// Frontera Technical Support • View topic - Fronty4x4spares...Quality Used Parts, rapid delivery.
Re: Fronty4x4spares...Quality Used Parts, rapid delivery.
Postby Pete Stewart on Mon Apr 18, 2016 7:17 pm
Hi I was looking for side steps for 2001 2.2 DTI LWB & can pay postage
Pete
Pete Stewart
Postby gregster on Thu Apr 21, 2016 11:34 am
I might have a pair next week, if you message me your postcode, I will price them up with shipping for you when I get them off.
Greg
Postby Pete Stewart on Thu Apr 21, 2016 12:40 pm
Thanks Greg
I live in Belfast
BT7 2FW
cheers & hopefully I can get the fuel pump sorted in between then (currently replacing the leak pipes as you suggested)
Pete
Pete Stewart
Postby Mickey boy on Fri Apr 22, 2016 8:57 pm
Hi Gregster, I'm after a grey rear headrest for my 51' plate v6 LWB frontera, interior is full cloth, no leather.
Thanks mick.
Mickey boy
Postby bhcalcutta on Thu May 05, 2016 5:33 pm
Hi Greg...Have you by any chance got any manual lockers in?
bhcalcutta
Intek CB
Kenwood head unit
wound up torsion bars
monroe adventure front shocks
avm manual lockers
Modified TLC80 Snorkel
Trooper clutch
flappy paddle delete
egr delete
Postby JEOH on Sat May 07, 2016 5:54 pm
Hallo Greg,
hast Du vielleicht einen vorderen Kotflügel
beeeeeeeeeeeeep wrong mode***falscher Modus*** wrong mode***
Hi Greg,
perhaps you have a front wing for the passenger's side (left) for a Frontera Sport 1995?
Tried today to sort out some rusty spots :oops:
Whole work ended in a hole along the wheels' arch.
Novablack would be fine, but is not a must-have...
Have a splendid weekend
Kind regards,
Sorry for my pigeonenglish.
JEOH
Vehicle Name: Gigante & Grünstreifen
G R Ü N S T R E I F E N (1997) 2013 - today:
BL 2.5 cm, roofrack scratch w cb,
stripped interior,
DEFA heater 230V DC + motorwarming
Nortenha MTK2 235/70 R16
G I G A N T E (1998) 2018 - today:
General Grabber AT2, Soft-Top with
old engine (mix c20ne/s20xe) & gearbox donated by GodZilla
Postby gregster on Sat May 07, 2016 5:58 pm
Mickey boy wrote:Hi Gregster, I'm after a grey rear headrest for my 51' plate v6 LWB frontera, interior is full cloth, no leather.
Thanks mick.
Can you send me a pic, so I can try and match the fabric for you.
Email to Sales@fronty4x4spares.com
Greg
Postby gregster on Sat May 07, 2016 6:02 pm
bhcalcutta wrote:Hi Greg...Have you by any chance got any manual lockers in?
Not at the moment, they dont come up often. I have heard bad reports about the Aisen looking ones that Milners do now, quite a few people have broken them I think. AVM's are better if you cant find the genuine Aisen ones...
Postby gregster on Sat May 07, 2016 6:05 pm
JEOH wrote:Hallo Greg,
Hi Greg,
Hi Jeoh,
I should have a good solid wing for you, it wont be black though...
Message me the address and we can discuss the options for sending it and work out the costs...
Greg
Postby Pete Stewart on Tue May 10, 2016 10:59 am
Hi Gregster,
I posted earlier I was having trouble starting the fronty & thought it was the diesel injector pump
I've replaced the corroded bleed up pipes, (& system bled), glow plugs, filter & new battery still no joy starting in the morning - starts on 5th/6th attempt using Easy Start (& will start during the day from a warm condition)
Do you have any reconditioned diesel pumps ?
Frontera 2001 2.2 DTI (LWB) 110,000 miles
thanks
Pete
Pete Stewart
Postby gregster on Tue May 10, 2016 2:16 pm
Hi Peter, not reconditioned, but I do have good working ones.
Greg
Postby Pete Stewart on Tue May 10, 2016 4:03 pm
That's great Greg,
How much are they bearing in mind I live in Belfast (postage etc....)
Pete
Pete Stewart
Postby FronteraBob on Sat May 14, 2016 4:07 am
Hi Greg, I need a brake pad wear cable as the front nearside of my 99 V6 tip has melted on ours when the caliper seized up, so I now have ABS light on and check pads message but thankfully no fault codes, also the disc is warped if you have any newish ones that would be great.
Cheers Bob :thumbup:
When words become violence, what could be better than silence.....
FronteraBob
Vehicle Name: Red Devil !
Modifications: Zero....
Postby gregster on Sat May 14, 2016 9:26 am
Hi Bob...Most of the B's we see have the pad wear sensors disconnected these days, I cant remember the last one I saw where they were connected. As for discs I can probably find a good pair, but I would recommend that you buy these new.
Postby gregster on Tue May 17, 2016 6:53 pm
Currently Breaking....
B
1 x 3.2v6 manual, came in today
2 x y22dth 2.2dti's
4 x x22dth 2.2dti's
1 x y22se 2.2i
Have just broken 1x y22dth and 3 x22dth so loads of fresh parts available already
A
2.4i
2.3td
x20se swb
2.8td
have recently broken 4x 2.8's, 1x 2.5, 2x 2.2i, and several 2.0i's...so lots of parts available still...
Give us a call on 01622 739908 for any frontera parts needs...
Postby FronteraBob on Tue May 17, 2016 10:57 pm
gregster wrote:Hi Bob...Most of the B's we see have the pad wear sensors disconnected these days, I cant remember the last one I saw where they were connected. As for discs I can probably find a good pair, but I would recommend that you buy these new.
But is the knackered pad sensor not the cause the check pads warning message, also do you have a leather interior in good nick ?
Ta Bob :thumbup:
FronteraBob
Postby gregster on Wed May 18, 2016 12:04 pm
If the contact is shorting out it gives the check pads message I think, so if disconnected and insulated as most are they dont flag a fault.
Yes I have a couple of nice B series leather interiors, one in black, and a half leather Olympus trim also in grey.
Greg
Postby RatCav on Wed May 18, 2016 12:38 pm
I may need either a 2.5 or 2.8 gearbox. Things went a bit sideways with the Mk.I project. Still going ahead but the original plan shifted to Plan "C" regarding gearbox ideas.
Postby gregster on Thu May 19, 2016 11:55 am
No worries bud, let me know what you need and when, and we will sort it for you.
Postby RatCav on Thu May 19, 2016 4:32 pm
All depends on whether 215 bhp will bust an untested 2.8 gearbox I bought off eblag for £25 6 years ago from a Trooper that had done the Dakar rally three times in the mid 90's :D
If it works, there is some serious history in it .. if not there will be a pile of cogs in an oily sand dune in the road :lol: :lol: :lol:
