Postby RockingDad on Mon May 23, 2016 6:54 pm
Hi, I think my radiator fan is balked! connected direct to the battery and nothing (Although closed circuit). Its a 99 A 2.0l Sport Transglobe. Do you have one you can supply?
RockingDad
RockingDad
Registration Year: 1999/S
Vehicle Name: Transglobe
Modifications: General Grabber AT's
Postby Sir-Doris on Tue May 31, 2016 2:22 am
Hi Greg.
Out of curiousity can you maybe check something for me please.
I have an A series 2.2i with the 2 piece prop. Always fancied fitting a 2.8 single as with the lift the driveshaft angles are a bit extreme at full stretch.
I see on your ebay shop you have a 2.8 and a 2.5 prop for sale. Could you measure them and let me know if they are the same length please.
Definitely the 2.8 prop is shorter then the 2.2 one (total length).
Cheers bud.
Phil
Postby RatCav on Tue May 31, 2016 11:51 pm
Thought the 2.2 was 4 bolt flange on the transfer box, as opposed to the sliding yoke of the 2.5/2.8
Postby gregster on Wed Jun 01, 2016 12:54 pm
2.2 still uses a slip yoke Ratty, but with a 2 piece prop...same as 2.3
Postby RatCav on Wed Jun 01, 2016 3:03 pm
Must be thinking of the B series .. or just confused :D
Postby gregster on Wed Jun 01, 2016 4:52 pm
B's are all flange bud....
Have you unpacked your giant pressy to yourself yet? LOL
Postby RatCav on Wed Jun 01, 2016 8:22 pm
Yup .. need to fit the clutch and drop it in so I can play with making engine mounts.
Postby Sir-Doris on Wed Jun 01, 2016 10:01 pm
The slip yokes are the same diameter and spline count.
I have a 2.8 prop but Im unsure if its from a SWB or a LWB and definitely shorter then the 2 piece. In either case its knackered as its been sitting outside for years and the slip bit is rusty and pitted and would damage the seal.
If you could help me out with the dimensions Greg it would be much appreciated as If long enough Ill have one off you. Even if its a bit short i could lengthen the prop itself.
Postby andytats on Wed Jun 01, 2016 10:04 pm
Sir-Doris wrote:Hi Greg.
Phil
If I remember right the 2.5 prop is about 1.5 inches longer than the 2.8
Postby Sir-Doris on Wed Jun 01, 2016 10:09 pm
Interesting. It may be something to do with the dimensions of the engine or its location in the engine bay. If memory serves me correctly I was under the impression all the '95 - '98 had the same gearbox.
Postby RatCav on Wed Jun 01, 2016 11:21 pm
The 2.8 had a spacer (probably about 1 1/2") between the engine and gearbox, to account for the DMF. On the Trooper the 2.8 and 3.1 had sprung clutch plates and no DMF, so no spacer. I assume that accounts for the difference.
Postby Sir-Doris on Fri Jun 03, 2016 9:57 pm
So a 2.5 prop may fit the bill.
Postby fudge on Sat Jun 04, 2016 9:37 pm
hi greg
is there any chance you have a coil pack from a c20 or c24 frontera? and the loom connection as i believe mine is on its way out
Postby gregster on Sun Jun 05, 2016 3:58 pm
The c20ne and c24ne didnt have a coil pack Fudge, they had a coil to feed the dizzy...
Postby dazza on Tue Jun 07, 2016 8:30 am
Hi Greg, do you have any power steering pipe for a 2003 v6
cheers Dazza
If its clean your not having fun!!!!
UTRINQUE PARATUS
(Ready for anything)
Humber-Yorks 4x4 Response training team HY44
dazza
Modifications: lpg
Postby fudge on Tue Jun 07, 2016 7:34 pm
gregster wrote:The c20ne and c24ne didnt have a coil pack Fudge, they had a coil to feed the dizzy...
Well that is what i ment by coil pack... the coil....
Postby twohoots on Tue Jun 07, 2016 7:48 pm
Hi, would you have a front ABS sensor left hand side for 3.2 '02? Thanks....
twohoots
Registration Year: 2002/52
Postby gregster on Tue Jun 07, 2016 9:20 pm
dazza wrote:Hi Greg, do you have any power steering pipe for a 2003 v6
cheers Dazza
Should have mate, which ones do you need?
Will have a look tomorrow...should have one bud
Postby gregster on Tue Jun 07, 2016 9:22 pm
twohoots wrote:Hi, would you have a front ABS sensor left hand side for 3.2 '02? Thanks....
Should have one later in the week hopefully....we sell them in the hub/stubaxle as is risky trying to remove them, but that then renders the car immobile. Will let you know when I get one off.
